Enthusiast ![]() Joined Sep 22, '10 From pomona, ca Currently Offline Reputation: 1 (100%) ![]() |
as the tittle says it, just wanted to know if some of you guys on here are using the Safc2 to tune based on the map signal.
ive been doing alot of research and i came across this. so, will it be better to tune using the map signal and be able to tune by boost, or will it better to do it the regular way, by throttle ?? any input is appreciated. thanks |
i used throttle.
Lo-Fi Version | Time is now: February 13th, 2025 - 6:05 PM |
