4 Pages V  < 1 2 3 4 >
> what all cars came with a 3vzfe, looking to swap
post Dec 14, 2011 - 11:39 AM
kurt95gt
Joined Aug 23, '11
From kenton ohio
ok ill keep that in mind thank you
ill try to get in touch with him on that forum if my phone will let me
94 st hatch my daily driver
n
post Dec 14, 2011 - 2:29 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
wtf is the deal with a flywheel for this motor can find one anywhere an no parts store can get one
can I reuse the 5s flywheel if I bor out the center like celicast95 did to fit on his 1mz ?
n
post Dec 14, 2011 - 3:21 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
I didn't bore anything out. I bought a Fidanza unit for a Solara V6 and bolted it on.
And then for it to bolt up properly to the transmission (using the S54) you will need a clutch disk with the same contact surface as the Solara Flywheel. My solution was a Stage 2 Kevlar clutch kit from South Bend Clutch for a MR2 turbo that had been custom splined for the S54.
A $700 solution.
Or you can get an OEM flywheel from a 2000 Camry V6 on the cheap from car-part.com and run a standard Celica GT clutch kit. You'll have less contact surface to the flywheel and it may slip, but it can be done that way. I don't recommend it though.
**** Photobucket
post Dec 14, 2011 - 3:42 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
ok I thought I read someone modded the s54 flywheel to fit
oh well I figure something out
was the clutch kit itself 700?
n
post Dec 14, 2011 - 5:33 PM
95CelicaST
Joined Feb 5, '05
No, the clutch was $340, and the Flywheel was $300 something.
**** Photobucket
post Dec 14, 2011 - 5:46 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
has anyone tryed a s54 flywheel to see how far off it is
n
post Dec 15, 2011 - 10:00 AM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Im picking up 3vz/e53 Saturday
500 for pair
n
post Dec 15, 2011 - 10:09 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
QUOTE (kurt95gt @ Dec 15, 2011 - 9:00 AM) *
500 for pair
WOOT.
make it happen!
post Dec 15, 2011 - 11:36 AM
kurt95gt
Joined Aug 23, '11
From kenton ohio
only now got some bad news idk if im getting it since now they want my old motor
an I wanna keep my old one till I kno this v6 will run fine
n
post Dec 15, 2011 - 2:04 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
found another 3vz for 550 they pull it an I dont have to fork over my motor to get it
so looking at it this Saturday an if all is good I should have it within a week
n
post Dec 15, 2011 - 2:48 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
ok this is probably a stupid question but do I need to completely rebuild the motor since it has 2almost 200000 miles on it or could I do a light rebuild for now as long as the compression checks out ok
an the do a full complete tear down an rebuild before I try to turbo
been told they are a tough motor so not sure what to do I've heard just change timing belt an waterpump an new head gaskets an it'll be good for another 100000 but just want more opinions
n
post Dec 15, 2011 - 8:03 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
im droppin mine in at 270xxx miles w/o a rebuild. it droe STRONG
post Dec 15, 2011 - 8:10 PM
richee3
Joined Jun 29, '08
From Denver
Better safe than sorry. I'd at least replace plugs, wires, dizzy, gaskets, water and oil pumps, thermostat, and timing belt.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Dec 15, 2011 - 8:34 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
I plan on basically everything richee3 said but I guess if you can boost without a problem at 270the I should be fine at 200the stock
n
post Dec 16, 2011 - 9:02 AM
95CelicaST
Joined Feb 5, '05
Tear the motor down and check the bores for damage. If no damage then put it back together with all new gaskets. If the bores are showing vertical wear then you should have it sent to a machine shop.
I understand you're wanting to do this on a budget, but buying a mystery high mileage motor and assuming it's fine seems crazy to me.
**** Photobucket
post Dec 16, 2011 - 10:47 AM
kurt95gt
Joined Aug 23, '11
From kenton ohio
yea im gonna atleast drop the oilman an check under the valve covers but ill get to see it run an I beleave the car can still move too so it wont be a complete mystery lol but I do get what your saying
n
post Dec 16, 2011 - 11:46 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
I'm not turboing this motor. Im just getting it in and running. i can find a cheap bare 3vz to rebuild for turbo later.
plus i drove my 3vz for a few thousand miles so i know its condition
post Dec 16, 2011 - 12:01 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
ahh ok well depending on how it seems to run I may drop it in for the simmer an rebuild over next winter
I reaffirmed little more again online last night why couldn't I run a 3sgte flywheel and a s54 clutch disc like people do with a 3sflywheel swap using a s54 the way everything read a 3s2 flywheel will bolt on the 3vz
n
post Dec 17, 2011 - 6:28 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
so went to look at what I thought was going to be a 932 es300 with a 3vz but it ended up being a 96tree es300 with a 1mz
n
post Dec 17, 2011 - 8:42 PM
richee3
Joined Jun 29, '08
From Denver
Win!
1998 Celica GT-
BEAMS Swapped.
Lo-Fi Version Time is now: February 23rd, 2025 - 3:27 PM
