> Shifting Problems Or Gear Issues, Need help!!
post Dec 17, 2011 - 12:59 AM
howie_vang
Joined Jul 11, '08
From Cali
I have been having troubles with shifting lately. Sometimes when I shift it will not go into gear while my car is running and even when i barely start it. Is it transmission problem..or does it has to do with clutch..it is getting irritating and dangerous when i am trying to shift gear..Also, sometimes going to reverse is hard too..it just bounce back to neutral when it doesn't go in..I appreciate if I can get some advice..Need to fix it soon.. Thanks for you time.
post Dec 17, 2011 - 2:32 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
Sounds like shifter cables are stretched and needing replacement.
post Dec 18, 2011 - 1:27 PM
RabidTRD
Joined May 31, '11
From Rochester, NY
Throwout bearing and clutch probably need to be replaced. Mine is doing the same thing at times. My throwout bearing is so bad that while I drive, and let off the gas, the car JERKS hard. When I sit at a light and put the car in neutral, the bearing wines lol.
post Dec 22, 2011 - 9:12 AM
opie_7afe
Joined Feb 26, '11
From beaufort,SC
QUOTE (RabidTRD @ Dec 18, 2011 - 1:27 PM) *
thanks for this post, i was wondering why my car jerks when i let off the gas, might be the noise im having when its below 65f and stops when warmed up.....was figuring it was drive line related and not mount related....after this trip i really need to stop blowing so much money on autogeek buying detailing stuff and get my butt to the pick and pull and get my transmission.....
post Dec 23, 2011 - 1:09 AM
howie_vang
Joined Jul 11, '08
From Cali
thanks for all the comment..now it is so difficult for me to reverse..and of course it won't go into gear at some point while driving..i don't even want to drive it anymore..i shall get new clutch..
post Dec 23, 2011 - 2:46 AM
pandakid
Joined Feb 12, '06
From Fresno CA
sounds like a bad clutch and throw out bearing,if you get a new clutch i highly recommed resurfacing your flywheel.(if you don't get a new flywheel)
post Dec 23, 2011 - 6:53 PM
RabidTRD
Joined May 31, '11
From Rochester, NY
Don't get a lighter flywheel unless you like your RPM's dropping drastically fast. Stick with a stock if you replace. The flywheel in the Celica is already pretty light compared to the other cars I've driven.
Lo-Fi Version Time is now: January 11th, 2025 - 8:45 PM
