> *HELP* Rod Separation From Piston, how do you do it?
post Dec 21, 2011 - 6:39 PM
DST94
Joined May 11, '09
From California
I need to replace my rod(broke the bearing). How do i separate the rod from the piston? Similarly, do I need to hone the cylinder if i am replacing the piston with a piston from another 7AFE? (i think its yes, but i just want to make sure) Help is greatly appreciated, i gotta get her running by the end of the week. . .
post Dec 21, 2011 - 6:57 PM
Cuts_the_Pilot
Joined Dec 15, '02
From Tasmania(Australia)
There is a circlip on the piston holding the gudegon pin in. Remove that, slide the gudgeon pin out, remove rod.
You don't HAVE to, but it's always a good idea when installing a new set of rings to even just give them a light flick with the hone so you have some nice new cross hatching in the bore to help the rings bed in.
ST205 Group A Rallye GT-Four, #61 of 77............600hp GT3582r
GRX133 Toyota Mark X 350s
post Dec 21, 2011 - 7:31 PM
DST94
Joined May 11, '09
From California
QUOTE (Cuts_the_Pilot @ Dec 21, 2011 - 3:57 PM) *
this is for an OEM piston and rod right? Im not seeing any pins, just a cylinder pushed in between the piston and the rod.
and im not ONLY replacing rings, im swapping my piston for another from a different 7AFE does your answer still apply?
post Dec 21, 2011 - 7:38 PM
mandrek
Joined May 4, '05
From western MD/NOVA
nope. sorry to say, but the 7afe pins are pressed in. quite aggrovating since most other are held in by a clip..
yeah you are going to have to press the old pin out and then have the new one pressed back in..
and as long as the other piston is of the same "mark" designation for piston diamiter/ bore then you should be ok..
just make sure it is the same.. say. post a pic of the top of the piston if you can.
post Dec 21, 2011 - 7:56 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
take it to a machine shop, they will heat it up and install the new piston on the rod. should cost more than 10 bucks.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
Lo-Fi Version Time is now: January 12th, 2025 - 5:50 AM
