> projectors modification
post Dec 25, 2011 - 4:55 PM
hzawde
Joined Nov 13, '10
From Calgary
is it necesary to modify them once you have them , or can i just directly replace them, i doubt everyone with them
has done the mod for lhd use
post Dec 25, 2011 - 5:57 PM
Timmyface
Joined Apr 17, '10
From Maitland, NSW
It depends on a few things:
You may, blind the opposite side of the road resulting in a crash, or a fine off police.
It will help you see better on the road, but its more for safety reasons. If your not running HIDs you could get away with it probaby.
post Dec 25, 2011 - 6:27 PM
mkernz22
Joined May 10, '10
From MA
you could also just make them point a little bit lower too
post Dec 25, 2011 - 7:12 PM
hzawde
Joined Nov 13, '10
From Calgary
ill do the point thing probably, looks too intense to do the whole mod thing
QUOTE (mkernz22 @ Dec 25, 2011 - 6:27 PM) *
post Dec 25, 2011 - 7:42 PM
RoyO
Joined Jan 8, '09
From Netherlands
In the Netherlands, we have to convert them to LHD to be road-legal, so that's the main reason why I converted them.
Modification is easy but it just takes some time. Here's a short how-to of my conversion.
My new projectors
Take off the lights and all rubber parts.
Put them in the stove: 10 minutes at 120 degrees Celsius
Take off the glass
The part of the projector that has to be converted
Cutting the metall. I used a DREMEL with a grinding wheel.
Re-install the projector. Put it back into the oven so the glue becomes soft again > it's easier to re-install the glass.
I used this glue
The result
I installed Pilot HID, H1 6000 in lowbeams, HB3 6000K in highbeams and H3 6000K in the foglights.
-Roy
This post has been edited by RoyO: Dec 26, 2011 - 5:09 AM
post Dec 25, 2011 - 9:03 PM
hzawde
Joined Nov 13, '10
From Calgary
ok thanks a lot man, really helpful
Lo-Fi Version Time is now: November 23rd, 2024 - 12:10 PM
