> swapping alternator parts for higher output alternator
post Dec 30, 2011 - 10:46 PM
match220
Joined May 13, '06
From Kaimuki, HI
This is a instructional, not a question, do this at your own risk though. Low level of difficulty. You need a philips, an 8mm and a 10mm. I used a hard-to-find alternator, a similar NipponDenso alternator should work, but I can't guarantee it.
I have a 3rd gen 3sgte, but the 5sfe alternator that I had on it needed replacing because the adjuster bolt snapped off inside the alternator, so I mixed two together. The alternator that I bought is from an ST215 (4th gen 3sgte). One inch larger diameter and one inch thicker. The problem is that the ST215 alternator positive output post hits the hood, and so does the 3 pin plug. Everything is in the pictures below, and there is more in the video (which just finished uploading and should be live in a bit)
http://www.youtube.com/watch?v=Y1BliP5KnEY
This post has been edited by match220: Dec 31, 2011 - 12:56 AM
-Jay
95 GT conv. project car: Manual, Gen III 3sgte, JN pisons, Eagle rods, overbore, crank knife-edged, crank scraper, ARP head/main/flywheel, Autronic EMS, Haltech Dual Wideband O2 controller, Audi 1.8T individual coils, FMIC and SSQV BOV, 3" downpipe, 3" ultra-high-flow cat, 2.5" Borla muffler, +other
01 S2000: FMIC, Haltech EMS, Haltech wideband, 570cc inj, forged pistons/rods, sleeved block, 5 angle valve job, ported and polished
02 R6, all stock, except for braided stainless brake lines, frame sliders, and adjustable brake/clutch leve
Lo-Fi Version Time is now: January 11th, 2025 - 5:47 PM
