> rear strut bar
post Jan 3, 2012 - 12:42 AM
pandakid
Joined Feb 12, '06
From Fresno CA
anyone know where i can get one?i try search no dice.
post Jan 3, 2012 - 1:10 AM
CAcelica29
Joined Aug 26, '11
From ventura, ca
ebay
post Jan 3, 2012 - 1:15 AM
pandakid
Joined Feb 12, '06
From Fresno CA
i didn't see one unless the gt4 ones fit on a usdm gt model
post Jan 3, 2012 - 1:19 AM
mak5603
Joined Oct 20, '08
They do indeed, i rock one.
2014 Toyota Rav4 XLE
post Jan 3, 2012 - 1:53 AM
pandakid
Joined Feb 12, '06
From Fresno CA
ty auto-x season starts soon.rear end whips out.
post Jan 3, 2012 - 2:50 AM
SupraKid
Joined Aug 15, '10
From The Best Coast
I have a GT4 rear bar in my car, bolted right in.
post Jan 3, 2012 - 8:54 AM
richee3
Joined Jun 29, '08
From Denver
Check out General Discussion, look inbthhevstickies for Discounted Parts for Members. GT4 rear strut bars are like $70 there.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Jan 3, 2012 - 2:40 PM
pandakid
Joined Feb 12, '06
From Fresno CA
thanks i was about to ask how much they go for
post Jan 3, 2012 - 4:36 PM
richee3
Joined Jun 29, '08
From Denver
Between $75-200 depending on when/where you buy it. About $150 from eBay with the leather cover and the strut tower covers.
1998 Celica GT-
BEAMS Swapped.
post Jan 4, 2012 - 12:42 AM
RabidTRD
Joined May 31, '11
From Rochester, NY
Wait so you're trying to stiffen the rear because it swings out? That means your front end is too soft and the rear is stiffer... Celica's understeer naturally, not oversteer. Adding this bar will add oversteer due to stiffening the rear and usually that's the desired result. If you want the whole car to go in the same line, get urethane front sway bar bushings to counteract the rear swinging. Sounds like your front bushings may be shot at this point.
post Jan 4, 2012 - 3:03 PM
jeffrosie
Joined Sep 11, '08
From Surrey Unitedkingdom
Or get a stiffer rear anti-roll-bar, if what you are trying to reduce oversteer.
post Jan 4, 2012 - 5:29 PM
klue
Joined Mar 8, '10
From Great White North
I've got cusco and whiteline bars if your looking for a quality piece. Stiffening the rear sway bar will induce oversteer
Lo-Fi Version Time is now: December 11th, 2024 - 7:08 PM
