> St202 LSD Tranny on 3sgte 3rd gen FWD swap
post Jan 6, 2012 - 9:27 PM
celica95-95
Joined Aug 4, '06
From Toronto
Hey guys looking for some info on St202 beams tranny Looking to put in my 3sgte 3rd Fwd swap for the use of the LSD ,
I know that it will bolt up , and Axle should be the same , Would the clutch be the same As the 5sfe tranny — this is what i'am running on my swap
I thinking it should bolt up and work , but just looking to get some info thanks for the help !
post Jan 7, 2012 - 8:51 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
no the E153 has a larger spline.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Jan 8, 2012 - 10:02 AM
richee3
Joined Jun 29, '08
From Denver
No. You'll need a 3S flywheel and pressure plate and 5S disc and throw out bearing.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Jan 8, 2012 - 11:06 AM
celica95-95
Joined Aug 4, '06
From Toronto
Cool thanks right now i have 3s flywheel with a stage 4 clutch on the 5s tranny , are you running the st202 LSD tranny on your setup ?
post Jan 8, 2012 - 11:54 AM
richee3
Joined Jun 29, '08
From Denver
QUOTE (celica95-95 @ Jan 8, 2012 - 10:06 AM) *
Yes, but the difference is that I have a BEAMS. It's no 3S-GTE, but it's essentially the same thing- a 3S motor with the S54 transmission. I have been told before that you can use an aftermarket performance 5S clutch, but I cannot confirm if that's true. At any rate, I wouldn't want a clutch intended for the lower power 5S to be anywhere near my 3S.
1998 Celica GT-
BEAMS Swapped.
post Jan 8, 2012 - 12:43 PM
celica95-95
Joined Aug 4, '06
From Toronto
great thanks ! The axle I have are from st204 gt-s thinking u have the same one ? Or are they different axle
Right now i have over 300 Whp so hoping that the LSD will help ! more for the racing-side
I seen on one form , someone had Celica st axle with BEAMS tranny didn't work to good at 80mph or more
So i guess i would be looking at the BEAMS tranny and maybe a clutch for it as well
what clutch would I be looking for the only a st202 ? one or is the same as mr2 st205
post Jan 8, 2012 - 3:24 PM
richee3
Joined Jun 29, '08
From Denver
Yeah, those axles will fit just fine. I can't say much about power though. I've read that the S54 and the axles both are good up to about 300 whp. After that, an E153 is geared much better.
Was it just the axles that didn't work so well above 80 or the trans? Mine is great all the way up to 116 mph where the ECU shuts the car down but I don't have near the power you do.
As for the clutch, you're good on the 3S flywheel but you'll need a good 5S disc and 3S pressure plate. Brand/stage is up to you. I'd lean more towards the MR2/ST205 clutch than the ST202. I'm not sure of the power ratings on any of them but I'm sure the ST205 clutch can handle a lot more than an ST202 clutch.
1998 Celica GT-
BEAMS Swapped.
post Jan 8, 2012 - 8:13 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
actually its just the center section. this is what i mean by splines. here is what you need. 3S clutch with a 5S center hub. now here is the good news for you. Southbend clutch can make this for you. its similar to when i alter the E153 trans to mount to a 2ZZ-GE. we use a 2ZZ clutch and flywheel with a E153 center section. call southbend and talk to Andy in the imports dept. tell him i sent you, he will take care of you.
post Jan 8, 2012 - 8:46 PM
richee3
Joined Jun 29, '08
From Denver
I'm confused... As I understand it, He has a 3S-GTE with an S54 right now, and he's getting the BEAMS S54 with LSD, not an E153. Did I miss something? I understand the difference in the spline count between the two transmissions, but I don't think he's getting an E153 unless I missed it both times I read the thread.
1998 Celica GT-
BEAMS Swapped.
post Jan 8, 2012 - 9:42 PM
celica95-95
Joined Aug 4, '06
From Toronto
Thanks for info smaay , richee3 got it right looking to get the BEAMS S54 with the LSD but looking at my setup i have 3s fly-wheel with stage 4 clutch 5S and 3s pressure plate... so maybe just a tranny swap would do
post Jan 8, 2012 - 10:42 PM
richee3
Joined Jun 29, '08
From Denver
If you currently have an S54, then you won't even need to replace your clutch. Both transmissions are S54's so just get a new throw out bearing and you're good to go.
For what it's worth, the LSD S54 has a different final drive ratio. Non LSD is 4.176 and the LSD version is 4.18. I don't know if this makes a huge difference or not. It seems to me that at 60, I used to cruise at 3,000 rpm even and with my LSD, I cruise at 3,100. Not a huge difference. It might even be in my mind. However, turnip races his BEAMS and according to him, his LSD trans had him bouncing off of the rev limiter in 5th gear down the main straight but his open diff tranny let him keep pulling. I don't know how much of a difference it will make for you though.
1998 Celica GT-
BEAMS Swapped.
post Jan 8, 2012 - 11:01 PM
celica95-95
Joined Aug 4, '06
From Toronto
yea i dont know if it would do the same in 5th gear , right now i got wheel hoop when the tree drop at the track , so hoping the LSD will help , other that that the tranny has been great and motor , going to change the Eng-mounts as well to the TRD ones and under brace i'am thinking
So I'll be on the look out for a BEAMS TRAN now ;-) thanks for the info
post Jan 20, 2012 - 2:45 PM
celica95-95
Joined Aug 4, '06
From Toronto
So i have been looking at BEAMS transmission how do you tell which one have the LSD
post Jan 21, 2012 - 4:29 PM
richee3
Joined Jun 29, '08
From Denver
The easiest way to tell is to look where the axles slip into the transmission.
Open diff:
LSD:
The open diff has the narrow bar, the LSD is much thicker.
This post has been edited by richee3: Jan 21, 2012 - 4:31 PM
1998 Celica GT-
BEAMS Swapped.
post Jan 21, 2012 - 6:20 PM
celica95-95
Joined Aug 4, '06
From Toronto
Great man thanks , how does the transmission you have hold-up? Does the LSD help's a lot?
thanks just asking because was think to Overhaul my Transmission and add an upgraded LSD
post Jan 21, 2012 - 6:43 PM
richee3
Joined Jun 29, '08
From Denver
QUOTE (celica95-95 @ Jan 21, 2012 - 5:20 PM) *
It holds up great! Feels about like any other S54 in a straight line but turns more aggressively into corners when I blip the throttle. Reverse, it cuts around a lot quicker than the open diff. And when I'm at WOT in first or second, I'll definitely know if I don't have the wheels pointed perfectly straight. It will take off whichever direction the wheels are pointed, much less forgiving than the open diff. I haven't gotten to go for a good spirited drive with it yet, so this is just what I've gotten from a few slightly aggressive short drives.
If you order the MR-S LSD from eBay and overhaul the transmission yourself, I suspect you'll be more than satisfied with your investment. I haven't put a lot of miles in with mine yet but I already don't want another open diff S54.
Per Manny,
QUOTE (presure2 @ Nov 29, 2009 - 8:52 AM) *
and the LSD works fantasticly.
i love the way it allows power delievery from mid corner to exit, where the car normally wants to just push out the LSD really helps pull the car out of the corner straight.
This post has been edited by richee3: Jan 21, 2012 - 7:11 PM
1998 Celica GT-
BEAMS Swapped.
post Jan 21, 2012 - 8:08 PM
celica95-95
Joined Aug 4, '06
From Toronto
Yea thanks for that post too , I check that e-bay one as well couple other ones if i do the transmission going to change every thing ... I have guy that works on transmission he is also a tuner and know his Toyota , I did all the work my-self on my car but the transmission might give it too him if the price is right !
I check out a Beams motor with Tran on weekend but did know if it was LSD , but know now thanks too the pic's. They wanted 700 for it. might go look at next weekend see if its LSD or not
post Jan 21, 2012 - 10:52 PM
richee3
Joined Jun 29, '08
From Denver
Motor and trans for $700 or just the trans? Either way, that seems like a decent deal. Go figure aftermarket LSD for the S54 is $400 plus other parts for the rebuild, plus labor if you take it to your friend. It would be pushing if not exceeding the $700 trans you could just bolt on and drive away.
1998 Celica GT-
BEAMS Swapped.
post Jan 22, 2012 - 8:13 PM
celica95-95
Joined Aug 4, '06
From Toronto
Trans 700 only no motor , I still got to check for the LSD ... but I see where you coming from i'am thinking the same as well ! In the other hand do the trans with upgrade LSD .... I know i will get all that 330 WHP down
going back this week to check for the LSD
post Feb 18, 2012 - 12:19 AM
Ghost1
Joined Sep 25, '10
From Toronto, Canada
Where did u manage to find 1, i am looking for 1 myself.
5sge in research mode.
winter = building time.
Lo-Fi Version Time is now: December 2nd, 2024 - 9:32 AM
