2 Pages V  < 1 2
> St202 LSD Tranny on 3sgte 3rd gen FWD swap
post Feb 19, 2012 - 12:25 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
QUOTE (richee3 @ Jan 21, 2012 - 1:29 PM) *
The easiest way to tell is to look where the axles slip into the transmission.
Open diff:
LSD:
The open diff has the narrow bar, the LSD is much thicker.
that first pic looks exactly like the factory LSD that comes in 93+ MR2 transmissions.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Feb 23, 2012 - 5:55 PM
celica95-95
Joined Aug 4, '06
From Toronto
QUOTE (Ghost1 @ Feb 18, 2012 - 12:19 AM) *
Where did u manage to find 1, i am looking for 1 myself.
I found one in Toronto , Ontario I would still have to look at it to check if it is LSD
I Going to go with the KAAZ LSD in my Tranny
post Feb 23, 2012 - 6:24 PM
Ghost1
Joined Sep 25, '10
From Toronto, Canada
i would buy that tranny in a hard beat. if i could find it , what shop or importer has it ?
This post has been edited by Ghost1: Feb 23, 2012 - 6:24 PM
5sge in research mode.
winter = building time.
post Feb 23, 2012 - 7:29 PM
celica95-95
Joined Aug 4, '06
From Toronto
QUOTE (Ghost1 @ Feb 23, 2012 - 6:24 PM) *
jdm toronto , or japan motor toronto
could check them out
post Mar 26, 2012 - 2:18 PM
purplegt4
Joined Feb 7, '03
From Northern Virginia
Open diff:
LSD:
Is there also a 'spin test' to find out? The trans I just acquired has the thicker bar, yet if I turn one side, the other spins the other way (both in and out of gear).
post Mar 30, 2012 - 4:17 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
The test I did with my helical lsd is as follows : you spin the right wheel forward (while the car is in the air)m, the left tire should spin backward!
This post has been edited by BonzaiCelica: Mar 30, 2012 - 4:20 PM
post Mar 30, 2012 - 4:42 PM
richee3
Joined Jun 29, '08
From Denver
My open diff did that too. Not really a good test.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Mar 30, 2012 - 5:18 PM
BonzaiCelica
Joined Apr 24, '08
QUOTE (richee3 @ Mar 30, 2012 - 4:42 PM) *
go fast around a turn and as your come out of the turn stomp on the gas pedal. And you should be able to come out of the turn really fast( you'l be able to notice your tires hugging the turn)
post Mar 30, 2012 - 5:39 PM
richee3
Joined Jun 29, '08
From Denver
You can definitely feel the difference there. I was merely remarking on one wheel spinning forwards and the other backwards when the car is jacked up. I was just saying that my open diff would sometimes spin one wheel, sometimes both wheels in opposite directions. I haven't tested my LSD tranny to see what it does.
1998 Celica GT-
BEAMS Swapped.
post Apr 30, 2012 - 4:08 PM
BonzaiCelica
Joined Apr 24, '08
in need of a clutch kit for the 3SGE Beams motor. I know the hybrid 3sgte pressure plate/clutch cover and 5sfe disc. How about the spline count. I know spec is the only company that already has these ready off the shelf. But all these clutch kits are for turbo application 3sgte. I'll call andy from southbend thanks Smaay
How about using the 1989 Celica GT-S clutch kit. These cars come with 1st gen 3S-GE engines here in the USA. Just not sure what transmissions these come with??? Anybody have the slightest clue?
This post has been edited by BonzaiCelica: Apr 30, 2012 - 4:13 PM
post Apr 30, 2012 - 5:29 PM
richee3
Joined Jun 29, '08
From Denver
BEAMS clutch disc and ST185 pressure plate. Part numbers 31250-20331 for the disc and 31210-20351 for the pressure plate.
1998 Celica GT-
BEAMS Swapped.
post Apr 30, 2012 - 7:23 PM
BonzaiCelica
Joined Apr 24, '08
QUOTE (richee3 @ Apr 30, 2012 - 5:29 PM) *
hmm wow. then to my understanding via toyodiy. 1999 5SFE and 1999 3SGE Beams motor use the same disc plate??? With this 4.529 final drive gear ratio I have an extra 19 more ft lb torque(on paper) than a 5sfe. So the ST185 pressure plate should suffice the extra amount of torque right??
1999 Toyota Celica SS-III
http://www.toyodiy.com/parts/p_J_1999_TOYO...BLMZF_3101.html
1999 Toyota Celica ST204 (5SFE)
http://www.toyodiy.com/parts/p_U_1999_TOYO...LMGKK_3101.html
This post has been edited by BonzaiCelica: Apr 30, 2012 - 7:24 PM
post Apr 30, 2012 - 8:02 PM
richee3
Joined Jun 29, '08
From Denver
I would imagine the disc can handle it but there are always upgraded 5S discs that can definitely handle it. The ST185 can more than handle the extra torque since the second gen 3S-GTE had 224 lb ft of torque stock.
1998 Celica GT-
BEAMS Swapped.
2 Pages V  < 1 2
Lo-Fi Version Time is now: December 2nd, 2024 - 9:47 AM
