> ECU chips... really worth it ??
post Jan 10, 2012 - 12:13 AM
alphonsus
Joined Jan 9, '12
From Missouri
i've noticed several ECU chips being advertised in different places, but are they really worth it ? they sound too good to be true, that is, increase horsepower AND mpg's in just 15 minutes for 70 bucks .. ??
does everyone have one of these except me ? am i that late to the "party" ? just wanted to ask for anyones two cents worth on the subject. thanks to one and all in advance. -al
post Jan 10, 2012 - 12:17 AM
SupraKid
Joined Aug 15, '10
From The Best Coast
No.
post Jan 10, 2012 - 12:19 AM
kurt95gt
Joined Aug 23, '11
From kenton ohio
What he said
94 st hatch my daily driver
n
post Jan 10, 2012 - 12:26 AM
it depends. Dot let first responses fool you...
if you are selling them, its totally worth it, you can make a lot of money, claiming false resutls, that cant be vrified, most are placed by the user, which voids the warranty, thus excluding you from liability.
if you are buying them yes and no. On a celica definetely no.
post Jan 10, 2012 - 9:00 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
about the only "chipping" thats worth it is when you program an ECU. In our case, theyre not programable. also installing a small "chip" in place or in line with a sensoe is 100% BS, all the time.
post Jan 10, 2012 - 10:33 AM
cheela
Joined Feb 2, '07
From Berlin, WI
QUOTE (njccmd2002 @ Jan 9, 2012 - 11:26 PM) *
post Jan 10, 2012 - 10:35 AM
Neon90424
Joined Jan 19, '11
biggest ricer scam ever.
post Jan 10, 2012 - 11:14 AM
jaylenewin
Joined Jan 2, '12
From Sydney, Australia
It really depends on your everyday situation. Unless you're fitting performance parts to your celica to do sunday cups than go for it... but you really wouldnt want an ECU for everyday driving. When you fit an ECU into a stock celica, you think you've noticed something different but there really wont be much difference at all. ECU = Placebo effect. Might as well buy a packet of chips and stick it under your hood. You'll notice something too, your car's engine power will smoke competition for sure tongue.gif
post Jan 10, 2012 - 11:34 AM
richee3
Joined Jun 29, '08
From Denver
You talking about those chips on eBay? No, those don't work. Those are nothing more than a resistor that you could buy for about $0.03.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Jan 10, 2012 - 11:47 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
CHIPS you install in place of or in line of a sensor = scam
Chipping or PROGRAMMING your ecu (a legit reprogram of your ecu, like honda guys can do, but NOT on a toyota ecu i ever heard of) WILL make a difference.
so any "chip" directed to a toyota = scam unless it replaces the ecu entirely, or a piggy back.
post Jan 10, 2012 - 2:03 PM
RabidTRD
Joined May 31, '11
From Rochester, NY
So when I run cams, I don't have to reprogram my ECU right? Because it's not possible?
post Jan 10, 2012 - 3:51 PM
KAOS
Joined Apr 18, '06
From Calgary, Canada
QUOTE (RabidTRD @ Jan 10, 2012 - 12:03 PM) *
I believe you will need to reset your ECU so that it can pick up on the modifications and make the necessary adjustments on its own.
QUICK INSTRUCTIONS:
Start the car and let it idle for about 10 minutes
Turn off the car, pop the hood.
According to the BGB - pull the EFI fuse for ~20-30 seconds (IIRC)
Put it back in, close the hood
Start the car.
Takes a bit to learn itself... but after any significant performance modification, its a great idea to reset the ECU.
post Jan 10, 2012 - 4:06 PM
mkernz22
Joined May 10, '10
From MA
Should you get a fuel management system when you get cams?
post Jan 10, 2012 - 6:14 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
you should get something to tune with for anything more than intake / exhaust.
hell just getting a piggyback on a stock car will probably gain you >10 hp and some mpgs as well
post Jan 10, 2012 - 6:26 PM
czwalga
Joined Sep 27, '10
From pittsburgh
Why are toyota ECU's not flashable?
I have a chevy tuner/flasher for my rx7 its pretty much amazing. You can do anything to it. I'm in the upper 700rwhp range and I still have the stock ECU. That really blows if you have to get an engine management system for pretty much any real mods....
-93 Rx7, Turbo 6.1L v8, 725rwhp/760rwtq
-95 Celica GT Rally Car - 3sge/AWD
-10 F150
Always buying stock wheels... PM me if interested in selling.
post Jan 10, 2012 - 6:27 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
the ROM that holds the tune isn't reprogrammable IIRC.
post Jan 10, 2012 - 6:33 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
I've run across a 'New Standard' that says all ECU after Model Year '03 must be able to be re-flashed by other than the Dealer.. but that doesnt apply to us frown.gif
post Jan 10, 2012 - 6:35 PM
czwalga
Joined Sep 27, '10
From pittsburgh
Interesting...
-10 F150
post Jan 10, 2012 - 6:48 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
QUOTE (czwalga @ Jan 10, 2012 - 3:26 PM) *
toyota locks them in the firmware. other manufacturers like mitsubushi dont, so you can just plug into the ODBII port and reflash it
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Jan 10, 2012 - 7:09 PM
czwalga
Joined Sep 27, '10
From pittsburgh
QUOTE (Smaay @ Jan 10, 2012 - 6:48 PM) *
Most manufacturers lock them, however with enough aftermarket support the money is there to be spent to get around it. I know it took a few months before the latest GM vette stuff was unlocked.
This post has been edited by czwalga: Jan 10, 2012 - 7:10 PM
-10 F150
Lo-Fi Version Time is now: November 23rd, 2024 - 9:08 AM
