> 5S-FE Turbo project, Would like comments/critique
post Jan 12, 2012 - 2:38 AM
Syaoran
Joined Jan 4, '12
From US
Hello, this would be my first elaborate post on here and I thought I'd get some feedback from you, the more experienced people.
I would like to know what your opinion on my idea for a boost build would be.
First off, I'm not going to use a CT-26. I would really like to, but the reason is that the ones I've found, that are NOT supra CT-26, are either in need of a rebuild or way too expensive for a small, old turbocharger, that isn't even a ball bearing to justify the price. That is my take on the CT-26. The CT-20b is way too rare, and expensive to rebuild in case I were to find one.
That leaves me with brand new eBay turbochargers. I have first-hand experience eBay turbochargers and I can say that some sellers do sell decent stuff. Ilovetacotaco sells some good turbo chargers.
My main question in relation to this topic is whether I should get a .50/.63 or .60/.63 turbo, considering I'll be using MegaSquirt-II or MS-III, undecided yet (have a friend that's been using them for more than 10 years now, he knows these EMS)
I plan on getting a cast T3 manifold with external wastegate. I'm looking to obtain above 250whp. I believe I should run relatively large injectors, right? Something like 460cc or more? Should I look into forged pistons and rods or should I just keep stock internals until I decide to go more boost?
My budget is about $2700, and this is what I've broken it down to.
1. Cast iron manifold $200 (add $50 for inside-out ceramic coating from a friend who does that)
2. Turbocharger ($150-$300)
3. Wastegate + BOV ($100)
4. Lines, flanges and welding work ($300)
5. TMIC or FMIC (~$300)
6. Pipes/t-clamps/silicone joints ($100)
7. MS-II ($400) / MS-III ($600)
8. 460cc RX-7 Injectors ($100)
9. Fuel Pump + Regulator ($200 if needed in the first place)
10. Gauges (Wideband, Boost, Oil Press. / $350-400)
Total: $2600
I know it'll be more expensive. I'm just wondering if I'd be able to get some things cheaper. I KNOW cheap/fast/reliable, but there's a fine line between what's considered "cheap" and just shelling out money for overpriced stuff.
I know I can rely on some eBay stuff. Most of the time cheap knockoffs are just as good as the originals, as most companies sell you something cheap for a lot of money because their brand name is on it.
Should I do TMIC or go for FMIC? I've already got the All-Trac hood, so I can fit a nice, small FMIC as a TMIC. I'd rather have a more simple setup, boosting 10-12psi. The less lines/pipes/etc, the better.
1993 Celica GT Coupe - sold
1994 Celica GT Liftback
post Jan 12, 2012 - 12:02 PM
thatmr2
Joined Aug 4, '10
From Massachusetts
I say save the trouble and just go with a GT4 clip and go 3SGTE!
post Jan 12, 2012 - 2:08 PM
dakotahwyatt
Joined Jan 2, '12
From pickerington ohio
QUOTE (thatmr2 @ Jan 12, 2012 - 1:02 PM) *
I'm not him but to that's what everyone is doing so I say go for it bro
post Jan 12, 2012 - 3:30 PM
PolliS_5S-FE
Joined Aug 29, '08
From Auckland, New Zealand
sick of hearing the 'just go 3sgte' yeah yeah i know its a good motor but cmon, if he wanted to he'd make a post about yet another swap. go 5sfte ftw
post Jan 12, 2012 - 4:08 PM
dakotahwyatt
Joined Jan 2, '12
QUOTE (PolliS_5S-FE @ Jan 12, 2012 - 3:30 PM) *
^^ I'm with that guy on this one
post Jan 12, 2012 - 5:29 PM
rave2n
Joined May 29, '09
From Gainesville, FL
For his budget, he cannot go 3sgte.
Though I have no knowledge of this build, It appears you are in the right direction.
post Jan 12, 2012 - 7:48 PM
PolliS_5S-FE
Joined Aug 29, '08
you will need 3sgte oil pan too unless you weld the 5s, I believe you will also need to relocate the oil filter
i much prefer the look of front mount but thats just me.
post Jan 13, 2012 - 5:44 PM
Syaoran
Joined Jan 4, '12
From US
Not to sound rude but first off I dont want to be another swapped celica. I like the torquey 5s vs the slow-without-boost 3s.
Second, its not like 3s engines rain from the sky. Hell, BEAMS 3s is less rare than a turbo one, and on top of that it can be obtained brand new for the same or less as a swap.
That said, anything a 3s can handle, a 5s can handle better, especially with 3s rods and pistons. It also spools any turbo faster, so you can use a bigger turbo than in a 3s with no addition to turbo lag.
That said, thanks for your replies guys! Somebody said something about a 3s oil pan, well I was just going to get a spare 5s pan from a friend threaded for the return line and using the oil press. sensor hole to put in a T-split for oil feed.
Any more input will be appreciated.
I was thinking maybe somebody would throw some warnings about potentially plugged holes like vacuums that wont do harm n/a but will do harm f/i.
i had a friend do his 5sfte build recently and he flooded his distributor with oil because a seal blew from having a couple vacuums wrongly rerouted from his last owner. he rerouted those vacuums properly after a friend of his who deals with MR2s told him some tips.
post Jan 13, 2012 - 10:13 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
QUOTE (PolliS_5S-FE @ Jan 12, 2012 - 4:48 PM) *
nope, left mine in the stock location.
for 2700 you can drop in a 1MZ-FE and have just as much power NA. did you find my thread on 5S turbo kits i make? you do NOT want an ebay turbo, they are chinese crap! you want a good garrett or turbonetics turbo. your budget kit that you pieced together will cost you way more in the long run.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Jan 14, 2012 - 8:44 PM
Syaoran
Joined Jan 4, '12
From US
QUOTE (Smaay @ Jan 13, 2012 - 11:13 PM) *
It's not really as easy as it sounds. A swap takes more knowledge, time, budget and tools than a turbo, and I'm aware of that. Also, finding a good 1MZ that doesn't need a rebuild/refresh is kinda hard in Puerto Rico. If you do find one, it's probably already sold or waaaaay too expensive.
I'm also pretty set on going turbo, as you can see.
Any specific turbo you'd suggest? I want something without an internal wastegate.
post Jan 14, 2012 - 9:24 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
well you have US listed as location, you didnt say PR. and a turbo small enough without an internal gate is hard to find. you could go with a GT28RS but its still internally gated.
a 1MZ i think will still be a cheaper solution. did you find my thread on kits
This post has been edited by Smaay: Jan 14, 2012 - 9:26 PM
post Jan 14, 2012 - 10:42 PM
Syaoran
Joined Jan 4, '12
From US
I saw your kits. The only thing I could use is the manifold and the turbo. All piping is different. I own a 5th gen GT, not a 6thgen, and I'm looking to do a TMIC setup to make use of my all-trac hood as well smile.gif
post Jan 15, 2012 - 12:38 AM
UndecidedPC9397
Joined Dec 15, '11
From minnesota
Thank god more people are coming out with these 5s-fte threads!!!
post Jan 15, 2012 - 12:57 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
then just use the stock 3S-GTE setup. but i can tell you this. a FMIC is WAY more efficient. any TMIC will heat soak really fast. i have a few TMIC from a ST185 if you need one. i also have a turbo manifold and a good condition CT26 that I used on my first 5S-FTE setup
post Jan 15, 2012 - 4:57 PM
Syaoran
Joined Jan 4, '12
From US
QUOTE (Smaay @ Jan 15, 2012 - 1:57 AM) *
It was my initial idea. FMIC is way more efficient but more PSI is lost as well. It's a win/loss situation, in which it's only good once you go past a certain limit.
If you could send pictures my way it'd be nice... it's always good to have more options.
post Jan 15, 2012 - 8:18 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
there is no PSI lost with a FMIC, only a tad more lag because its a larger system. you dont know alot about turbo systems do you? i suggest you do alot more research. anyone can make a shopping list but you dont understand how each system works.
why do you think you need an external wastegate?
post Jan 28, 2012 - 12:33 AM
Syaoran
Joined Jan 4, '12
From US
Update: bought an OEM manifold, cleaned up, opened up a bit and ceramic coated good for up to 1600 degrees F... nice black finish.
post Jan 28, 2012 - 12:57 AM
JasonTX
Joined Mar 1, '10
From TX
QUOTE (Syaoran @ Jan 28, 2012 - 1:33 AM) *
just curious why you wouldent want an internally gated turbo? i found with my ct26 the wastegate regulated the pressure pretty precisely.
just tring to give you another perspective
you could avoid having to purchase an extra piece of equipment.
you can always wedge the actuater arm closed so the internal wategate never opens (or wield the gate closed) then add an external later if the internal wont suite your needs
you may find with your desired psi/driving style a supper precise wastegate may not be necessary
in any case, good luck on the build and please keep us posted on the progress
peace
-jec
This post has been edited by JasonTX: Jan 28, 2012 - 1:00 AM
JN 3:16
post Jan 28, 2012 - 10:41 PM
Syaoran
Joined Jan 4, '12
From US
Hey thanks for the comments.
When it comes to the turbo part of the build, I'd rather have separate serviceable "chunks" than All-in-One stuff because, for example, if the wastegate for one reason or the other goes bad, then I'd have to fix/seal the wastegate and turbo as a whole, or get a new turbo. If I get a turbo with no IWG and the external gate goes bad, I can rebuild/replace the gate and be done with it.
I was looking into a CT-26, but there's a couple of reasons holding me back from pulling the trigger on one. For starters it's an older turbocharger. Most of the time you'll find one with 150k miles or more on it. Second, it's a bit more complex to run because of an added line for coolant (which is worth it in the end because it helps prolong turbo life, but it makes the setup less neat).
Performance-wise, I feel the CT-26 is too little for the extra .2L displacement of the 5s-fe. I could get a marginally bigger turbo and have just as fast spool as a 3s-gte with a CT-26, all with a bit more power at the same PSI level. I also have the benefit of having a brand new turbo/less beat-up turbo vs a 16-20 year old turbo.
Nothing is written in stone yet so things might change from here to there. smile.gif
post Feb 3, 2012 - 12:23 PM
Your on the right track, don't bother with the ct-26.
Above 270whp, the tune is gonna be critical. One good hiccup, and kiss the stock ringlands goodbye.
For 300+whp, I would definetly do forged pistons, the rods are not weak, but the rod bolts are known to strech in Tue older 5th gen motors.
If I were building another 5sfte today, I would do it one of 2 ways.
For sub 300whp, I would grab a 20b, run 16-17psi with water injection with a stock unopened motor, with the emanage ultimate, or ms, and tune it myself.
For above that, I would drop in a set of stock sized forgies get cams and have an intake manifold made,, spend all my money on an ems and tuning, and run a gt3071 or somthing similar.
Lo-Fi Version Time is now: November 26th, 2024 - 12:11 AM
