14 Pages V  « < 5 6 7 8 9 > »
> Rave's Next Progression Thread, 95 GT Red
post Apr 17, 2013 - 7:03 AM
Dennisthe10
Joined Oct 30, '12
From Cheshire
love the work you have done and love how far you have come, I'm pretty sure you have confirmed that matt black is the way to go with mine too, cant wait for more pics smile.gif
Well done with the work so far, loving this
post Jan 12, 2014 - 4:52 PM
rave2n
Joined May 29, '09
From Gainesville, FL
Its been a while, but I believe I can move forward from here. Have had to help the family 3 times in the last year financially, which each time was my car funds =/ - New year, new attitude, funds still the same, but w/e...I'll lose more, the longer I wait. Dat gotta pay to play =P
Sent funds for a re-surfaced flywheel today to get the 3sgte swap moving along, and I expect to find a down pipe to purchase within the next few days. Will patch the short section after down section until I can get it to a shop to close up, clamp style. That completes all the mechanical items besides a few odds and ends like a rubber line for the walbro, and the etc of vac lines, little local items..hopefully.
The final, and most daunting task. The wiring.
I keep seeing, its 6 wires. So, that has to wait til I actually start the swap, and since, from what I understand you do not need to extend the harness for the ECU, that leaves making the looms for the relays. Hope to begin that task in the next week.
I want to finish this swap in the next 3 months. Will be taking some time off work, do it now before it isn't capable of making it.
Today I did some work on the 3sgte, mostly going back over what I've already done, because I had some doubts.
I removed both oil pans from the bottom end, and inspected some items. The strainer and arm are in good condition, but to be honest, I hate to admit it, but I snapped a bolt head when putting the oil pump back in. I wanted to ignore it and put some fipg around it and move on, but i decided to just rip it all apart again and do it right.
So, pulling the oil pump back out later in the week, getting that bolt out, cleaning all the edges and re-sealing it again. Glad I did, I didn't obstruct the oil channels on the pump, but the little O-ring looked outa place to me. Wasn't sure, so better safe then sorry, and now I won't wonder if its right and tight.
Left over issues with the GT that have to wait til after swap:
Both Front Bearings & Wheel Hubs - Both making noise, hubs shot, bearing lasted 7 months.
Rear Pads, Rear passenger Caliper, Both Rear rotors turned.
Check Heatercore leak
Remove replace rear atenna
Replace both front quarter panels
95+ Front Bumper & New front splits.
New Tires!!
Think that its folks...Got my work cut out for me, but time to get back on task.
Excuse my book, I post to motivate myself, and information retention =)
post Jan 12, 2014 - 7:42 PM
enderswift
Joined Jul 12, '08
Dude, call up the vendor that is supplying your clutch and ask them what step size they require for their kits. Then call your machine shop and make absolutely sure they machine that step. Otherwise you'll be screwed like I was
post Jan 13, 2014 - 10:16 AM
rave2n
Joined May 29, '09
QUOTE (enderswift @ Jan 12, 2014 - 7:42 PM) *
Ugh, I already got my kit from Southbend or something like that.
I didn't get anything crazy, just the OEM disc one.
post Jan 13, 2014 - 12:03 PM
I lost your number but you can shoot me a PM if you find yourself in need of an extra hand. Good luck, good sir.
post Jan 16, 2014 - 10:33 AM
rave2n
Joined May 29, '09
QUOTE (SwissFerdi @ Jan 13, 2014 - 1:03 PM) *
Will do! As always its appreciated
Looks like the fun is about to begin!
Thankfully its going to be nice and cold in FL for a few days, so no flying blood suckers to deal with, just work work work.
post Jan 18, 2014 - 12:31 PM
rave2n
Joined May 29, '09
Some items arrived
Not extremely happy with the welds on the downpipe, but you get what you pay for, so as a temp solution, it will serve the purpose.
Also began cleaning the oil pans off of the gaskets. Using some roloc, goes pretty quick, just gota dig out the runs, and general cleaning. Hope to have the bottom end put back together by Monday, and some other loose ends with it.
post Jan 18, 2014 - 1:55 PM
I hope this will be running in a few months, I'd like a ride.
post Jan 19, 2014 - 7:35 PM
rave2n
Joined May 29, '09
Getting all the pieces of the puzzle put together. Per usual, I should have got the clip wink.gif
From the ECU to the Walbro is nearly everything there, except maybe some flywheel bolts, and all the home made wiring required. Inventory it all, and make a plan. Moving along.
Oh yea, and a tabby for scale.
This post has been edited by rave2n: Jan 19, 2014 - 7:37 PM
post Jan 20, 2014 - 5:33 PM
rave2n
Joined May 29, '09
Had to fix this....
Required all this, but I'm glad I did. I found other mistakes, and poor work of my own.
So what took me days before, just took me a couple hours this afternoon, which was quite nice.
Finish up the pans, slap them on, and to the pile of junk I posted prior to this one.
post Jan 27, 2014 - 8:38 AM
rave2n
Joined May 29, '09
Some more work over the weekend
Cleaned oil pan #1 - Again..
back on the block..
I think I sealed it much better this time. Last time I just spread the FIPG all over the surface, which was very unpleasant to clean, and I was afraid I used quite to much the first time. I did...This is much better =)
In other news, I just got promoted at work, so substantial raise but with quite the increase in responsibility. So just going to keep moving forward and try to get this done, possibly easier now that funds will align better.
post Jan 27, 2014 - 10:27 AM
cheela
Joined Feb 2, '07
From Berlin, WI
good stuff! congrats on the promotion. more money for more racecar parts!!! biggrin.gif
post Jan 30, 2014 - 12:27 PM
rave2n
Joined May 29, '09
QUOTE (cheela @ Jan 27, 2014 - 11:27 AM) *
Haha thanks! Yea its good news..and it just got even sweeter.
Since my work requires me to occasionally go out to transmitter sites that lack proper roads, and me now being the primary contact for outages, work is now pre-taxing an allowance to my pay monthly to acquire a vehicle that can traverse such conditions.
So, I can finally park the Celica without being worried about time and getting to work the next day.
So in a couple weeks, buy a vehicle, and get the 5sfe out of the bay, and start the cleaning and wiring!
post Feb 2, 2014 - 6:14 PM
rave2n
Joined May 29, '09
2nd oil pan installed today.
Nothing picture worthy.
Timing next.
post Apr 19, 2014 - 3:11 PM
rave2n
Joined May 29, '09
Back to work!!
Prepping for engine pull... Hood outta there...
Hour or so later..no bumper fenders, plastics. Found lots of missing hardware. Still need new fenders, will have to replace hardware then.
Progress is progress wink.gif - Start pulling the accessories next weekend, then the motor the next. Heres hoping.
Annd, I had to take the boom from the Celica. The jeep is way to loud of a vehicle being lifted and all....so I need to transfer my audio.
New head unit to go with the boom.
http://www.crutchfield.com/p_130X8500BH/Pi...BH.html?tp=5684
Which eventually will go into the Celica when its drivable and legal again.
post Apr 20, 2014 - 12:56 PM
rave2n
Joined May 29, '09
Slowly...but its happening...
post Apr 21, 2014 - 10:02 PM
enderswift
Joined Jul 12, '08
Beast it
This post has been edited by enderswift: Apr 21, 2014 - 10:04 PM
post Apr 22, 2014 - 7:13 AM
rave2n
Joined May 29, '09
QUOTE (enderswift @ Apr 21, 2014 - 11:02 PM) *
Beast it
Haha felt good ripping all that off. Alot of just nasty going on in that bay.
I want it sparkling before I drop the new engine.
Trying to dedicate an hour a day at least. Missed yesterday, but today is a new day.
post Apr 26, 2014 - 10:40 AM
rave2n
Joined May 29, '09
And a little more today...
post Apr 26, 2014 - 7:51 PM
PR0PH37
Joined May 29, '09
From Burlington, NC
Sweet. Love your "organized confusion"! Lol
wow . teespring.com/savethemanual
Lo-Fi Version Time is now: November 26th, 2024 - 12:43 AM
