Rave's Next Progression Thread, 95 GT Red |
Jul 3, 2012 - 2:04 PM |
'93 MX-5 LE |
Jul 4, 2012 - 1:01 PM |
Loading up. Only got it about 10 feet in the yard before nearly having a heatstroke. Need to acquire some more wood as well, or I'll never get it to the back. Damn thing is heavier then I remember. One step at a time. Looks like poo atm, but I see a diamond that just needs some polished. |
Jul 7, 2012 - 1:41 PM |
Got the engine behind the house, now to take the AWD trannie off, and start removing accessories.
Pictures later...if I get that far this evening =P |
Jul 8, 2012 - 9:00 AM |
And, did you?
'93 MX-5 LE |
Jul 8, 2012 - 11:06 AM |
And, did you? Lol yea, I got the transmission off this morning after quitting when it got dark last night. Just put my engine stand together, and need to run to the store to get bolts long enough to bolt it into the block because the trannie bolts are not long enough. not really sure of the threads, so its going to be a couple different size purchases. |
Jul 8, 2012 - 11:08 AM |
'93 MX-5 LE |
Jul 8, 2012 - 1:22 PM |
Bah, home depot did not carry the bolts, and all the fastener stores are closed =/
So i will have to start back up next weekend once I get the right bolts this week. Some pictures of today progress. I got alot of clean up to do |
Jul 8, 2012 - 7:54 PM |
Enthusiast Joined Jul 12, '08 Currently Offline Reputation: 5 (100%) |
ah yes the bolts. I ran into the same problem lol. Try Ace hardware if there's one local to you, they always have everything I need. How was the transmission removal for you? Because I had a rough time due to a hidden bolt behind the center diff haha
Jul 9, 2012 - 7:59 AM |
ah yes the bolts. I ran into the same problem lol. Try Ace hardware if there's one local to you, they always have everything I need. How was the transmission removal for you? Because I had a rough time due to a hidden bolt behind the center diff haha Hmm, wondering if there is an Ace around here, havn't been to one of those since I lived in PA, and was quite some time ago. Will check though, thanks! Yea I know exactly which bolt you are talking about, 14mm head, hidden under there. No enough clearance for a socket, so had to wrench it out, 1/2 inch turns each time in 99+ temps. People around probally heard a large percentage of my vulgarities. It was a PITA to get her off, took me a good 1 1/2 hours once I took the rear brackets off. It was mainly because I trying not to wreck the spline, so finding the right angle and just finally muscling it off. She is heavy! This post has been edited by rave2n: Jul 9, 2012 - 8:00 AM |
Jul 9, 2012 - 4:00 PM |
Win! Felt a little bad for the shop owner, you could tell the big box has hurt business, as the shelves were barely stocked, and he had what I needed whereas home depot did not...I shall try to bring as much business as i can his way. He knew his stuff too, once i said it was for an engine stand. He said "must be a Jap engine" lol. This post has been edited by rave2n: Jul 9, 2012 - 4:03 PM |
Jul 12, 2012 - 10:28 AM |
Want to update you folks, but these flywheel bolts are going to be the end of me.
I've wedged the flywheel to stop it from moving, but it appears I'm going to need one hell of a steel pipe to add some leverage to break these loose. Taken a flywheel off or two, but never had this much issue. They aren't reverse threaded are they? Just curious before I start cranking on them. This post has been edited by rave2n: Jul 12, 2012 - 10:28 AM |
Jul 12, 2012 - 3:33 PM |
Buy an impact wrench and a compressor. Trust me, its gonna come in handy many times after the flywheel bolts
Jul 13, 2012 - 3:40 PM |
Buy an impact wrench and a compressor. Trust me, its gonna come in handy many times after the flywheel bolts I bet! I have a nice compressor, but it got knocked over and busted the valve. In the process of sourcing a replacement. This did the trick for now. Yes that is a closet pole to hang clothing on =P Got this far before I got tired of being soaked (Working in the rain =/ tired of excuses ) and donating blood to the flying blood suckers. Noob question of the week, does that look like the got the angles okay for the stand mount before I tighten it up? figured best to ask, then have it fall over and be pissed I didn't take a second to make sure. This post has been edited by rave2n: Jul 13, 2012 - 3:41 PM |
Jul 13, 2012 - 3:53 PM |
Enthusiast Joined Jan 20, '09 From Winnipeg Currently Offline Reputation: 5 (100%) |
Yes that is a closet pole to hang clothing on =P Nothing wrong with that, Helped me get my strut bolts off too -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Jul 13, 2012 - 6:55 PM |
I know some of these updates may seem pointless and mundane, but each step for me is quite the exp. and learning as I go. So stick with me, the interesting shiz will come soon enough.
Was quite interesting getting over that step. Finally got her where I needed it, so I have light to work on it, and a covered area. Time to buckle down and get it torn apart read to accept new parts.. This post has been edited by rave2n: Jul 13, 2012 - 7:20 PM |
Jul 15, 2012 - 12:49 PM |
Enthusiast Joined Oct 20, '08 From Seattle, WA Currently Offline Reputation: 5 (100%) |
Yeah dude, getting the AWD tranny off while on the hoist and then getting the motor away from the tranny onto the stand is a fukking process, haha. Damn hoist legs don't "spread" enough, lol.
My buddy has a snap on battery powered impact wrench that got my flywheels bolts off in an accumulated like 30 seconds! Such a handy tool.. Looking good man, keep it up! -------------------- 2006 BMW 330i - 6 Speed - Dinan Stage 1
2014 Toyota Rav4 XLE |
Jul 15, 2012 - 3:02 PM |
Got a little work done on the 3s. Just tearing things off. Not much due to camping but I'm sure I'll get a bit more done over the week.
Anyone know if the distributor cap is interchangeable from one from a MR2 3s? Mine was a bit worn and busted when I was taking the ignitor coil off. Will need the wire tool. I believe they are, just making sure before I purchase. This post has been edited by rave2n: Jul 15, 2012 - 3:08 PM |
Jul 15, 2012 - 4:47 PM |
Enthusiast Joined Apr 20, '06 From Florida Currently Offline Reputation: 44 (100%) |
looking good, keep up the progress
ps: I think the dist cap is the same, but double check with another user before getting one |
Jul 16, 2012 - 5:37 PM |
Well, got the OEM downpipe off, and a few other tidbits.
Went to the other side to take the crankpully off, so I can remove the lower cover. No dice. have a universal pulley holder on the way to assist with its removal. Should be here Wednesday. 52 smackers. OTC 4754 Universal Pulley Holder This post has been edited by rave2n: Jul 16, 2012 - 5:38 PM |
Jul 17, 2012 - 5:50 AM |
Enthusiast Joined Jan 12, '09 From Poland,Europe Currently Offline Reputation: 0 (0%) |
U're doing very well man, nice thread.Good luck with your plans and i'll be watching.
This post has been edited by Sebby: Jul 17, 2012 - 5:52 AM -------------------- |
Lo-Fi Version | Time is now: November 22nd, 2024 - 11:05 AM |
