> Help please ripping my hair out
post Jan 13, 2012 - 6:04 AM
aqua1996
Joined Jun 8, '07
From Darwin, NT Australia
Hey all
I just came in from under the car and im about to kill some one.
Im doing my front and rear engine mounts. Now this seems like a simple task as ive done it before on other cars. now the problem is.
Jacked car up and on stands, Cross member bolts are out and front engine mount off.
My problem is with the rear mount. all the bolts are out and both the mount and crossmember are free but stuck and wont come out.
ive jacked engine up and down but cant get it out. the problem is there is not enough room to get the mount out.
anyone done this recently that might be able to shed light on my problem.
Thanks in advance\
Bevan
post Jan 13, 2012 - 6:42 AM
rave2n
Joined May 29, '09
From Gainesville, FL
Remove the mount from the block, not the crossmember. Should be 2 bolts holding her in. Otherwise you'll never get that crossmember out.
I did the same thing on my 7a, I was screaming and cursing for over an hour. Then we went back and read the directions step by step, and it was quite specific about removing from the block for this exact reason. We could move the crossmember around all we wanted, just there was no angle to take it out.
This post has been edited by rave2n: Jan 13, 2012 - 6:43 AM
post Jan 13, 2012 - 6:51 AM
aqua1996
Joined Jun 8, '07
cheers ill try that there is **** all room to get at the second bolt. im gonna get back to it first thing in the morning. ill let ya know how i go
post Jan 13, 2012 - 6:55 AM
richee3
Joined Jun 29, '08
From Denver
Pretty sure you'll need ratchet or end wrenched to remove it from the block. I don't think I could get my 3/8 ratchet to the bottom bolt on the block.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Jan 13, 2012 - 6:58 AM
aqua1996
Joined Jun 8, '07
yeah even with the the mount loose im not getting a ratchet in there. im thinking a 14 mm ring spanner might be the only way
post Jan 13, 2012 - 7:31 AM
rave2n
Joined May 29, '09
Yea I had to use a deepwell socket to get it out, I believe I ended up kneeling on the valve cover to get it done too.
If I remember correctly that is the reason I didn't try to get it otu of the block first because it was such poor spot, but the end result was I had to get that bolt, to get her out.
This post has been edited by rave2n: Jan 13, 2012 - 7:33 AM
post Jan 13, 2012 - 9:15 AM
dakotahwyatt
Joined Jan 2, '12
From pickerington ohio
QUOTE (aqua1996 @ Jan 13, 2012 - 6:51 AM) *
Rotate the motor push on it to the front of the car
post Jan 13, 2012 - 6:08 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
I feel your pain its quite tricky. You'll have to mess with it for a while good luck.... I think it took me over an hour to get the rear one on (since it was my first time). takes 15 min breaks in between to clear your head.
post Jan 16, 2012 - 7:22 AM
rave2n
Joined May 29, '09
Just a tip, if you havn't got her out yet.
Lower the suspension crossmember after you remove the center bolt from the mount. Sorry for the earlier bad advice, was just the only way I've done it before.
Just did it yesterday by lowering the whole suspension crossmember...so easy to get out after that.
post Jan 16, 2012 - 12:34 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
have you tried squirting some dish soap on there to make it easier to slip the mounts on
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Jan 17, 2012 - 1:12 PM
rave2n
Joined May 29, '09
QUOTE (Smaay @ Jan 16, 2012 - 12:34 PM) *
laugh.gif Havn't heard that trick. Just battled with my rear mount yesterday, the biggest issue was the steering rack getting in the way. I literally just dropped the whole suspension crossmember and supported with a jack, and it went right in without lifting or rotating the engine.
post Jan 17, 2012 - 1:28 PM
use a torch, it will come out.
balance the engine front and back, It requires art.
post Jan 18, 2012 - 4:44 AM
aqua1996
Joined Jun 8, '07
got it out after your sugestions just took front and trans side mounts off motor moved forward then I lifted it up and with a bit of manipulation came out. going back in took some time and swear words but they are all in 4x engine mounts replaced. cheers for the help guys you rock
Lo-Fi Version Time is now: November 22nd, 2024 - 1:37 PM
