> manifold lock-bolt, how does it work
post Jan 15, 2012 - 5:20 AM
skogs
Joined Apr 19, '08
From Norway
There is some kind of a locking bolt that bolts the exhaust on to the header. It looks like a regular 14mm pipe but with a 7mm bolt inside of it. Does anyone know how to loosen this bolt? Do i loosen the 7mm first, or will i just break it then? I cant reach the 14mm with a regular socket wrench because of the 7mm. Do i need a spesial tool?
post Jan 15, 2012 - 5:21 AM
Bitter
Joined Mar 11, '06
From Way South Chicago
Photos?
post Jan 15, 2012 - 8:02 AM
skogs
Joined Apr 19, '08
From Norway
I was hoping to not use the camera under there, but ok, i will take a pic.
post Jan 15, 2012 - 9:06 AM
skogs
Joined Apr 19, '08
From Norway
The pics are here:
http://www.bilforumet.no/andre_forum/tekni...tml#post2879357
post Jan 15, 2012 - 9:21 AM
Neon90424
Joined Jan 19, '11
that looks awful..long tube ratchet maybe?
post Jan 15, 2012 - 10:03 AM
richee3
Joined Jun 29, '08
From Denver
That's not a lock bolt, that's just the exhaust stud. Lube the 14 mm nut up so it'll break free easier and get at it with a deep well socket and it'll come right off, leaving the exhaust stud in place. But be careful, because the nut is soft aluminum and will round off very easily.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Jan 15, 2012 - 11:08 AM
RocketScott
Joined Nov 21, '05
From Tacoma, WA
That nut is not aluminum.
post Jan 15, 2012 - 2:46 PM
Bitter
Joined Mar 11, '06
they're stainless steel, but get softened over time. heat them with a torch and they'll come off way easier.
post Jan 15, 2012 - 3:14 PM
mkernz22
Joined May 10, '10
From MA
get some PB Blaster and soak it, then let it sit for a bit
post Jan 15, 2012 - 6:51 PM
mandrek
Joined May 4, '05
From western MD/NOVA
sea foam's deep creep ftmfw!
post Jan 15, 2012 - 8:11 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
yeah the studs have a hex head on them just to help put them in place. all you need is a 14MM deep socket . sometime the stud comes off with the nut. when that happens i usually just replace both
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
Lo-Fi Version Time is now: December 1st, 2024 - 8:13 PM
