> Coolant Leak, Loosing coolant from cold engine.
post Jan 16, 2012 - 8:59 AM
jackkasper
Joined Dec 16, '10
From grand prairie, tx
Coolant LeakI have coolant leaking from either the thermostat housing or the metal tubing (?) that joins the engine block at about the same location. I have tightned all the bolts and the coolant leak has gone from a drip to a massive loss of coolant. This doesn't appear to happen when the engine is warm but rather when the car is sitting in the driveway.
Has anyone encountered this before and what is the solution?
http://s1134.photobucket.com/albums/m608/F...nt=IMAG0278.jpg
post Jan 16, 2012 - 9:51 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
the gasket that goes around the thermostat might have failed. take the metal pipe off and check it out
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Jan 16, 2012 - 11:24 AM
jackkasper
Joined Dec 16, '10
The gasket for the water by-pass pipe has failed. Is there any way to change that without removing the water pump?
Lo-Fi Version Time is now: November 26th, 2024 - 9:33 PM
