> Engine Problems, P1300
post Jan 17, 2012 - 8:21 PM
white_light808
Joined Jun 20, '10
From Hawaii
Hey guys,
I have a 96 5SFE Manual Celica and Ive had this problem for the past couple months, its a P1300 engine code, ive replaced the ignition coil, and everything checked out ok, and my guess is the ecu
but this is the problem, it runs ok in gear, only when i come to a stop/idle it dies and it doesnt happen all the time, and the engine light comes on when the car dies in idle
any ideas?
post Jan 18, 2012 - 12:55 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
change you're whole distributor, just changing the coil sometime wont fix the problem. Too bad you have an OBDII, I got a spare ECU I wouldn't mind driving out to help you. Could be your Ignition Module on the firewall side, that I have an extra also. Should be the same all through the years.
post Jan 18, 2012 - 8:45 AM
Bitter
Joined Mar 11, '06
From Way South Chicago
Igniter?
post Aug 3, 2012 - 6:58 PM
white_light808
Joined Jun 20, '10
From Hawaii
oh, update
post Aug 3, 2012 - 11:33 PM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
QUOTE (white_light808 @ Aug 3, 2012 - 7:58 PM) *
oh, update
Was just about to tell you to try replacing them. Lol.
Lo-Fi Version Time is now: November 30th, 2024 - 1:55 AM
