Is it possible!! |
Is it possible!! |
Jan 18, 2012 - 12:35 PM |
Enthusiast Joined Jan 16, '12 From arkansas Currently Offline Reputation: 0 (0%) |
Got a question does anyone know if ist possible to replace the front end of a 98 celica with the front end of a supra! i like the celica except for the circular head lights and i was just wondering if its possible to replace the fenders and front bumper cover etc to a supra front end! thanks guys
Jan 18, 2012 - 12:58 PM |
Jan 18, 2012 - 1:51 PM |
Is it possible? Yes. Is it feasible? Not really. It'll be fully custom fabricated and will be a nightmare to do yourself unless you've done similar conversions. A shop will charge you an arm, both legs, and your firstborn child. Playr158 did the conversion once and his advice is to drop the car off at a shop, cut a huge check, and pick it up later.
The Supra is a larger car than a Celica so in my opinion, the conversion doesn't look good anyway. -------------------- "Employ your time in improving yourself by other men's writings, so that you shall gain easily what others labored hard for." -Socrates. Even Socrates told us to use the search button!
Jan 18, 2012 - 2:25 PM |
It can be done but takes alot of custom work
look into a curren front end. Its mostly a straight swap an itll get rid of the the factory lights But parts are harder to find -------------------- 95 gt coupe, v6 swap weekend toy
Jan 18, 2012 - 2:27 PM |
Enthusiast Joined Feb 2, '07 From Berlin, WI Currently Offline Reputation: 18 (100%) |
curren swap on a cell looks better than a supra swap on one.
-------------------- *1997 Celica ST - 3SGE Greytop BEAMS *1977 Celica RA29 - Classic Cruiser *2005 Matrix AWD - dedded but still hanging around like a ghost 2019 Rav4 XLE Premium - Sports mode is fun. |
Jan 18, 2012 - 2:28 PM |
It can be done but takes alot of custom work look into a curren front end. Its mostly a straight swap an itll get rid of the the factory lights But parts are harder to find I've done both. Supra parts are much wider (6") and longer. so its all custom and requires lots of work...take it to a professional, cut a check. Curren requires rare OEM parts, you have to (like the supra) cut out the radiator core supports and swap them and then it all bolts together, so its much simplier than surpa. also use the search button. |
Jan 18, 2012 - 7:47 PM |
thanks guys I may just.end up buying both I found a supra for 6000 its got water damage but I can restore it
Jan 18, 2012 - 8:42 PM |
Do it! If you don't, I will. I'm dead serious.
Lo-Fi Version | Time is now: December 4th, 2024 - 9:07 AM |
