NASTY MISFIRE NEED HELP BAD! |
Jan 18, 2012 - 12:54 PM |
Enthusiast Joined Sep 27, '10 From Laredo Currently Offline Reputation: 0 (0%) |
So I have this nasty misfire, i started with the spark plugs and still the car had a little stuttering to it on the accelaration, and after a while when i would make stops, it would stuttered bad to a point where it looked liked it would turn off but it wouldnt, yesterday i changed the coil and wow now it jukes like crazy when im on the express way its jukes nasty to the point that you can get whiplash, if anyone has had this problem can you please help, its ****ing annoying
Thanks |
Jan 18, 2012 - 1:30 PM |
Enthusiast Joined Apr 7, '04 From Toronto Currently Offline Reputation: 3 (100%) |
Try changing your spark plug wires.
Jan 18, 2012 - 1:53 PM |
Any other suggestions besides that?
Jan 18, 2012 - 2:08 PM |
Check your timing?
Jan 18, 2012 - 2:44 PM |
Enthusiast Joined Jul 14, '08 From St. Louis Currently Offline Reputation: 2 (100%) |
change your cap / rotor?
-------------------- '99 Celica GT - Sold
'11 Mazdaspeed3 |
Jan 18, 2012 - 3:36 PM |
check your MAP sensor, see if its plugged in
Jan 18, 2012 - 3:41 PM |
where is the MAP sensor located?
This post has been edited by justin3: Jan 18, 2012 - 3:41 PM |
Jan 18, 2012 - 4:04 PM |
what coil did you change ?
Jan 18, 2012 - 4:08 PM |
the one thats inside the cap
Jan 18, 2012 - 5:07 PM |
Enthusiast Joined Jan 19, '11 From Paraguay, Winchestertonfieldville Currently Offline Reputation: 1 (100%) |
my st205 would give big whiplash stuttering and massive fireballs because of spark plug wires grounding on the valve cover...check your cables
Jan 18, 2012 - 5:17 PM |
check what cables, the spark plug wires you mean?
Jan 18, 2012 - 5:21 PM |
Enthusiast Joined May 31, '11 From Rochester, NY Currently Offline Reputation: 5 (100%) |
You may be getting proper spark, just not enough air or fuel. Did you get bad gas? Are your injectors clogged? When is the last time you changed your air filter, fuel filter, and cleaned out your throttlebody? Misfires aren't always in relation to spark... there are three parts to a fire. Air, fuel, and ignition... with out one of these parts, you don't have combustion.
-------------------- 1994 Toyota Celica GT-S 5S-FE 190k Miles. Project car 1992 Toyota Celica GT 5S-FE 170k Miles. Daily driver/beater 1999 Toyota Camry LE 5S-FE 216K Miles. RIP You will be missed. *ASE Certified General Manager |
Jan 18, 2012 - 5:26 PM |
yeah spark plug wires....you can always empty a bottle of carb cleaner into the intake see if it clears something up sometimes i hear its not a good idea tho...the engine should drown out if you spray too much of it at low revs...
if its the spark plug wires you should be able to hear them clicking when the spark misses This post has been edited by Neon90424: Jan 18, 2012 - 5:27 PM -------------------- |
Jan 21, 2012 - 12:03 AM |
Enthusiast Joined Dec 30, '11 From Atlanta via Mobile Currently Offline Reputation: 0 (0%) |
wat?
So you have a misfire. What cylinder(s)? Disconnect each injector separately. When there is no change, that cylinder is missing. You can stick a screwdriver to the injector and listen to the end to see if the injector is firing. Pull off the cap and check for buildup. If you've never changed any of these things, it might be worth doing as proper maintenance. Just use your head. Search the internet. This post has been edited by RobbMeeX: Jan 21, 2012 - 12:06 AM -------------------- |
Feb 1, 2012 - 10:12 AM |
Ok update, I changed the spark plugs, plug wires, coil, rotor, and distributor cap, still having these nasty misfire in between 2500 RPMs and 3500 RMPs, before and after that it runs smooth, what could be the issue now?
Note... My car didnt seem to do this before i changed the coil, after i changed the coil it started doing this. This post has been edited by justin3: Feb 1, 2012 - 3:36 PM |
Feb 7, 2012 - 9:19 PM |
Enthusiast Joined May 10, '06 From El Paso, Texas Currently Offline Reputation: 1 (100%) |
When you changed the coil,do you touch anything else? did you put the correct coil? what about installing the old coil? do you know how to test de distributor coils?
Feb 9, 2012 - 3:16 AM |
Enthusiast Joined Aug 16, '11 From california Currently Offline Reputation: 0 (0%) |
It might be the order of your spark plug wires is wrong. When i changed my wires to the thick ones i have now, the first time i started the car, i had horrible missfire. I didnt even drive it because i knew it didnt sound right. So i check online for oem specs and found out the order i put the wires back on the distributor cap was wrong. so you might want to check that.
Ok update, I changed the spark plugs, plug wires, coil, rotor, and distributor cap, still having these nasty misfire in between 2500 RPMs and 3500 RMPs, before and after that it runs smooth, what could be the issue now? Note... My car didnt seem to do this before i changed the coil, after i changed the coil it started doing this. |
Feb 9, 2012 - 9:52 PM |
Enthusiast Joined Sep 22, '11 From midstate michigan Currently Offline Reputation: 0 (0%) |
If the coil made it worse put the old coil back on and start your diagnosis over. Just becuz it's new doesn't make it good!
Mar 5, 2012 - 2:23 PM |
Enthusiast Joined May 6, '04 From antioch CA Currently Offline Reputation: 0 (0%) |
i say check the plug wires too. If their is a crack in any of them the car will stutter.
Mar 6, 2012 - 10:00 AM |
Enthusiast Joined Mar 5, '12 From Iowa, Council Bluffs Currently Offline Reputation: 0 (0%) |
sounds like wet sparkplugs!
look at them inspect em if theres any oil.. or maybe water on that! try to use some Gas Add ons! try using Octane fuel.. that should dry it up if theres water in there.. that happened to me when i washed my engine bay lol. i did it first time idk how water got into my spark plugs but yea i went to autozone and the guy told me i have water on my spark plugs so he had me put in octane gas in my regular gas.. after 20 mins the car started running fine. |
Lo-Fi Version | Time is now: November 26th, 2024 - 9:05 PM |
