> Can I swap a 3S-GTE into my '97 ST?
post Jan 21, 2012 - 2:15 AM
N8dgr8
Joined Jan 21, '12
From Texas
My tranny started popping out of 3rd and 5th a few weeks ago, and my mechanic said the synchro was bad. Basically, I'm looking at a rebuild, which makes me wonder if I should replace my 176k mile 7A-FE simultaneously. What would I need to get a 3S-GTE into my ST?
post Jan 21, 2012 - 3:01 AM
nics
Joined Feb 15, '08
From Royal Oak, MI
read the stickies.
all info is there
God made man....
Everything else...
Made in China
post Jan 21, 2012 - 10:07 AM
Arsaces
Joined Oct 7, '10
In this case you can easily search your answer, but in many cases the search function on this forum is very limited and poor.
post Jan 21, 2012 - 10:33 AM
N8dgr8
Joined Jan 21, '12
From Texas
QUOTE (Arsaces @ Jan 21, 2012 - 10:07 AM) *
I know, and I've found a lot of info about some of the stuff I'd need to do. I am trying to put together a compete list of every little piece I'd have to buy (preferably from someone who has done it themselves) so I can get a cost estimate. Also, how concerned should I be about the legality of the emissions from a Japanese 3SGTE? Even links to other posts that answer my questions would be appreciated!
post Jan 21, 2012 - 10:34 AM
JasonTX
Joined Mar 1, '10
From TX
Howdy
welcome to the forums, the short answer is yes
http://www.6gc.net/forums/index.php?showtopic=73956
very comprehensive guides in this post outlining your swap options and everything you will need as well as walkthroughs. theres one like it at the top every section in the forum that covers pretty much every thing about maintaining and modifying our cars .
where in TX are you located?
This post has been edited by JasonTX: Jan 21, 2012 - 10:40 AM
JN 3:16
post Jan 21, 2012 - 10:45 AM
N8dgr8
Joined Jan 21, '12
From Texas
QUOTE (JasonTX @ Jan 21, 2012 - 11:34 AM) *
Howdy
Thank you for the info! I'm in Rowlett (Dallas County).
post Jan 24, 2012 - 2:37 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
more than you can afford pal, i love that quote... anyways it will be cheaper to rebuild your 7A. follow my assembly guide.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Jan 24, 2012 - 3:14 PM
JasonTX
Joined Mar 1, '10
From TX
QUOTE (Smaay @ Jan 24, 2012 - 3:37 PM) *
true a rebuild may be cheaper but dallas jdm motors had a 4th gen 3sgte for under a grand a few weeks ago i bet you can haggle a bit and have them drop it off for you free since your only like half an hour away.
as far as bang for the buck if you can turn your own wrench and read a wiring diagram a 3sgte may be in your future
check out eastern pros threads. a lot of good 4th gen info there
peace
-jec
This post has been edited by JasonTX: Jan 24, 2012 - 3:15 PM
JN 3:16
post Jan 24, 2012 - 5:08 PM
bsamps4
Joined May 16, '10
From Raleigh
Are you wanting to rebuild the 3s that you want to buy, or are you just going to install it?
If you're just going to install it you need to purchase GT engine mounts, wire loom, extra 12/14 gauge wiring, oil,oil filter, coolant, spark plugs, rotor cap, rotor button, spark plug wires....and some electrical/mechanical skills.
You could probably get away with a swap for around 3500...
If you want to rebuild...
You would need to add pistons, rods, bearing, and all needed seals...
This would cost you a minimum of 6000...
post Jan 24, 2012 - 6:38 PM
JasonTX
Joined Mar 1, '10
From TX
QUOTE (bsamps4 @ Jan 24, 2012 - 5:08 PM) *
i may be mistaken but i think the options he's considering are install a 3s or break apart and rebuild the 7a while his tranny is in the shop.
-jec
This post has been edited by JasonTX: Jan 24, 2012 - 6:40 PM
JN 3:16
post Jan 30, 2012 - 12:25 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
you dont need pistons or rods. just bearings, rings, gaskets, etc. etc.
post Feb 17, 2012 - 12:02 AM
2celicas2love
Joined Oct 4, '09
From Pomona, CA
Do the swap if you can afford it. Keep in mind you'll have to get a transmission as well as Axels to complete it. Everything adds up to a lot ...a lot of money and u will not pass emissions legally. You will have to pay a slum to pass u
The heart has its reasons which reason knows nothing of
2000 7th gen GTS 6spd
95 st, swapped 3sgte 3rd gen wrc version :D
post Feb 17, 2012 - 1:07 AM
Soulend
Joined Nov 24, '07
From Tucson, Az
well where I live, I drove my 97 ST up with the 3SGTE in and passed with the plug in. so it might just depend on where you are and what they test.
but yeah stickies stickies stickies. one of the first persons to do a write up about the 3S swap did it into an ST. basically ST's have more work because not only do you need parts the GT people need you also need all the GT parts they already have.
gl hf dgl
Kevin
Lo-Fi Version Time is now: December 4th, 2024 - 9:56 AM
