> White Gauge wiring
post Dec 23, 2003 - 7:08 AM
acenova
Joined Dec 21, '03
From Portland, OR
I just bought some white indiglo gauges for my car to go over the black ones but I was curious as to what to plug into for the power source. Should I use the dimmer or is there something else I should tap into for the switch?
post Dec 23, 2003 - 10:37 PM
YOu can use the dimmer or you can use the light on wire that connects to the stock radio wiring harness, its a yellow wire.
post Dec 24, 2003 - 3:48 AM
van95st
Joined Sep 6, '03
From Fairbanks AK
if you do use the dimmer, as i did, make sure you tap into the 12V constant going to it not the variable comming out.
This post has been edited by van95st: Dec 24, 2003 - 3:48 AM
post Dec 24, 2003 - 11:31 AM
Isnt the variable the one that does the dimming? So that you can dim them?
post Dec 24, 2003 - 1:24 PM
AudioFreak
Joined Dec 19, '02
From West of Atlanta
The gauges come with a dimmer. Tapping the variable side of the cars dimmer will burnup the gauges.
post Dec 24, 2003 - 1:44 PM
Just wonderin.
Lo-Fi Version Time is now: January 5th, 2025 - 10:55 PM
