![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 4, '12 From US Currently Offline Reputation: 6 (100%) ![]() |
Hey everyone, so my 5th gen celica has been leaking oil from the dipstick out for a while now. My worry is that it is a bad piston ring. However:
1. The PCV wasn't even there, and its vacuum was plugged. 2. Positive Crankcase Ventilation hose was clogged too. [hose below] ![]() -I have replaced the PCV and removed the plug from the crank case hose. -I turned the car on but couldn't take it for a spin, but for the while it was on it didn't spew any oil out. -There is no weird noises coming from the engine at all. Valve seals? Piston rings? The rubber on the dipstick is missing a chunk on the very bottom of it, too. There was oil on the boot of spark plug #1 (one closest to the dist) No oil on the rest. Any ideas? -------------------- 1993 Celica GT Coupe - sold
1994 Celica GT Liftback |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 22, '07 From Houston, TX Currently Offline Reputation: 4 (100%) ![]() |
with no ventilatin of the crankcase the normal blowby will cause oil/gasses to escase elsewhere (seals, gaskets, etc)
Enthusiast ![]() ![]() ![]() ![]() Joined Jan 19, '11 From Paraguay, Winchestertonfieldville Currently Offline Reputation: 1 (100%) ![]() |
look for smoke coming out of the tailpipe thats a tell tale sign your rings are gone
There's no oil coming out of the tail pipe. There's the pre-cat and the muffler on the exhaust.
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 8, '03 From Lancaster CA Currently Offline Reputation: 6 (100%) ![]() |
you were getting blowby thats why it was coming out the dipstick.
Well most certainly, but caused by what? The vent hose covered?
This post has been edited by Syaoran: Jan 22, 2012 - 12:36 AM -------------------- 1993 Celica GT Coupe - sold
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 31, '11 From Rochester, NY Currently Offline Reputation: 5 (100%) ![]() |
Yeah, as stated before, those being clogged meant that there is no where for gasses and pressure to escape. Therefore it has to find a place to seep out. Normally oil will come out of the dipstick with the engine running if the dipstick is out, but it shouldn't push past both o-rings. I'd take the ring to a parts store and purchase a new one for you dipstick. Should be good now that you replaced the PCV and positive vac hose.
Oil on the bottom of the boot can be from a bad seal on the base of the sparkplug tube, or the gasket up top could be allowing a bit to eep over the top of the tube and down the walls. -------------------- 1994 Toyota Celica GT-S 5S-FE 190k Miles. Project car 1992 Toyota Celica GT 5S-FE 170k Miles. Daily driver/beater 1999 Toyota Camry LE 5S-FE 216K Miles. RIP You will be missed. ![]() *ASE Certified General Manager |
Oil on the bottom of the boot can be from a bad seal on the base of the sparkplug tube, or the gasket up top could be allowing a bit to eep over the top of the tube and down the walls. The seal up top (where the valve cover nuts go) was practically gone (I could pick out a chunk of rubber). So I got all 4 new seals and a new valve cover gasket. I'll be doing that soon. What should I do to remove the oil on the spark plug? Let it burn out of the system naturally? -------------------- 1993 Celica GT Coupe - sold
Lo-Fi Version | Time is now: February 18th, 2025 - 1:40 PM |
