> Front wheel bearing problems?, any ideas?
post Jan 26, 2012 - 5:59 PM
celiracer
Joined Oct 5, '05
From NE
Hey guys been looking around for info. Has anyone had problems with keeping front wheel bearings from blowing out all the time? my daily is a 95 and i've replaced pass side front 4 times the first 3 lasted a couple months before they blow out. the 4th lasted 6 months and is now blowing out. I have been buying hub and bearing from toyota direct and has been pressed in everytime by my dad who is a mechanic. and have been getting it aligned right after the install.. anyone else have this problem? my 97 w/ the 3s swap hasn't caused me any problem after replacing on that car.. Jut seems the 95 is always going out. thanks in advance
post Jan 27, 2012 - 8:03 PM
Stambo
Joined Apr 23, '08
From Muskego,Wi
torqued down to proper spec? i know having big rims and wheel spacers wears those things out faster but on your daily i doubt that would be the case.
2nd Gen 3s-gte.... It lives!
97celiman
post Jan 27, 2012 - 9:28 PM
richee3
Joined Jun 29, '08
From Denver
Possibly loose axle nut, or one that keeps loosening? Only causes I can think of ate the axle nut, cheap bearings (which you've ruled out,) lowering, bigger rims, or not having an axle in the hub at all.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Jan 27, 2012 - 9:48 PM
SupraKid
Joined Aug 15, '10
From The Best Coast
What type of bearing are you using to replace it?
post Jan 30, 2012 - 3:04 PM
celiracer
Joined Oct 5, '05
From NE
i'm buying bearing hub an seal kit from toyota.. gonna try and replace spindle this time with it and hope it don't go out again lol.
Lo-Fi Version Time is now: February 16th, 2025 - 11:58 PM
