> 5sfe to 3sgte (I have questions), I want to swap the 3sgte
post Jan 29, 2012 - 1:19 AM
yoyofanatic
Joined Jan 29, '12
From Minnestota
I have a 1995 celica gt convertible
its all stock with its 5sfe.
I want to put in the 3sgte. I know it bolts onto the tranny with the 3sgte clutch and flywheel.
Some of my questions are
- Will the 3sgte mount on the frame with the 5sfe mounts, because I think the block is the same.
-Is there enough room in the whole enigine bay of the car for the 3sgte?
post Jan 29, 2012 - 4:49 AM
http://www.6gc.net/forums/index.php?showtopic=73956
basically all you need to get all the info you need.
The NA performance & Engine and transmissions maintenance thread
Introduction & Basics
Engines 101 - Get the basics right first.
Technical Engine specs. - The basics on what all those numbers and letters mean in the engine code.
Toyota BGB or Service & Repair Manuals. - Where to get the Toyota Service Manuals.
Resting your A/F ratio (Air fuel ratio) - A quick and easy task to rest your A/F ratio.
Fuel Economy. - Good or poor gas mileage?
Feasible and Non-feasible Swaps. - great info on what works, what doesn't & alternatives. (Includes the 2JZ swap)
Multiple Celica Engines
Cold Airbox. - Info about them and how to make one.
Custom Exhausts thread. - Sizing , shape & style for NA and Turbo.
Port & Polish. - (External Link) With details on porting & polishing a 3S-GTE head.
Celica specific Engines.
7A-FE & 7A-GE, AT200 (see here for 7A-FTE & 7A-GTE)
Info:
7A-FE USA specifications.- The 7A-FE specs.
Maintenance:
7A-FE Engine Repair Manual. - The AT200 7A-FE repair manual.
Building the 7A-FE. - Great info, also with what not to do.
Performance:
Cold Air Intake (CAI) for the ST. - How to make your own CAI for your ST Celica.
Making a Cold Air Intake (CAI) for the ST. - Another how to, to make your own CAI for your ST Celica.
Installing a Cat-back Exhaust system. - A great guide on installing the Greddy SP cat-back exhaust system.
Installing a Header/Extractors on the 7A-FE. - A great how to install a Header/Extractors on the 7A-FE engine.
5S-FE & 5S-GE, ST204 (see here for 5S-FTE & 5S-GTE)
Info:
5S-FE USA & Canadian specifications. - The 5S-FE specs.
Info about the 5S-GE/GTE engine - Great guide on how to build a hybrid 5S-GE/GTE engine. (pdfile)
Maintenance:
5S-FE Engine Repair Manual. - The ST204 5S-FE repair manual.
5S-FE Timing belt and/or Water Pump Replacement. - How to change your timing belt and/or Water Pump on the 5S-FE motor.
How to Replace Shift solenoids. - How to replace bad shifter solenoids on an automatic Celica GT.
Performance:
Cold Air Intake (CAI) for the GT. - How to make your own CAI for your GT Celica
SAFC II in a 94 GT. - A great write up on how to install the SAFC II.
3S-FE, ST202 or ST203
Info:
3S-FE Japanese specifications. - The 3S-FE specs.
Maintenance:
Performance:
3rd Gen 3S-GE & 3S-GE BEAMS, ST202
Info:
3S-GE Japanese specifications. - The 3S-GE specs.
ACIS & BEAMS Discussion thread. - A discussion thread about the 3S-GE engine.
Maintenance:
(RM396E) 3S-GE Engine Repair Manual. - The ST202 3rd Gen 3S-GE engine repair manual. (pdfile)
Performance:
Guide to modifying the ST202 3S-GE. - A great guide on how to modify the 3rd 3S-GE.
3rd Gen 3S-GTE, ST205 & ST205 WRC edition (See here for more info)
Info:
3S-GTE Japanese specifications.- The 3S-GTE specs.
Maintenance:
(RM398E) 3S-GTE Repair Manual. - The ST205 3rd Gen 3S-GTE engine repair manual. (pdfile)
(RM399E) ST205 Chassis and Body Repair Manual. - The ST205 GT-Four Chassis & body repair manual. (pdfile)
Performance:
(see here for more info)
V6, 4A-GE series & other Swaps
Info:
Completed swap thread. - For those who have successfully swapped engines.
4A-GE info - great info if your thinking of swapping a 4A-GE into your AT200 Celica.
2GR-FE Discussion thread. - Discussion, info notes regarding swapping a 2GR-FE into a 6Gen Celica.
Maintenance:
Performance:
Transmissions, LSD & Clutch
Info:
USDM Transmission Gear Ratios. - The Gear ratios for auto and manual transmissions for the ST GT & GT-S.
Engine RPM vs Vehicle Speed Graphs. - Great info/graphs showing the vehicle speed (mph & km/h) for various engine speeds.
E series Transmission. - Great info on the GT4 transmission also has info converting them to 2WD.
Maintenance:
AT200 MT transmission fluid change. - Great guide on how to change your manual transmission fluid.
ST204 AT transmission fluid change. - Great guide on how to change your automatic transmission fluid.
Clutch Install video. - It's for a different engine, but the same principals apply.
How To Rebuild Your Clutch Master Cylinder - Great how to guide.
Removing your transmission (MANUAL) 5sfe. - Great how to, great info if you need to replace your clutch aswell.
Swapping Transmissions:
Auto to manual check list. - A checklist of parts you need to swap in a manual transmission.
Auto to Manual Swap. - A guide on how to swap from an auto to a manual transmission.
Auto to manual swap. - Converting from an Auto to a Manual on a ST.
Converting the MR2 transmission for Celica use. - A great how to, on making the transmission work.
Performance:
How to articles:
•How to check, Check Engine Light (CEL) - On a 94-95 Celica (7A & 5S)
•How to check, Check Engine Light (CEL) - Another how to guide
•Engine Bay Renovation. - Very detailed thread about wire tucking, battery relocation, and a few other neat tricks in the engine bay.
•How to Replace Shift solenoids. - How to replace bad shifter solenoids on an automatic Celica GT.
•How to Replace a Drivers side Axle - How to replace the drivers side axle.
•How to Refurbish your axles. - Great 'how to' & info thread.
•How To Rebuild Your Clutch Master Cylinder - Great how to guide.
Part Database
6GC part database - Covering performance parts.**Currently linked to our basic part list.**
post Jan 29, 2012 - 11:35 AM
Neon90424
Joined Jan 19, '11
another pointless thread
post Jan 29, 2012 - 3:15 PM
Ted95
Joined Mar 8, '09
From Westport, MA
QUOTE (yoyofanatic @ Jan 29, 2012 - 1:19 AM) *
the s54 tranny has 3 of the 4 motor mounts on the transmission. if your using your stock s54 tranny you will be fine with the mounts.
the 3sgte comes in our cars (GT4) factory in Japan so yes it fits.
you need a 3sgte pressure plate and disc but with the splines for the s54.
theres a sh!t ton of info on this site espically in the stickies and in this Forced Induction forum.. just read through some of the build threads, they are loaded with info.
st205 powered ss3 coupe
post Jan 29, 2012 - 5:55 PM
pxcr440
Joined Sep 6, '03
From hudson ,iowa
not sure how serious you are but i will be pulling out a complete 2nd 3sgte with complete front mount setup , plug and play harness by tweak and ecu even tranny and clutch setup put about 1000 miles on it over the past 2 summers and a few couple hour trips , mines a 94 gt and i am located in northeast iowa
hit me up if your interested
Lo-Fi Version Time is now: December 2nd, 2024 - 12:25 AM
