Enthusiast ![]() ![]() Joined Feb 4, '12 From Findlay,oh Currently Offline Reputation: 14 (100%) ![]() |
Well me and will get to be top priority but its fun to work together...lol
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 23, '11 From kenton ohio Currently Offline Reputation: 14 (100%) ![]() |
Update!!
Was out working on it today Been thinking for awhile that my fuel pressure was too high an causing issues with running right so I started dropping the psi an it began to not be able to hold an idle so I turned it up to above where I had it an now she's running like a whole new car No lagging between shifts an the power output has went up as well!! So the hope is now to get it in a shop yo get the exhaust finished soon an start really putting some miles on her!! -------------------- 95 gt coupe, v6 swap weekend toy
99 gt hatch beams swapped wife's 94 st hatch my daily driver http://www.6gc.net/forums/index.php?showtopic=82235 ![]() |
Yay!!!! And you want to do another swap! *cough*
![]() -------------------- 2001 Miata LS 5-speed
At some point I wanna do a beams or 3mz
Enthusiast Joined Jun 18, '07 From Atlanta Currently Offline Reputation: 0 (0%) ![]() |
I vote for a 2grfe or a gen4 3sgte.
Oooohhhhh 2gr sounds like fun!
Might have to do that too -------------------- 95 gt coupe, v6 swap weekend toy
Fits great in mk2 mr2's. The ultimate v6 swap for an mr2. You'd want to check fitment head/hood clearance for a celica. But otherwise, totally doable.
The gen4 3sgte is easy and can be done in a few weekends. |
2GR my Celica and I'll stick around.
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Nov 29, '10 From Lake Havasu City, AZ Currently Offline Reputation: 31 (100%) ![]() |
^the main concern with the 2gr, from what i've read, is the DBW conversion.. i've never looked to deep into it so i cant speak about it but from a quick glance and browsing a few threads on mr2oc it seems relatively straight forward? (as far as custom swaps go
![]() -------------------- ![]() 6gcHeroes:808hectortimmybatmandiegotigamak |
I've done a bunch of 2gr wiring for the sw20. I swapped a 2gr into my brother's mr2, and then 15-20 harnesses for people. On those, I make a separate 10ft harness for the pedal. 6 wires all to the ecu. With the Celica, you could just run the wire straight from the ecu. 5ft would be more than enough.
Your making this too tempting with me not having the funds to do it lol
Hood clearance??? Who needs a hood if I stuff a 2gr in the coupe I'm leaving the hood off to show that bad boy off lol In all honesty I will probably be in touch at some point about a 2gr..... but it'll be awhile.. Would like to hear all the detail on what it takes Oh nice hearing from you mr220v!! Its been too long -------------------- 95 gt coupe, v6 swap weekend toy
Hell, even 1MZ it and I'll stay.
Well then get to work!
Mr220v is the man to talk to -------------------- 95 gt coupe, v6 swap weekend toy
I've been looking for over a year and never found a donor. I found a Camry that was a driving car, but it was $2,000 or so. Need to find one that's been rear-ended, then I can most likely get the swap done for free when it's all said and done.
When I did my brother's, I didn't feel like it was necessary to get an entire 2gr parts car, or even a motor set. He bought a longblock, and then bought everything else separately. There are a lot of items that you wouldn't use out of a motor set. Catalytic converters/manifolds, power steering, and the automatic transmission. Also, you have to find the very specific nonimmobilized rav4 2grfe ecu. So since you're stuck piecing it all together anyway, may as well save the money and not pay up for a motor set.
Again, for a Celica, the big thing to look at going in is the hood clearance. |
How much taller than a 1mz is the 2gr??
Only reason I've thought about a donor car is I'd get a lot of what I need at one time an could sell some of the leftover parts or just scrap the car. A e153 is a must I'm guessing with the 2gr too isn't it. What the rough cost of a basic 2gr swap? -------------------- 95 gt coupe, v6 swap weekend toy
^Your soul!!! Muwahahahaha!!!
For the 1MZ I think it's worth trying to find a donor since there were Camry/Solara that have the 1MZ/E153 from the go. I had the thought if you have the GT Celica just swap drive-trains between the two and you could sell the Camry/Solara as a working car for probably not much less than what you payed for it. This post has been edited by Box: Jul 10, 2013 - 12:42 PM -------------------- 2001 Miata LS 5-speed
I forgot about the immobilizer.. that was the other issue the mr2 guys had
How much taller than a 1mz is the 2gr?? A e153 is a must I'm guessing with the 2gr too isn't it. What the rough cost of a basic 2gr swap? Are the gears turnin in your head now? ![]() -------------------- ![]() 6gcHeroes:808hectortimmybatmandiegotigamak |
Only downside to that is you then have 2 wiring harness that you need
Only downside to that is you then have 2 wiring harness that you need Everything is there, just needs lots of solder and schematics. ![]() -------------------- 2001 Miata LS 5-speed
Lo-Fi Version | Time is now: February 18th, 2025 - 3:22 AM |
