project 1mz celica, 94 gt starting a new life |
Apr 18, 2012 - 12:55 PM |
Well i got alittle more figured out with the help of mr220v.
Im getting miss fires on cly 1,3,5 witch he thinks is caused by her leaning out on the top end An hes reasoning for thinking this makes since. The return style fuel system on the motor is set for 32psi But the computer is setup for a returnless system that runs at 51psi He thinks if i get it to match the ecu it will run right He told be he had a similar problem on a 2gr swap. It would run fine till you gave her gas because the pressure in. The return line wasnt high enough. So now i just have to wait for the new regulator to show up Witch could be anywhere from the 20th-3rd witch means she be ready for the midwest meet or right after hopefully But today i tried regrounding the a/t signal to a known good ground with no luck So i think im just stuck wiyh those codes. An im looking for another speed sensor. I priced a new one an she said well the cheap cheap one is 85bucks. Witch promptly lead to being my response then fallowed by when i relized she wasnt joking an i said i give up an left alil an alil that a part that small cost soo much. Not sure of what else to do now -------------------- 95 gt coupe, v6 swap weekend toy
Apr 18, 2012 - 1:19 PM |
Are you getting an O2 sensor code. Lean on only one bank would make me think that I had a bad O2 sensor or possibly an exhaust leak on that side of the engine. Dude you gotta grab a scanner tool, it will save you in that you wont be throwing money at these issues by replacing everything, just replacing what you need.
I would definately say that fuel pump situation is causing problems. The computer is probably triming itself rich to the max to correct the lean condition and then still running lean beyond a certain rpm. We need to find out your bank 1 and bank 2 fuel trims and the O2 sensor readings. Also, Id suggest focusing on the fuel pump first on make the transmission a low priority. You can hold off on that VSS just get that engine purring first This post has been edited by Special_Edy: Apr 18, 2012 - 1:21 PM |
Apr 18, 2012 - 1:34 PM |
No i didnt see an o2 sensor code
But come to think of it I hink my bank 2 o2 sensor it jusy another bank 1 sensor o had layin around cuz a wire broke. On the old one I know i dont have an exhaust leak. They spent about an hour goin over it looking for leaks just to be sure there was none They did have to move the bank 2 sensor alittle farther down cuz it was hitting the streering rack Hope thats not the issue -------------------- 95 gt coupe, v6 swap weekend toy
Apr 18, 2012 - 1:52 PM |
Enthusiast Joined May 3, '11 From Ohio Currently Offline Reputation: 8 (100%) |
^I agree. A combination of scanner tool (purchase one for yourself at 70$ and use on all vehicles. I like mine) and a DMM (digital multimeter) are going to be key for you to get this working properly. my multimeter isn't anything special, cost me like 15 bucks bought locally and it does everything you need it to do on a daily basis and I've solved problems with it on my car, my sisters VW, and my dad's garage door opener after lighting struck the transformer... even tested a dizzy with it to find that was bad.
Start with that regulator, and get that scanner tool from someone or go buy one. Information is key here. get more information than you have problems and you'll eventually get answers. -------------------- |
Apr 18, 2012 - 3:24 PM |
Enthusiast Joined May 4, '05 From western MD/NOVA Currently Offline Reputation: 2 (100%) |
though i do not have experiences with this motor, or much on diagnosing fuel delivery issues, i do have a strong basis of trouble shooting electronics.. and with the process of elimination, logic, and the info that you have already provided would suggest to me that you first look at the rear bank O2 sensor.. lean conditions on 1 bank.. and the same bank that you had a band-aide sensor put in, (and possibly still an open in the line (cut, bad/no ground, or even a high resistance contact (like a twisted splice that came lose during soldering and it now does not have a solid contact)) and a faulty sensor will not always trip a code or kick a CEL... so testing the sensor and the circuit that it is on will always be the best way of making sure that the system is doing what it needs to be doing..
This post has been edited by mandrek: Apr 18, 2012 - 3:24 PM -------------------- |
Apr 18, 2012 - 5:55 PM |
It's interesting that you're getting a misfire on cylinders 1, 3, and 5 but not 2, 4, and 6. What's going on with that rear bank? I'd love to see the real time info from the scanner. I'm not so sure that the ECU really is leaning the fuel out or else you'd have total misfires across the board. Do you have two FPR's (one for each bank) or just one for all 6 cylinders? Do all the plug wires originate from the same source or do they have two different sets of wires, one for each bank? I'm betting that those three cylinders are exactly what's causing your issues. It's just a matter of going through and checking all the factors that control air, fuel, and spark on the rear bank.
Maybe it is the O2 sensor being too far downstream, causing the ECU to lean out that bank but I'd look into other simpler/cheaper to fix causes first. -------------------- "Employ your time in improving yourself by other men's writings, so that you shall gain easily what others labored hard for." -Socrates. Even Socrates told us to use the search button!
Apr 18, 2012 - 5:58 PM |
though i do not have experiences with this motor, or much on diagnosing fuel delivery issues, i do have a strong basis of trouble shooting electronics.. and with the process of elimination, logic, and the info that you have already provided would suggest to me that you first look at the rear bank O2 sensor.. lean conditions on 1 bank.. and the same bank that you had a band-aide sensor put in, (and possibly still an open in the line (cut, bad/no ground, or even a high resistance contact (like a twisted splice that came lose during soldering and it now does not have a solid contact)) and a faulty sensor will not always trip a code or kick a CEL... so testing the sensor and the circuit that it is on will always be the best way of making sure that the system is doing what it needs to be doing.. Lol this is like where I said that dirty connectors can cause high impedence in the circuit. At this point im addicted to heat shrink and dielectric grease. If I had to jack with the wiring once I dont ever want to have to do it again lol. Unless its the spaghetti factory disaster that is my 64 chevy harness that Im too frustrated to even look at... God I need to rip that nightmare out |
Apr 18, 2012 - 7:21 PM |
Im going tomortow an gettong a new o2 sensor
An price new plug wires Mr220v is pretty dead set its a fuel pressure problem so im working from there Richee3-ill try an explian the ing. In detail when i have more time -------------------- 95 gt coupe, v6 swap weekend toy
Apr 18, 2012 - 8:46 PM |
Ok 96+ 1mz have wasted spark so it has. 3 coil packs on cyl 2,4,6
The theres spark plug wires that. Run from the coil pack to cyl 1,3,5 The ignites both cylinders at the same time. It sounds crazy i know but While cyl 2 is in compression an ignited to make piwer cyl 1 also. Reignites to burn of any extra gas This was done to make the engine pass emissions. So im starting to wonder if my miss fire isnt be caused by bad plug wires this is thefirst those codes came up an i did move the plug elwires around today so im going to go to the junk yard saturday an grab the retainer clip things that hold the wires up off of everything an see if that helps at all -------------------- 95 gt coupe, v6 swap weekend toy
Apr 18, 2012 - 10:38 PM |
if those cyl. are misfiring that bad, then the extra unburnt fuel from being so rich could have fouled your sensor out. Before I'd replace the sensor, because you know you're misfiring, I'd get that worked out. 02 sensor or not, it shouldn't misfire. Dont want the misfires to ruin another 02 sensor.
Apr 18, 2012 - 10:45 PM |
I dont plan on doing much more till i get that regulator
really hoping this does it cuz im not gonna lie funds are getting low to get her running -------------------- 95 gt coupe, v6 swap weekend toy
Apr 18, 2012 - 11:17 PM |
It is weird it's only misfiring on the odd cylinders. Searched Google and found this: http://www.aa1car.com/library/misfire.htm Seemed to have some good info. Didn't see anything about misfiring at higher rpm's though.
Apr 18, 2012 - 11:22 PM |
Im glad you posted that cuz im just happen to think one(or all 4 ) said it was a lean missfire!!
Apr 18, 2012 - 11:27 PM |
Hope it can be of help. You'll get it right soon enough. If only we could put my philosophy of, "**** it and drop in a 350" to the Celica.
Apr 18, 2012 - 11:29 PM |
I think at this point the best thing i can do is take a break for a day an zone out on skyrim an go back to work on her the next day with fresh eyes so to speak
Hope it can be of help. You'll get it right soon enough. If only we could put my philosophy of, "**** it and drop in a 350" to the Celica. Hmmm i do have a 350 an another celica -------------------- 95 gt coupe, v6 swap weekend toy
Apr 18, 2012 - 11:46 PM |
Skyrim is awesome. I can't believe I haven't touched it in months though... Maybe if found an 85 or earlier Celica a 350 might work out.
Apr 19, 2012 - 12:10 AM |
Did you not replace those items during the build?
I dont think that would be a cause for a lean condition. Your spark plug may fire from wasted spark, but if the wires were bad I think it would be noticeable at any rpm under any load, and it would probably be running stupid rich on that bank, not lean. Lean is too much air in the AFR. I would be interested to see some data logging with throttle position, MAF readings, timing, and fuel trims. It's all easy to find. Download any OBD-II app onto your phone and get an OBD-II dongle to sync with via Bluetooth. I used Torque with an ELM327 adapter to log and export data charts which helped point me in the right direction with my issues. You need to get the regulator in place. -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Apr 19, 2012 - 12:59 AM |
Did you not replace those items during the build? I dont think that would be a cause for a lean condition. Your spark plug may fire from wasted spark, but if the wires were bad I think it would be noticeable at any rpm under any load, and it would probably be running stupid rich on that bank, not lean. Lean is too much air in the AFR. I would be interested to see some data logging with throttle position, MAF readings, timing, and fuel trims. It's all easy to find. Download any OBD-II app onto your phone and get an OBD-II dongle to sync with via Bluetooth. I used Torque with an ELM327 adapter to log and export data charts which helped point me in the right direction with my issues. You need to get the regulator in place. I replaced the plugs but not the wires. They looked like they were in good shape Were can i get that Bluetooth adapter thing at? Im hoping it shows up before the end of the weekend i really think the fuel regulator will finally fix my issues. Mr220v has talked me through alot an he has yet to be wrong he actually mentioned the fpr might be a problem about a week or so ago but we both thought starting with the ecu an maf was the best thing to do so i could read my codes so i guess i should of ordered it sooner but i forgot it till he said something again today Im just trying to stay calm about everything because normally im one to freakout when i can figure something out but im alittle list on this without the help An thanks everyone for trying to help me figure this all out ill do my best to get a scanner an pull the info you guys are wanting. -------------------- 95 gt coupe, v6 swap weekend toy
Apr 19, 2012 - 9:34 AM |
Apr 19, 2012 - 10:30 AM |
Those things always looked real cool but I would still suggest renting the one at autozone, its not a global OBD so it will even read ABS and SRS codes off of integrated car. Its like $200 but thats just a deposit you get it all back. I know with the way this project is going youre short on cash by now. You can even take theirs out to the parkinglot and use it, thats how Ive always done it.
But still the fuel pressure should be #1 priority. I bet that engine will be running like a dream when you get that sorted out |
Lo-Fi Version | Time is now: November 26th, 2024 - 2:55 PM |
