58 Pages V  « < 28 29 30 31 32 > »
> project 1mz celica, 94 gt starting a new life
post May 2, 2012 - 9:30 PM
Box
Joined Feb 23, '12
From Warrior, AL
Bummer, hopefully it's just a matter or things adjusting themselves.
2001 Miata LS 5-speed
post May 2, 2012 - 9:40 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
I require an update.
**** Photobucket
post May 2, 2012 - 9:51 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
You will get your update when i get home
Im also going to sre if a 97 1mz uses a bigger fuel pump in the am if it does im swapping to a supra pump
94 st hatch my daily driver
n
post May 2, 2012 - 10:32 PM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
QUOTE (Smaay @ May 2, 2012 - 5:38 PM) *
did you do anything to the engine before you put it in? perhaps there is something mechanically wrong with it
+1 Timing belt off perhaps? Individual cylinder compression? Valve clearances
Im calling the autoparts store near your house tomorrow and putting a diagnostic computer on hold for you LMAO tongue.gif
This post has been edited by Special_Edy: May 2, 2012 - 10:34 PM
post May 2, 2012 - 10:38 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
I checked the timing the night it was brought home
All the timing marks lined up.
Im going to see how she acts now that all the codes are cleared
Since before i cleared them i would get a small backfire/missfire when revving to redline at wot
After i reset the codes no more bf/mf
n
post May 2, 2012 - 10:41 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
I have a diagnostic computer now lol just havent had the extra 3 seconds to run a real time on it yet
I will in the am tho
n
post May 2, 2012 - 10:56 PM
Box
Joined Feb 23, '12
From Warrior, AL
QUOTE (kurt95gt @ May 2, 2012 - 9:51 PM) *
Checked parts house and the fuel pump for the I4 and V6 Camry is the same.
Had a thought, can't remember if you haven't or not. But have you changed the fuel filter?
post May 2, 2012 - 10:57 PM
Special_Edy
Joined Oct 29, '11
QUOTE (kurt95gt @ May 2, 2012 - 10:38 PM) *
Lean condition could cause the misfire i/e fuel pump not supplying enough fuel at high rpm. Or MAF sensor malfunction. All this will be clearly visible on the Scanner tool. Just do some googling on how to interpret the data. Id be looking at long term fuel trim @ idle and short term fuel trim @ high rpm/WOT that and make sure ur MAF readings are consistent/proportional through the throttle range. Make sure to set a custom list of data instead of the entire data list. The fewer parameters the scanner is displaying the higher the tick rate( the more updates per second). Viewing the entire list will make it update slow. The graph function will help out alot especially with the MAF and O2 sensors
Just some stuff to get you started.
post May 2, 2012 - 11:41 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
As soon as i figure out my scanner app on my phone ill get that info if i can with it
An what does a flashing check engine light mean?
n
post May 3, 2012 - 12:25 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
flashing CEL is severe misfire. and being 1, 3 and 5 means is something on that bank. you might have a leak somewhere.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post May 3, 2012 - 12:30 AM
ricochet1490
Joined May 3, '11
From Ohio
continuously flashing? or just on occasion? Everytime I've had a cel and it flashed for about 30 seconds and then stopped, it was the computer recording a new code and it was telling me about it.
not to say the above is wrong... just my .02
This post has been edited by ricochet1490: May 3, 2012 - 12:31 AM
post May 3, 2012 - 12:31 AM
kurt95gt
Joined Aug 23, '11
From kenton ohio
QUOTE (Smaay @ May 3, 2012 - 1:25 AM) *
Well guess i might have to pull the intake off an check the plugs an the exhaust gasket
n
post May 3, 2012 - 12:34 AM
kurt95gt
Joined Aug 23, '11
From kenton ohio
It doesnt stop till i shut the car off then once it starts it doesnt stop till i shut the car off again
n
post May 3, 2012 - 12:39 AM
ricochet1490
Joined May 3, '11
From Ohio
btw... went back to the first pages... can't find any pics on your small engine tear down and or painting of the covers etc. Are they missing or just in another thread? I thought i'd seen them.. but maybe I'm dreaming frown.gif
This post has been edited by ricochet1490: May 3, 2012 - 12:40 AM
post May 3, 2012 - 12:44 AM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Thats all probably under the coupes thread
Remember in the beganing i was putting this motor in the coupe lol
n
post May 3, 2012 - 12:56 AM
ricochet1490
Joined May 3, '11
From Ohio
you sir are correct... that is where they are indeed.
Your problem here is obviously bank related. To fire, we need spark, fuel and air....
If for a moment we assume the fuel situation is good (and not made worse by this other fpr), and we assume that the air is good (it only has one way in and if the maf was bad the other bank would misfire as well), and we exclude things like exhaust because it would run open piped... not well, but it would do it without misfires....
then that leave one of two things....
1) Spark isn't getting to that bank, something in the wasted spark system not working either physically or wiring might be bad
2) combination of spark/a/f is wrong. Maybe spark is 180 out? maybe timing way off? I can think of nothing gasket wise that would cause a misfire like that. Maybe the cams on that bank only? IDK, but test the spark, see if it's there, see what your plugs look like. IF that checks out, maybe go back to fuel? But for peace of mind I'd check timing (both exhaust and intake) because there are a lot of cams in this motor and if even one of them was off it would cause you massive problems.
Bigger job, but this new problem with the flashing CEL came after you adjusted and changed the fuel pressure.... which likely made it worse by the sounds of things. Check your codes with your obd2 port, but it's ONLY ever been that bank.... check things that are bank specific, not generally specific like fuel and fuel pressure....
post May 3, 2012 - 1:35 AM
Special_Edy
Joined Oct 29, '11
QUOTE (kurt95gt @ May 2, 2012 - 11:41 PM) *
It means a fault is occuring ATM
Misfires cause the CEL to flash
This post has been edited by Special_Edy: May 3, 2012 - 1:38 AM
post May 3, 2012 - 1:42 AM
Special_Edy
Joined Oct 29, '11
Oh and 1,3 and 5 means that bank one as a whole is misfiring
Bet you a chocolate covered doughnut that bank one O2 sensor is bad.
Either cam timing on bank one is wrong, or the O2 sensor is bad
This post has been edited by Special_Edy: May 3, 2012 - 1:42 AM
post May 3, 2012 - 9:01 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
O2 sensor wont throw a flashing CEL. cam timing might be out, have you done a compression test?
post May 3, 2012 - 9:07 AM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Ok i looked at my real time info with engine off
the only thing that wasnt reading zero was the throttle
it was at 10.2
An my freeze frames show 0% fuel trim on bank 1,2
Freeze frame was while running
n
Lo-Fi Version Time is now: December 2nd, 2024 - 7:19 AM
