project 1mz celica, 94 gt starting a new life |
May 10, 2012 - 2:24 PM |
Enthusiast Joined May 4, '05 From western MD/NOVA Currently Offline Reputation: 2 (100%) |
Im picking up a new axle tomorrow an finishing hooking up my oil pressure gauge an probably running alittle bit of seafoam through the oiling system for about 40 mile an hopefully clean out some sludge im sure that has built up in it over the years hey quick heads up.. i just put new axles on my car as well, and got the brand new ones from advanced, think they are called GSP. (not the remans they offer for a few less) On the driver side i got no problem, but the pass side i have a vibration that is defiantly related to the speed of the car, and after eliminating just about everything else im fairly sure that it is the axle.. i noticed that this replacement does not have (what looks to be) a dampener that was the OEM axle i removed. i was going to just simply cut a slit in the OEM one, remove it, put it on the new one and tie it on there using SS ties (like when used to tie header wrap).. but my suspicions of the device were confirmed when, i was about to start the cut, and seen that the rubber piece has a metal ring as part of the outer most ring... i have not decided if i will just go ahead and cut it off and try to use it any ways, since i do not want to put on a balancing device that i had to cut and possibly un balance it in the process of transferring it over.. either way.. i would go OEM for the axles. at least for the pass side for sure.. let us know what direction you went with this and if you encounter any issues plz.. good luck bro!!! -------------------- |
May 10, 2012 - 2:58 PM |
Enthusiast Joined May 3, '11 From Ohio Currently Offline Reputation: 8 (100%) |
I have Autozone axles on mine for like 30k miles now... they're fine.
If your axel is unbalanced from the factory, I'd take it back and get it exhanced as it should still be under warranty -------------------- |
May 10, 2012 - 3:02 PM |
I have a reman pass side axle in my coupe frim advance that ive had no issue with
I prefer reman axlrs over newv -------------------- 95 gt coupe, v6 swap weekend toy
May 10, 2012 - 3:08 PM |
ive had more than one new axle that i had issues with but
Never had a bad reman -------------------- 95 gt coupe, v6 swap weekend toy
May 10, 2012 - 3:12 PM |
unfortunately i have to make a 1400 mile trip starting tonight.. i have 2 small leeks that i will need to address once i get to my destination, and will have to pull both axles to get to em (inner spline seals into diff are leaking) its not bad to the point that i cant drive on it, but i have just run out of time to do it now, and it will have to wait till i have a weekend to do em both at the same time..
May 10, 2012 - 8:07 PM |
Well got my paycheck
Its alittle short from my little vacation a couple weeks ago so looks like no new,brakes for me this week but ill be getting the axle in the am an rebleeding the brakes Them working out some bugs this weekend then hopefully hitting the track on the 25 to see what she can do in a 1/4 mile -------------------- 95 gt coupe, v6 swap weekend toy
May 13, 2012 - 1:15 PM |
Well
Think i know why my oil light was going on an off im losing oil pressure An shes wanting to over heat The oil pump an water pump both run off the timing belt right? -------------------- 95 gt coupe, v6 swap weekend toy
May 13, 2012 - 3:23 PM |
Yes.
When do you lose oil pressure? -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
May 13, 2012 - 4:06 PM |
I started at 65-68 psi the i could rev to 2500 an it would be almost to 80psi then it falls off from there
Its also overheating (atleast ttying too) I went from 70-80 psi now im down to 40 -------------------- 95 gt coupe, v6 swap weekend toy
May 13, 2012 - 4:07 PM |
GRRRRRRR dislike
May 13, 2012 - 10:19 PM |
Dont know how this applies to our engines but could the pressure valve on the oil pump could cause this? Do you have a mechanical gauge attached to it or are you getting these readings off your OBD II port with your cell phone?
The first thing I would do is drain your oil into a clean container( like a large silver bowl/pot from the kitchen). Look for debris or sludge in the bottom or a metallic sheen in the oil itself. Refill the engine with heavier weight oil( 10W-40 or 20W-50 is the manual spec with the temperature where I live). Check the coolant system and make sure it operating correctly. Sit and watch the engine through a warmup cycle, you can feel/measure the temperature for the thermostat and the coolant fan switch to open by touching the radiator hoses. Flush it if it looks nasty and make sure its full. |
May 13, 2012 - 10:33 PM |
It hits 19odegrees in less than 4 minutes
Last week its stayed at round 180 after about 2hours The overheating an the oil psi drop all happen at basically the same time -------------------- 95 gt coupe, v6 swap weekend toy
May 13, 2012 - 10:35 PM |
Kurt, what you are describing is normal. cold engines have higher oil pressure. when it gets to normal operating temp it goes down. what is its steady state pressure? if its over 35PSI thats ok. when you rev it does the pressure go up?
hhmm im not sure why you are overheating now. what have you changed? did you put in a new thermostat? -------------------- 2001 Celica GT-S Turbo
May 14, 2012 - 12:12 AM |
Ill check in the morning but i think itll start to go up then drop down as the rpms go up
Like something is slipping I know as the car warms up the psi will drop but the way its acting doesnt seem right -------------------- 95 gt coupe, v6 swap weekend toy
May 14, 2012 - 9:31 AM |
did you replace the oil pump?
check tbelt tension.. and the oilpump pully.. ive seen multiples fail -------------------- QUOTE "And, as always, your friendship, help, and dedication to the advancement of Texas Celica dominance is GREATLY appreciated. Thanks bro." -DEATH 1994 GT: V6 swap, 5speed E53 W/ LSD, All Power, now RED 1995 ST: SOLD @273k miles, Auto, all power, CarPC, White 1994 ST: Totaled, 5spd, all power, Red RIP 07/09/09 @ 241,810 1994 Lexus LS400: This is my new DD |
May 14, 2012 - 9:36 AM |
Witch one is the oil pump pully
May 14, 2012 - 9:37 AM |
Witch one is the oil pump pully Which.... I'm willing to bet it's the one on the oil pump. Because oil is also used to cool the engine, failing oil pump may also be part cause for increased temp -------------------- |
May 14, 2012 - 9:45 AM |
Witch one is the oil pump pully Which.... I'm willing to bet it's the one on the oil pump. Because oil is also used to cool the engine, failing oil pump may also be part cause for increased temp i just woke up an didnt think about that ill have ti fight with the crank pully to come off so u can get the lower cover off -------------------- 95 gt coupe, v6 swap weekend toy
May 14, 2012 - 9:48 AM |
yep.. the pulley on the pump itself ... they usually get loose and the play makes the hole for the shaft bigger and bigger(giggity) untill eventually it free spins on the shaft.
May 14, 2012 - 9:51 AM |
Why does that pump have to cost soo much
140bucks!! Fml shes parked for awhile -------------------- 95 gt coupe, v6 swap weekend toy
Lo-Fi Version | Time is now: December 2nd, 2024 - 5:50 PM |
