58 Pages V  « < 38 39 40 41 42 > »
> project 1mz celica, 94 gt starting a new life
post May 14, 2012 - 10:00 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
fail...
the pulley is like 10$ if thats all the issue is...
but id do the pump anyway
post May 14, 2012 - 10:26 AM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Id rather do the whole pump so itll be atleast 2weeks
94 st hatch my daily driver
n
post May 14, 2012 - 11:31 AM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
Someone explain to me how the timing belt has caused the water pump and oil pump to stop functioning normally yet the engine is still timed correctly. Knowling little of the MZ engines, I'm still inclined to say that you would have much more serious problems than coolant temperature and oil pressure if you were having problems anywhere in the timing belt.
Dont jump to conclusions. The first step is diagnosising the issue not throwing money and parts at it. Are you sure 190 degrees isnt a safe operating temperature for your engine?
Have you checked the oil? Was there sludge or metal in the oil? Was the oil filter plugged?Have you checked, drained, flushed the coolant system? Are your cooling fans operating correctly? Is your thermostat opening up?
Do your oil pressure and coolant temp sensors work correctly, or are you getting false readings.
Dont replace parts till you know whats wrong.
post May 14, 2012 - 11:43 AM
kurt95gt
Joined Aug 23, '11
From kenton ohio
I have aftermarket gauges in it so i know my readings are right
the stock t stat opens at 180 degrees
I checked the oilan its full an clean
The coolent didnt have oil in it eather from what i can tell
I know the engine temp going up could affect the oil psi
Since the hotter the oil gets the lower the psi it flows at
Um thinking i might start with a t stat an go from there
n
post May 14, 2012 - 12:15 PM
ricochet1490
Joined May 3, '11
From Ohio
Edy makes a point here. I was simply pointing out the location of the oil pump pulley.
But 190 doesn't seem too hot .... I mean frankly, 10 degrees when parked.... that's not bad and it likely doesn't even show up on the stock temperature gauge of the car, only your aftermarket gauge. If everything else is checking out, coolant, oil looking good. and you are above 35psi on the oil pressure, I wouldjn't worry about it until you get WAY outta spec on something. to me, you aren't "out of spec" just not in the middle of spec. This is a swapped motor after all with many things missing, with wiring spliced, in a car with a gauge cluster it's not used to that has 150k miles on it. I'd get your axles worked out and drive it to work one night, or to the store, or down 347 one night on a cruise and see what that temp is while moving air across the radiator.... heat transfer is very finicky, so it wouldn't surprise me if 190 is just where your car will run.
However, given that you've see the change happen does mean something. But what exactly is hard to tell. Maybe some crud in the motor broke free and clogged your oil return line, screwing with your pressure reading? I mean any number of things are possible. I would just drive it around, to the store etc etc. and see if your numbers stabilize. If it gets worse, you have a problem, if they stay the same and are still within safe spec, I wouldn't worry about it..... A hotter motor produces more power anyway.
You should just drive it down to see the beams and really stretch her legs out! lol
post May 14, 2012 - 12:36 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
You might be right im going to try an pump some oil through thr oil gauge line an see what happens
I think im going to change my t stat tho
Cuz thinking about it
The top hose was super hot an the lower hose had no heat to it at all witch makes me think it is probably stuck close
n
post May 14, 2012 - 1:00 PM
Special_Edy
Joined Oct 29, '11
QUOTE (kurt95gt @ May 14, 2012 - 12:36 PM) *
What location are you getting your readings off of? The factory temp sensor/ oil pressure location or an alternative location. I seem to remember you having an adapter spliced into the radiator hose.
Like ricochet said hotter is more powerful. A hotter engine will seal better(rings and such), vaporize fuel better, and thin the oil more which reduces the amount of HP required to pump it. Switch to a heavier viscosity oil, as long as the lowest expected ambient temp is above 60 - 70° F then 10W-40 or 20W-50 will be within specification for the 5sfe/7afe and most likely the 1mz is the same. Definately worth looking up if you want to boost that oil pressure
Are you running the stock radiator, and is this radiator slightly smaller than what the 1mz donor car was equipped with?
Another thought- arent the 5SFE/7AFE cooling systems reverse flow compared to most other engines and manufacturers within the industry? Could the 1MZ cooling system be the opposite of the 5S / 7A? I havent a clue but I'll toss that idea out there.
This post has been edited by Special_Edy: May 14, 2012 - 1:02 PM
post May 14, 2012 - 1:11 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
The water temp is about a foot maybe less away from the stock one
An yes it in the top hose
The oil pressure is coming from the oil sensor location
n
post May 14, 2012 - 1:14 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Im running a godspeed aluminum rad that is twice as the stock gt rad with 2 slim line fans and the hoses are hooked up like othe 1m swaps
n
post May 14, 2012 - 2:04 PM
mandrek
Joined May 4, '05
From western MD/NOVA
hey, i have the god speed rad as well, i now have all of my gauges working and running well.. now my setup is a bit diffrent, but wile doing research on how i was going to set up all of my circuitry, one thing i kept running into was this: OEM t-stats do not open up untill 190-200 the 180 i got was one of the lowest e-bay ones i could find. if you go with mishimoto, TRD, or any of the more reputable manufactures you will still have a hard time finding a T-stat that will go any lower than it first craking open at 180.. also there is the rate or speed at which the T-stat opens... before i installed my newer t-stat, i tested my used OEM and the new e-bay one side-by-side.. in boiling hot water then ice water, and back... what i found was that the e-bay 180*DID open sooner, but the speed was pretty much the same as the OEM, so that both units would be wide open at pretty much the same time...
also.. there is this.. the fan switch that is used to activate the rad fans, is a temp probe that closes the circuit at a certain temp... now what i found (IIRC) was that there was about a 30* spread.. OEM T-stats opening at 190* and fan switch operate at 220* this is done done so that the fan are not always on, and only turn on to keep the car from overheating.. this is why when your car idles the fans kick on and off every so often.. now here is what is different about my set up though... i have an ST and on the rad is made for GT/GT-4 meaning there was an empty port at the bottom of the rad.. i decided to plug that port with a a cheap Harbor Freight temp sensor/gauge.. this being that the temp readings would be reading the temp of the water after it hit the rad, and before it goes into the motor...
so.. i have temp of water going in, we have t-stat controlling water flow to the rad that opens and closes its opening based on the temp of the fluid hitting it, and the fan switch that closes at only a certain point...
this gives me a very odd but insightful view of what is going on in this process.. untill the car is warmed up, and wile driving around my HF temp gauge is pegged to the bottom of the guage, pretty much useless..... BUT!!!!!!!! when im idling i can literally see my oem temp guage (like all of us) climb.. and then see my HF gauge climb as the t-stat starts to open, then at just a bit over 200* the fans will kick on.... and then watch my temps drops on the HF gauge....
this is all allot faster when i have been driving and then come to a stop.. all in all a nice and easy way of seeing that the rad and the rest of the system is doing its job..
now you are reading your temps for your gauge at the top of the water flow.. reading engine temps.. great.. but you gota think that the pump is still pushing some flow into the rad, and the t-stat may still be working right.. just barely holding the port a bit open at the temp the coolent is sitting at. And with the bigger rad,, the heat soak is going to be slower, meaning more time b4 the fans kick on. and seeing a temp of 190* imo is perfectly normal.
lastly i have to ask, but am almost sure of the answer.. did you keep any of the OEM fan shrouds or did you just put the two fans up against the rad w/ the supplied push through clips?
i chose to adapt the main fan's OEM fan shroud so that the new slim fan fit inside the OEM shroud. i did this for one main reason.. function.. the reasoning for a fan shroud is so that the fan can pull air through a broader surface area than the diameter of the fan itself.. remove the shroud, and you are removing overall efficiency of the fan ability to cool the rad.. stack that with the fact that the new rad has more than twice as much thermal mass to remove than the OEM rad= slower temp drop rate... meaning the fans will be on longer..
so a 190* operating temp now looks very normal.
when i finally get my project thread i will have pix of all of this.. but till then i hope my description will suffice.. kindasad.gif
hope this helps some.
post May 14, 2012 - 2:41 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Ok my fans stay on all the time an normally it takes about 15-20 minutes bfore the temp gets above 160 an thats just setting at idle righ now it jumps to 190 after about 5 minutes maybe alittle less
i chose to run the daul slim lines basically because of a lack of space
With the god speed rad the stock fans are almost tpuching the exhaust manifold
I might just pull the t stat out an see how it acts.
The factory 1mz t stat is a 180 degree stat btw.
Im really starting to think its my main problem
n
post May 14, 2012 - 2:59 PM
ricochet1490
Joined May 3, '11
From Ohio
get a diff t-stat for sure.
Also,
Aluminum soaks up SOOO MUCH MORE heat it isn't funny... you have to weld aluminum at least twice as hot as steel.... so even with that, you are going to see a difference on start up... def need to heat the motor up I think IMO.
post May 14, 2012 - 3:03 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Wait witch side of the motor is the oil pickup on
n
post May 15, 2012 - 7:41 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
id guess on the side the pump is on.. tbelt side
post May 15, 2012 - 9:08 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
Kurt look at my thread where it tear down the 1MZ, the pics are all there. and on the 1MZ engine the oil pump is turned by the crankshaft. just like the ZZ engines. it is not like the 5S-FE that has its own pully.
This post has been edited by Smaay: May 15, 2012 - 9:11 AM
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post May 15, 2012 - 9:26 AM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Ok. Ill try an look through it here in a few
The reason i asked where the pick up is at
Is because i still have her jacked up on the drivers side front so all the oil is setting on the pass side rear of the oil pan. So i was thinking maybe thats my problem at higher rpms atm. Maybe its tilted away from the pick up so theres no oil to pick up
n
post May 15, 2012 - 11:15 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
a tilt shouldnt make much difference.. should be enough oil in there to make up for it
post May 15, 2012 - 11:27 AM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Idk ill try an figure it out soon
My buddy sam just got home from Afghanistan
So its been a busy day
n
post May 15, 2012 - 11:53 AM
Special_Edy
Joined Oct 29, '11
QUOTE (stephen_lee @ May 15, 2012 - 11:15 AM) *
Well the pickup is going to be wherever the sump is, the bulge that is the lowest part of the pan. The oil will be slung around more from turning than from jacking the vehicle.
We need a video of your oil pressure problem.
post May 15, 2012 - 12:23 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Ill try an get a vid tonight
The best way to explain it is like this
At cold start the gauge jumps to 80psi an stays there at idle( roughly 1100rpm)
then as i give it gas an start to rev the engine itll clime to 85psi by 2500rpm but then starts to drop back down to around 75psi by 5000rpm
n
Lo-Fi Version Time is now: December 3rd, 2024 - 2:35 PM
