58 Pages V  « < 40 41 42 43 44 > »
> project 1mz celica, 94 gt starting a new life
post May 22, 2012 - 5:49 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Thanks box
Hopefully thia fixs one problem
94 st hatch my daily driver
n
post May 22, 2012 - 6:07 PM
Box
Joined Feb 23, '12
From Warrior, AL
Welcome, I await the results.
2001 Miata LS 5-speed
post May 22, 2012 - 6:14 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
n
post May 22, 2012 - 6:33 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Oh another small update
My tien s techs showed up today
Thank you jaws4god
n
post May 22, 2012 - 6:50 PM
Box
Joined Feb 23, '12
From Warrior, AL
Huzzah!!!
post May 26, 2012 - 4:41 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Picked up a facelift bumper an turn signals at the junk yard on friday
also picked up a couple short ram intakes an filters so ill be playing with intake setups on all the cars some alittle later today
Also picked up a cd player an battery but that all be under another post later
Post pics of everything alittle later too
n
post May 26, 2012 - 4:46 PM
richee3
Joined Jun 29, '08
From Denver
QUOTE (kurt95gt @ May 26, 2012 - 4:41 PM) *
Note to self: Just bring skirts when I head your way laugh.gif
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post May 26, 2012 - 6:03 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
I need your facelift bumper for the coupe yet Daniel lol
n
post May 26, 2012 - 8:39 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Well 1mz isnt over heating anymore
n
post May 26, 2012 - 10:08 PM
ricochet1490
Joined May 3, '11
From Ohio
diagnosis? Just fix itself?
post May 26, 2012 - 10:16 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
QUOTE (ricochet1490 @ May 26, 2012 - 10:08 PM) *
The overheating was a bad thermostat.
Haven't started on the oil pressure yet tho
n
post May 26, 2012 - 11:07 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
So i got to lookin at the line for my oil gauge
It seems like the half closest to the motor was getting better pressure than the half leading to the gauge
so i conbectex the gauge to the first half an the psi went crazy
Went from 60to20to40to70 then the pressure dropped down to 20 an then i seen oil coming out the back of the connection on the gauge an the line broke
The connector was bad so im going to get a new connector an see what happens
I noticed the that when i revved the motor an the psi would drop i would see air bubbles coming out around the gauge connection an some oil leaking out too so im really hoping fixing the line fixs the problem
n
post May 27, 2012 - 1:02 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
But i desided to work on the intake some sl i can get colder air into her
n
post May 27, 2012 - 3:27 PM
celica74
Joined Feb 8, '10
From North Carolina
been waiting for someone to do this(put the filter cone where the high beam should be).
post May 27, 2012 - 3:57 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Its a rough idea so far
Im thinking about just taking the glass off the light an molding a connector to the back if the light to feed air in
But my first idea was for the filter to set inside of where the light use to be an just make a block off plate to stop rain from getting in untill im at the track
n
post May 27, 2012 - 4:05 PM
celica74
Joined Feb 8, '10
From North Carolina
seen integras with just a plastic cone sitting where the light use to be and the intake tube just sitting in it with something to connect the two. Never heard if it yeilded much gain. Sounded mean though. Ive thought of just removing the highs all together, molding one of the holes and putting in dual filament bulbs for the lows. Then run a filter to the high. Would be cool to actually see if someone could photoshop it or actually do it.
post May 27, 2012 - 4:20 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Im working on it lol
n
post May 27, 2012 - 10:48 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
how shes setting for the night . Swapped the filter from the crv( yes i have a sri on my crv biggrin.gif) since its alittle smaller around an fitted where i wanted it to
Tomorrow im going to pull the headlight apart an start making a cold air box around the. Filter. Might not help make any power but itll sure make people wonder at the track!
n
post May 28, 2012 - 5:59 PM
bnr32celica
Joined Jan 16, '12
From 860, ct
If that headlight is good, I'll buy it! I have a leaky broken one you can use for mockup.
post May 28, 2012 - 8:23 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Well i dropped the oil pan an cleaned out the sludge an cleaned out the super clogged oil pickup line
now im just waiting on a new oil pan gasket to ahow up tomorrow
n
Lo-Fi Version Time is now: December 4th, 2024 - 4:24 AM
