58 Pages V  « < 41 42 43 44 45 > »
> project 1mz celica, 94 gt starting a new life
post May 28, 2012 - 9:59 PM
RabidTRD
Joined May 31, '11
From Rochester, NY
Honestly, it doesn't make that much difference having the filter there or having it in the bay. You're more likely to suck in rain and birds than anything.
post May 28, 2012 - 10:28 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
I know
I mainly did it to do something diffrent i plan on covering it with mesh an make a plate to cover it when it rains
94 st hatch my daily driver
n
post May 28, 2012 - 10:34 PM
Box
Joined Feb 23, '12
From Warrior, AL
Just make a hood scoop! thumbsup.gif Hopefully cleaning everything will take care of the oil psi problem.
2001 Miata LS 5-speed
post May 28, 2012 - 10:38 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
I hope so only one way to find out
n
post May 29, 2012 - 8:23 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
*fingers crossed*
post May 29, 2012 - 9:06 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
there is no gasket for the oil pan, you are supposed to use FIPG or a good black RTV
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post May 29, 2012 - 9:14 AM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Mine had a cork gasket an fipg
n
post May 29, 2012 - 12:22 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Hopefully it stays that way
Now to fix a small coolant leak an get the tires back on
But as of right now she holds a constant 23psi at idle an a constant temp of 180-185
Tge oil psi goes from 23-24 at idle to just shy of 70psi at 5700rpm
n
post May 29, 2012 - 1:28 PM
Box
Joined Feb 23, '12
From Warrior, AL
post May 29, 2012 - 1:31 PM
mak5603
Joined Oct 20, '08
Awesome!
How much sludge did you remove? Got any pics? Im currently battling a sludge monster in my Audi..
This post has been edited by mak5603: May 29, 2012 - 1:31 PM
2014 Toyota Rav4 XLE
post May 29, 2012 - 2:46 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
I didnt take any pics. Cuz i had no intent of posting pics of it
But there was probably close to an 1/8 of an inch in the pan an the oil pick up was completely clogged
n
post May 29, 2012 - 3:09 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
glad the link i posted guided you to the issue.
post May 29, 2012 - 3:21 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Yes its time for the ohio celica dominance. To began
Witch also means TRACE HURRY UP WITH THE BEAMS!!!!
n
post May 29, 2012 - 3:24 PM
ricochet1490
Joined May 3, '11
From Ohio
dawg.... I can only do so much frown.gif ... likely won't be done by the 30th due to nearly 15 days of vacation.... boo for car..... yay for vacation!
post May 29, 2012 - 3:26 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
just think of how much sludge is in the rest of the engine.
post May 29, 2012 - 3:27 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Guess i need to get my stuff at 100% an drive down an help with your swap huh
Maybe even get Daniel to comeover an bring me some goodies lol
n
post May 29, 2012 - 3:30 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
QUOTE (Smaay @ May 29, 2012 - 3:26 PM) *
Id almost. Rather not think about it at right now
n
post May 29, 2012 - 3:31 PM
QUOTE (Box @ May 28, 2012 - 11:34 PM) *
How are you envisioning this? I'm thinking 80s style, a rectangle cut in the hood, then a scoop in similar formation with a pipe end running to the throttle body. Trim it on the outside with a bit of black.
This post has been edited by SwissFerdi: May 29, 2012 - 3:34 PM
post May 29, 2012 - 3:41 PM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
QUOTE (SwissFerdi @ May 29, 2012 - 3:31 PM) *
The headlight will yeild much more power than a hood scoop. The two high pressure areas are the front bumper and windshield while the hood is a lowpressure area. There may be a couple PSI of pressure built up in front of the bumper at high speeds which is like free horsepower
post May 29, 2012 - 3:43 PM
ricochet1490
Joined May 3, '11
From Ohio
QUOTE (Special_Edy @ May 29, 2012 - 4:41 PM) *
^this
Which is also why you see cowl induction.... high pressure at the base of the windshield...
Lo-Fi Version Time is now: December 4th, 2024 - 4:44 AM
