> 3sge coversion to 3sgte ?, want to convert my 3sge to a 3sgte
post Feb 1, 2012 - 12:50 PM
st202import
Joined Feb 1, '12
From england
hi guys first time posting was wondering if a 3sgte will fit straight into my st202 ?
cheers
post Feb 1, 2012 - 3:19 PM
richee3
Joined Jun 29, '08
From Denver
There might be some wiring involved but they use the same mounts so yes, it will swap in. You cannot use the AWD transmission without doing an AWD conversion though. Check the stickies in the Engine/Transmission/Maintenance forum- there is loads of information there. Welcome to the site smile.gif
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Feb 2, 2012 - 12:55 PM
st202import
Joined Feb 1, '12
From england
yeaa need to wire in a new ecu n bits n bobs , was gonnna use my transmission so it front wheel drive as i have the gearbox and limited slip diff in it already
cheers
post Feb 2, 2012 - 2:23 PM
richee3
Joined Jun 29, '08
From Denver
In that case, you're all set thumbsup.gif The S54 trans is good up to about 300 hp. After that, the E153 is a stronger trans and has longer gears which suit the power better.
1998 Celica GT-
BEAMS Swapped.
post Feb 3, 2012 - 1:19 AM
99gt3sge
Joined Jun 7, '11
From so cal
so basicaly we can use the ge harness and just re-pin the ecu plugs?
Lo-Fi Version Time is now: December 3rd, 2024 - 5:45 AM
