> spacers ?
post Feb 4, 2012 - 7:19 PM
celica2286
Joined Feb 2, '12
From los fresnos, tx
I want to put spacers on my 94 celica GT but i went to tire discount and they dont recommend it, should i believe that ? are they safe when it comes to wearing out arms and bushings ?
post Feb 4, 2012 - 9:47 PM
Syaoran
Joined Jan 4, '12
From US
All spacers and wheels with lower offset than OE spec will wear your bushings and suspension components.
The farther away the wheel is from the said part, the more stress it will cause on suspension components. Try grabbing a 5lb dumb bell to your chest. It's easy right? Now try holding that same dumbbell with your arm stretched outward for more than 20 seconds.
The same thing happens to your suspension components.
With that said, there's a reason why polyurethane bushings exist smile.gif Aftermarket setups require aftermarket suspension modifications, or replacement of worn OE suspensions.
1993 Celica GT Coupe - sold
1994 Celica GT Liftback
post Feb 9, 2012 - 10:05 PM
rdyzz
Joined Dec 27, '11
From minnesota
^ i've herd people say that, but i myself and many others have driven with spacers for years without any ill effects. heck many car makers have some form of spacing, be it bolt style hub like the accords and bmws, even the brake rotor itself is a spacer. unless your running 5" thick spacers i wouldnt worry about things happening to much, these cars are old and for the most part the bearings are probabally original in most of these.
some rwd cars use the same bearings as fwd cars and rwd guys run 0 to -15 offset. all your doing is changing the offset, if your worried i say just use a reasonable size spacer.
post Feb 16, 2012 - 12:25 AM
Mr_Tee
Joined Mar 30, '09
From Jamaica
15mm max should be safe for the bearings
post Feb 20, 2012 - 11:32 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
i have seen, and people on this forum will attest to being able to run 25mm all around safely. Even during auto-X
エキサイティングカーレーシングチーム!
post Feb 21, 2012 - 10:55 AM
mak5603
Joined Oct 20, '08
I have had 25's in the front and 30's in the rear for a couple years, no problems...
I WAS a delivery driver full time for some of the time, and dd'ing the car the rest of the time, and i have taken it to the local track for some lapping on an occasion. And again...NO PROBLEMS.
Think what you'd like about spacers over 15mm. Im just recounting my personal experience with 30mm spacers. I dont think its cool by any means that i need to run a fat spacer, but its way better than looking sunken in.
No to mention a bearing takes what, 45 minutes to fix minus the press? Ill do 45 minutes of work so my car doesnt look 15mm more sunken in any day, hahaha.
2014 Toyota Rav4 XLE
post Feb 23, 2012 - 12:54 AM
Lenny
Joined Nov 2, '09
From Tacoma, Wa.
i autocross my car frequently on 15mm to 25mm spacers and have had no problem what so ever. the only slight issue was the tire rubbing against the fender. but that can be solved by rolling the fender.
1994 Celica GT- TenzoR 1.8in. Drop springs. 16mm wheel spacers.
Lo-Fi Version Time is now: November 23rd, 2024 - 10:08 AM
