> Idle problems after restarting on a warm day, Idle problems after restarting on a warm day
post Feb 7, 2012 - 5:58 PM
valerit1
Joined May 2, '06
From Nevada
After some driving on a warm (not really hot - winter!) day and stopping for a short time -
when restarted, the idle is weak, fluctuates and the engine frequently dies. No problems starting a cooled down or cold engine,
or any other problems. Restarting and giving a little gas in this situation fixes it. I heard about the heat soak, but it never happened before
in similar conditions. The only difference - after many years of using Chevron exclusively, recently switched to Shell gas.
Any ideas? Thanks!
post Feb 7, 2012 - 6:23 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
i wouldnt imagine gas is the issue. i use shell almost exclusively.
clean the throttle body/IACV. then id try the coolant temp sensor if that doesnt work
post Feb 7, 2012 - 8:37 PM
celicomx
Joined May 10, '06
From El Paso, Texas
Probably coolant sensor, check engine light come on? how the exhaust smells when you have the problems to get it started? When was the last time you changed spark plug, spark plug wires, cap & rotor?
This post has been edited by celicomx: Feb 7, 2012 - 8:38 PM
Lo-Fi Version Time is now: November 26th, 2024 - 7:32 PM
