> FS: 6GC tails/front lamps/fenders/ST215 3SGTE ECU's/ 5SGTE
post Feb 8, 2012 - 1:50 PM
placham
Joined Nov 24, '10
From Worth, IL
Hello, my name is Matt, selling some of the stuff I have from converting over.
Low ballers welcome, worst I can say is NO or counteroffer.
Please text seven08-37two-1six85 or email me at plachamaciej@yahoo.com
Im not here regularly so its easier to get a hold of me via TxMsg or email.
UPDATE more parts.........................prices as follows.
St215 TMIC "intercooler" cosmetic damage, fully functional, ..............125..........shipped
5SFE oil pan great to do oil return for turbo setup, has hole by drain plug, plugged by rubber plug, ......50........shipped
3rd Gen 3SGTE TB extension inlet, will not fit 2nd Gen, this it the bigger TB version what ever 3rd Gen is,..... 60...........shipped.
Also got 2 starters that will fit 5spd trans......... asking 30+postage
St215 3SGTE ECU A/T trans works fine tested on car, speed cut active on it still at 120MPH wont go past it needs something like HKS or Greddy speed defender wired into harness.
more parts and updated pics,,,, if no price please ask.
New stuff added
ST215 3SGTE injectors aqua colored 540CC high impedance(no resistor box required) asking 230 shipped for set of 4 injectors,,, I have 2 sets for sale...tested working
St215 3SGTE A/T ECU tested working as stated above asking .........220...... shipped
5SFE M/T ECU came off of my '94 GT.......asking 60 shipped
5SFE A/T ECU came off of '97+ Camry with distributeless ignition and crank angle sensor type......asking 60 shipped
St215 3SGTE Top Mount intercooler as stated above 125 shipped
3rd Gen Rev3 throttle body adapter/spacer only 3rd gen spec motor TB it will fit.........60...shipped
6GC gauge cluster all gauges work..tested.... comes with KPH speedo that came off of my JDM cluster, just needs your speedo swapped for odometer easy swap......40...shipped
6GC kouki tail lamps both sides L+R,,,,,, Im selling ether LED moded and slightly tinted/smoked tails(their on car at the moment) or totally stock Kouki lights with no mods.
Led moded lights have been opened in the rear and led circuit board installed, then they were resealed, I got them like that, and they look bad azz at night.
OEM tails are just that oem kouki's have a crack but its like on inside of lense on right tail lamp I think it doesnt affect their function one bit.
IM KEEPING A SET FOR THE CAR, I JUST DONT NEED 2 SETS, SO SOMEONE CAN CHOOSE WHICH ONES THEY WANT.
LED Kouki type asking 275 shipped--------> I'll try to get night shot if interested.
OEM kouki asking 225 shipped------------->just your normal Kouki tails.
94+ 6GC GT 5SFE 5spd trans,,,, comes with shift cables and axles TOB and fork. asking 300 picked up only I'll will not ship nor will I look into finding prices
97+ Camry cylinder head DIS type but with removing plug can run distributor system on this head with no problems. I will include intake manifold, ether a 97+ or the older IM that fits this head, older type IM had TB and valves on it, I should have the TB for the newer too just have to find it. There was no issues with motor or head, head just came off for GTE head, has no bent valves or any damage Im asking 200 for head+IM (you choose which IM you want) ...........can probably ship but will be expensive better to pick up, comes with valves/springs/retainers/keepers/lifters-buckets.
2nd Gen 3SGTE hydraulic belt tensioner.....BRAND NEW...0miles...found out hard way it wont fit my ST215 and why, need it gone..... 60 shipped takes it.
3SGTE water pump back cover ( T-stat housing) brand new should work on ST185 and such, I will throw in water pipes with oil cooler with this or can part it out......BRAND NEW COVER)......asking for cover+pipes+oil cooler 140........ shipped......
Pile of stuff............if you see anything just ask I'll get price shipped for it..... think there's a E153 trans top bracket need to verify tho, 2 good starters for S-series S53 trans. 5SFE distributor, 93+ corolla Manual pedals Brake+clutch with master might fit Celica -93 or 94+ not sure tho.
Thanks for looking at my stuff.
Mid/late Sep I'll be posting my 5SGTE partially assembled motor...so stay tuned.
This post has been edited by placham: Aug 15, 2012 - 6:01 PM
post Feb 8, 2012 - 11:27 PM
ricochet1490
Joined May 3, '11
From Ohio
jdm tail light dibs - do you have any pics of those? Or did I just miss them?
Edit: Nvm - the ones on the right?? Never seen ones like those. Let me do research and figure out what I want.
This post has been edited by ricochet1490: Feb 8, 2012 - 11:29 PM
post Feb 8, 2012 - 11:34 PM
mkernz22
Joined May 10, '10
From MA
QUOTE (ricochet1490 @ Feb 8, 2012 - 11:27 PM) *
those are the preface jdm light 94-95. the 96+ jdm lights are way different
post Feb 8, 2012 - 11:37 PM
ricochet1490
Joined May 3, '11
From Ohio
QUOTE (mkernz22 @ Feb 8, 2012 - 11:34 PM) *
Ah - I was wondering. I def need the 96+'s... oh well. i release my dibs lol
post Feb 9, 2012 - 2:32 AM
placham
Joined Nov 24, '10
From Worth, IL
QUOTE (ricochet1490 @ Feb 8, 2012 - 11:37 PM) *
Your talking about kouki tails with white/clear turn signal, like ones I'm rocking now they will run you in upper 250usd, unless u get one hell of a deal. Ones I got here are almost like USDM but signal is full amber I got them by a mistake (think their ether zenki or chuki not sure how celica gen thing works) kouki is late spec.
post Feb 9, 2012 - 6:09 PM
placham
Joined Nov 24, '10
From Worth, IL
Items moved to top of post.
This post has been edited by placham: Feb 14, 2012 - 3:15 PM
post Feb 9, 2012 - 8:28 PM
placham
Joined Nov 24, '10
From Worth, IL
Edited oil pan sold, pics removed.
This post has been edited by placham: Feb 14, 2012 - 3:14 PM
post Feb 10, 2012 - 5:42 PM
xs94st
Joined Aug 11, '07
From Corona, CA
Shipping cost of passenger fender to 92882 plz =]
Pandelica 2.0 in progress.
post Feb 10, 2012 - 8:27 PM
placham
Joined Nov 24, '10
From Worth, IL
QUOTE (xs94st @ Feb 10, 2012 - 6:42 PM) *
Also:
Jdm headlamps and USDM tails ........sold&shipped
St215 oil pan ..........sold&shipped
This post has been edited by placham: Feb 16, 2012 - 4:49 PM
post Feb 14, 2012 - 4:33 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
I give you $30+shipping priority to Hawaii 96731 for the Euro bezel
post Feb 14, 2012 - 10:45 AM
placham
Joined Nov 24, '10
From Worth, IL
QUOTE (808celica @ Feb 14, 2012 - 4:33 AM) *
Im not parting with it, besides I paid over 70 for it +postage from UK + paint to match my car, but nice try biggrin.gif u interested in USDM one?
xs94st-are u still interested in RT side fender, buyer never showed up so their back up.
This post has been edited by placham: Feb 14, 2012 - 10:48 AM
post Feb 15, 2012 - 2:09 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
QUOTE (placham @ Feb 14, 2012 - 5:45 AM) *
wow 70?!?!? i paid less for mines wink.gif i just need another one.
post Feb 15, 2012 - 5:04 PM
warthog1
Joined May 24, '11
From Glendale, AZ
Just received the head and tail lights. Thanks Matt. Well packaged and protected, items came as they were described. I had to perform surgery on the bubble wrap to get the headlights out. thumbsup.gif
post Feb 15, 2012 - 7:04 PM
placham
Joined Nov 24, '10
From Worth, IL
QUOTE (warthog1 @ Feb 15, 2012 - 6:04 PM) *
Im glad ur happy, yeah I did my best to package it, as I would expect no less if someone shipped something like that to me, I must be anal tongue.gif
Leave me feedback on forum if u can I'll do same when I get a chance.
Thanks,
Matt.
post Feb 15, 2012 - 8:54 PM
Driver
Joined Apr 3, '10
Hey! I'm interested in those water lines and you're really, REALLY close. I have cash! smile.gif
post Feb 16, 2012 - 12:33 AM
placham
Joined Nov 24, '10
From Worth, IL
QUOTE (Driver @ Feb 15, 2012 - 8:54 PM) *
Pm me ur cell number I get u my info, local pick up is more than welcome save me trouble shipping, cash is king, is Saturday fine for u.
This post has been edited by placham: Feb 16, 2012 - 8:41 AM
post Feb 16, 2012 - 12:43 AM
Driver
Joined Apr 3, '10
Saturday works for me! PM'd
post Mar 11, 2012 - 6:42 PM
Lindsley
Joined Jun 26, '11
From St.Lucia
do you have the st215 head?
post Mar 12, 2012 - 9:35 PM
placham
Joined Nov 24, '10
From Worth, IL
QUOTE (Lindsley @ Mar 11, 2012 - 6:42 PM) *
St215 is in my 6GC, out for t-belt and throw out bearing job.
Nope for St215 head, just spare ECU's and Top Mount I/C
And hybrid 5SGTE, that comes with 2nd Gen Head
Matt.
post Mar 13, 2012 - 10:31 AM
Skinerp89
Joined Aug 12, '08
From Maryland
which fenders do you have and how much? would nto mind having these if price is right.
Lo-Fi Version Time is now: November 26th, 2024 - 10:52 AM
