Shift light as part of the Rev guage. |
Dec 9, 2012 - 6:48 PM |
That looks decent for on the cheap.
Oct 4, 2014 - 6:54 AM |
Enthusiast Joined Jun 18, '11 From Lublin, Poland Currently Offline Reputation: 0 (0%) |
Hello guys !
I know it was long time ago that you were talking in this topic, but have anyone of you done this shift light using attached schematics? I tried to do it yesterday but it seems to be wrong in some point, it doesn't work for me |
Oct 5, 2014 - 3:33 PM |
Moderator Joined Nov 5, '07 From New Zealand Currently Offline Reputation: 3 (100%) |
I haven't tried it myself. Can you post up what you've done?
Oct 6, 2014 - 5:39 AM |
Enthusiast Joined Jul 1, '14 From Hawaii Currently Offline Reputation: 3 (100%) |
You can buy a shift light on eBay for about $15 shipped. Basically follow what the mightycarmods guys did except instead of the bulb, put a red LED Strip inplace of the bulb and curve it to the outside edge of the Tacho, then put some Aluminum tape on cardboard or paper to separate it from the Speedo unless you're okay with the bleeding light. Without the LED strip, the light is pretty dim and you can barely see it during the day. Total cost should be about $25 if you can get the LED strip light in red off of amazon or eBay which is around $10 for 5 meters which is more than enough. If you want to get RGB led strips you can also do the color changing backlight and then use an extra few inches and just set it up so it only lights up red. Theres usually 4 wires, some have 3 positives and a common ground, some have 1 positive and 3 grounds. Not hard to figure out which you have
Lo-Fi Version | Time is now: November 29th, 2024 - 9:31 AM |
