Enthusiast ![]() Joined Sep 30, '11 From Sydney Currently Offline Reputation: 0 (0%) ![]() |
Hi guys,
Was replacing the dizzy o-ring and broke a sensor i think ![]() When i had replaced the o-ring i went to fire up the engine and it did eventually but is horribly shaking and sounds like its running on 1 cylinder. This is what i broke, could this be whats causing my problem or did i probably just install the dizzy wrongly... ![]() ![]() ![]() Thanks |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 24, '07 From Oahu, Hawaii Currently Offline Reputation: 23 (100%) ![]() |
What motor? Looks like coolant temp sensor. How many prongs does the connector have?
-------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Its a 5s-fe and looks like 2 connectors
yeah most likely a coolant temp sensor.
Would that cause the engine to not run properly though?
http://www.auto-repair-help.com/auto_diagn...ture_sensor.php
read here to further expand your knowledge on your car -------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Enthusiast ![]() ![]() ![]() ![]() Joined Oct 18, '06 From cincinnati Currently Offline Reputation: 10 (100%) ![]() |
it could, but more than likely wouldn't cause it to run THAT bad. double check your dizzy install.
-------------------- proud =3sgte SWAPPED= '95 Celica ST owner [calling it the GT2 or half-trac]
309,000 miles n' .... |
finally found it in the BGB, it is the engine coolant temperature sensor. Double checked the dizzy install looks fine to me. I guess ill have to wait till tomorrow and order a new sensor
it could, but more than likely wouldn't cause it to run THAT bad. double check your dizzy install. yeah i was thinking the same thing. is your car OBDI or OBDII??? -------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Really not sure but its a 1997 ST204 ZR which is basically the Australian GT. I thought anything after 1996 was ODBII but that is just a guess
Really not sure but its a 1997 ST204 ZR which is basically the Australian GT. I thought anything after 1996 was ODBII but that is just a guess you are correct. your car is a obdII vehicle. no check engine lights on? if i can remember obdII 6's timing cant be adjusted at the distributor. so i wouldnt know what would have your car running like crap. -------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Enthusiast ![]() ![]() Joined Aug 29, '08 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) ![]() |
no you cant adjust timing after 96
I replaced the coolant temp sensor and she fired up just like normal and all is well now. Thanks guys!
Lo-Fi Version | Time is now: February 23rd, 2025 - 4:43 AM |
