> Best oil for 3s-gte?
post Feb 23, 2012 - 4:57 AM
dudeofchaos
Joined Dec 9, '08
From Blainville
I've always used Castrol Syntec but I've heard the Castrol Magnatec was very good at preventing engine wear due to cold start, though I believe there is only part syntec magnatec, I've always prefered fully synthetic oils.
Any one recommands one of them or any other brand? I will use 10w40 btw.
People seem to never be accurate when they talk about engine oil..
post Feb 23, 2012 - 8:42 AM
JozhGoober
Joined Jan 2, '12
From Rome, NY
I've never had any problems with Mobil 1 5W- or 10W-40 in my MR2's 3S-GTE, but the debate on best oil runs long. I've heard "German" Castrol Syntec is probably one of the best, but it can be hard to find.
post Feb 23, 2012 - 10:20 AM
bsamps4
Joined May 16, '10
From Raleigh
Royal Purple tested great!
post Feb 23, 2012 - 11:24 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
i use plain 5W30 or 10W30 oil. i dont spend the extra $$$ on synthetic
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Feb 23, 2012 - 12:14 PM
dudeofchaos
Joined Dec 9, '08
From Blainville
QUOTE (JozhGoober @ Feb 23, 2012 - 9:42 AM) *
I've always ran on Castrol Syntec and never had any problems, thought they made one of the best oil. Always hesitated to go with either Mobil 1 or Castrol though and now that I've heard of Castrol Magnatec I'm even more confused though I'm not sure I like the fact that it's partly synthetic kindasad.gif
post Feb 23, 2012 - 12:45 PM
mckenziejr
Joined Jan 29, '12
From toronto,ontario
Amsoil is probally one the best out there, you could also try royal purple, motul...
post Feb 23, 2012 - 3:59 PM
Sunny
Joined Nov 15, '10
From Austria
Hi,
10W40 is fine, but note that this has nothing to do with the quality that are just viscosity grades
for quality have a look to the ACEA and API specifiacitions
there is nothing wrong by using fully synthetic oils, they just becomes faster older due to the aditiv package -> aditives die faster against the base oil, so if you have a high VI you have more aditives in the base oil
-> example: a 10W60 has more aditives against a 10W40
i just can recomend not to use a lower viscosity of 10W, the 3S-GTE is a old engine and not developed for fuel-efficient engine oils, you are also run more in danger of oil film breaks * so
bearings, cams and turbo will thank you this especially when you drive hard
for example, when i drive 0W40 my engine eat the oil but with 10W40 i lost nearly nothing
* a 10W has typically a higher VI base oil against a 0W
unfortunelty my english isn't that perfect but i hope i was able to explaine you a little bit smile.gif
greetz
KEEP COOL UNDER PRESSURE
Lo-Fi Version Time is now: December 3rd, 2024 - 12:25 AM
