![]() Enthusiast ![]() Joined Jan 18, '08 From Brea, California Currently Offline Reputation: 10 (100%) ![]() |
Does anybody have this part laying around. mine broke off on the plastic piece
2 little air hoses connect to it ![]() ![]() This post has been edited by charming6gmoz: Feb 23, 2012 - 8:03 PM -------------------- Luis
Enthusiast ![]() ![]() ![]() ![]() Joined Oct 18, '06 From cincinnati Currently Offline Reputation: 10 (100%) ![]() |
bi-metal vacuum switching valve IIRC. it should run to the EGR and the charcoal canister I think...
I might have one around, feel free to make an offer in case I find it tomorrow. (or maybe later tonight) -------------------- proud =3sgte SWAPPED= '95 Celica ST owner [calling it the GT2 or half-trac]
309,000 miles n' .... |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 31, '11 From Rochester, NY Currently Offline Reputation: 5 (100%) ![]() |
Check out ebay, they're usually kicking around there. It's a EGR VSV. It tells the EGR when the car is warmed up and when it should open/close. I broke mine while changing my distributor cap and rotor a year ago and found one for cheaaap on ebay.
-------------------- 1994 Toyota Celica GT-S 5S-FE 190k Miles. Project car 1992 Toyota Celica GT 5S-FE 170k Miles. Daily driver/beater 1999 Toyota Camry LE 5S-FE 216K Miles. RIP You will be missed. ![]() *ASE Certified General Manager |
![]() Enthusiast ![]() ![]() Joined Nov 2, '09 From Tacoma, Wa. Currently Offline Reputation: 2 (100%) ![]() |
yeah the dealership sells those things for around $50. it's the most common thing to break on toyotas. every time i hit the junk yards those are the first things i look for.
-------------------- 1994 Celica GT- TenzoR 1.8in. Drop springs. 16mm wheel spacers.
yeah the dealership sells those things for around $50. it's the most common thing to break on toyotas. every time i hit the junk yards those are the first things i look for. yeah, they're too delicate and hard to come by. Check out ebay, they're usually kicking around there. It's a EGR VSV. It tells the EGR when the car is warmed up and when it should open/close. I broke mine while changing my distributor cap and rotor a year ago and found one for cheaaap on ebay. i'll check ebay see if i have any luck -------------------- Luis
Lo-Fi Version | Time is now: February 20th, 2025 - 12:48 PM |
