> header problems
post Feb 24, 2012 - 10:48 AM
TannerEsser
Joined Oct 17, '11
From Kent, WA
i was wondering if there is a way to run a header on a 5sfe with the cat under the header. is there a way to bypass the o2 sensors without driving around with the check engine light on?
post Feb 24, 2012 - 11:30 AM
199celica
Joined Jul 29, '11
From chino, Ca
QUOTE (TannerEsser @ Feb 24, 2012 - 10:48 AM) *
Im not to sure how well it works but weapon- r makes a cel eliminator for the o2 sennsors check it out and see what you think the site is called weapon-r.com
post Feb 24, 2012 - 11:36 AM
mkernz22
Joined May 10, '10
From MA
you get a check engine light? what header are you using?
post Feb 24, 2012 - 11:40 AM
TannerEsser
Joined Oct 17, '11
From Kent, WA
QUOTE (mkernz22 @ Feb 24, 2012 - 11:36 AM) *
well it will be on because no matter what header i get only one of the two o2 sensors will be atatched
post Feb 24, 2012 - 11:49 AM
JasonX
Joined Oct 18, '07
From Orange County, CA
i only got one o2 sensor attached on mine with no CEL.
QUOTE (TannerEsser @ Feb 24, 2012 - 8:40 AM) *
post Feb 24, 2012 - 11:50 AM
TannerEsser
Joined Oct 17, '11
From Kent, WA
QUOTE (JasonX @ Feb 24, 2012 - 12:49 PM) *
did yours only come with one?
post Feb 24, 2012 - 11:51 AM
mkernz22
Joined May 10, '10
From MA
no, if you buy any of the headers off eBay, they come with a mounting spot for both of the o2 sensors. I'm running the header from eBay, but since I have a '95, i only have 1 o2 sensor, but I'm still using the second one to see my A/F ratio.
This post has been edited by mkernz22: Feb 24, 2012 - 11:51 AM
post Feb 24, 2012 - 11:55 AM
TannerEsser
Joined Oct 17, '11
From Kent, WA
QUOTE (mkernz22 @ Feb 24, 2012 - 12:51 PM) *
ya but i have two for the emission control system. and if there is no cat converter in between those two sensors the check engine light will be on..
This post has been edited by TannerEsser: Feb 24, 2012 - 11:55 AM
post Feb 24, 2012 - 1:23 PM
mkernz22
Joined May 10, '10
From MA
i don't believe it will be on. i haven't heard of any problems on here before about.
post Feb 24, 2012 - 1:44 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
I have a ebay header with both o2 sensors in it an both are hooked up just like stock
I have no cell no light or anything
I dont have a cat earher
Idk if it will pass emissions or no since they dont check where i live
My light has kicked on once since the header an that was because my o2 came unplugged
94 st hatch my daily driver
n
post Feb 24, 2012 - 2:31 PM
Arsaces
Joined Oct 7, '10
OBD1 doesn't care, OBD2 'generally' does.
post Feb 24, 2012 - 3:08 PM
mandrek
Joined May 4, '05
From western MD/NOVA
QUOTE (Arsaces @ Feb 24, 2012 - 2:31 PM) *
post Feb 24, 2012 - 5:45 PM
TannerEsser
Joined Oct 17, '11
From Kent, WA
thanks guys. i do have a camry manifold. any ideas where i should put my second o2 sensor?
post Feb 24, 2012 - 5:52 PM
mkernz22
Joined May 10, '10
From MA
well if you can get some pics, it would be easier for us to help you
post Feb 24, 2012 - 6:16 PM
TannerEsser
Joined Oct 17, '11
From Kent, WA
just one second
post Feb 24, 2012 - 6:31 PM
TannerEsser
Joined Oct 17, '11
From Kent, WA
my engine
my o2 sensors
Camry manifold
post Feb 24, 2012 - 9:09 PM
RabidTRD
Joined May 31, '11
From Rochester, NY
Have a bung welded in above the 4 wire and put your 1 wire sniffer in. What year is your Celica? Looks the same as my 94 OBDI California emissions.
Just realized you have a two wire upstream, so you're OBDII.
If you want to run a cat, have a universal Magnaflow one welded in down below and extend the wires to it.
This post has been edited by RabidTRD: Feb 24, 2012 - 9:38 PM
post Feb 25, 2012 - 11:14 PM
mkernz22
Joined May 10, '10
From MA
QUOTE (RabidTRD @ Feb 24, 2012 - 9:09 PM) *
yes he is OBDII, but there were two sensors on my '95 cali spec.
as for that camry manifold, it maybe farther up on it, but i don't understand why you're replacing a stock exhaust with a stock exhaust...
just the a header off ebay! depending where you get it from, it shouldn't be too much
post Feb 27, 2012 - 10:30 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
CA cars have 2 O2 sensors, all years
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Feb 27, 2012 - 11:18 AM
TannerEsser
Joined Oct 17, '11
From Kent, WA
so just to clarify with my set up if i got ebay headers my check engine light would not be on?
Lo-Fi Version Time is now: February 22nd, 2025 - 11:02 PM
