Engine Stand Bolts, ... frick, what size do I need?? |
Feb 27, 2012 - 6:55 PM |
Enthusiast Joined Apr 18, '06 From Calgary, Canada Currently Offline Reputation: 37 (100%) |
I just realized that I need to pick up some bolts in order to mount my engine to my new engine stand I just bought.
Any ideas the size of bolts I need to pick up? (I'm obviously going to get grade 8 bolts, and I think they need to be course/fine thread, and maybe 3 1/2" in length - but diameter I'm not sure of) Halp? Hoping to mount the block on the flywheel side of the engine... (like normal) This post has been edited by KAOS: Feb 27, 2012 - 6:56 PM -------------------- |
Feb 27, 2012 - 7:30 PM |
Enthusiast Joined May 16, '10 From Raleigh Currently Offline Reputation: 12 (100%) |
I just realized that I need to pick up some bolts in order to mount my engine to my new engine stand I just bought. Any ideas the size of bolts I need to pick up? (I'm obviously going to get grade 8 bolts, and I think they need to be course/fine thread, and maybe 3 1/2" in length - but diameter I'm not sure of) Halp? Hoping to mount the block on the flywheel side of the engine... (like normal) Take one of your 17mm tranny bolts to the hardware store. -------------------- |
Feb 27, 2012 - 9:28 PM |
3/8''-16 x 3-1/2'' - should do the trick.
Sounds about right. Thanks bsamps4! -------------------- |
Mar 14, 2012 - 8:25 PM |
Enthusiast Joined Jul 7, '03 Currently Offline Reputation: 55 (100%) |
3/8''-16 x 3-1/2'' - should do the trick. Sounds about right. Thanks bsamps4! ? shouldn't it be metric? if it is close to a 3/8- 16 it is probably a 10mm 1.5 to clarify the 10mm probably has a 17mm head. A 3/8 -16 may actually thread in a ways but it is a smaller diameter with a different thread pitch so you could damage the block threads if you use those. This post has been edited by 97lestyousay: Mar 14, 2012 - 8:51 PM -------------------- JDM guy made me do it.
Mar 14, 2012 - 8:50 PM |
Actually Randy; you're right about it being metric, but it was a 12MM 1.5 thread! I don't remember the length I got them in, but I ended up getting them too long and had to use extra washers so they would bolt up nice and tight...
Sorry I forgot to update this thread! -------------------- |
Mar 14, 2012 - 8:55 PM |
yeah 17mm head sounds more like a 12mm.
Lo-Fi Version | Time is now: January 12th, 2025 - 4:46 AM |
