11 Pages V  « < 7 8 9 10 11 >
> My 1MZ progress thread
post Jan 25, 2013 - 1:05 PM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
Since you have all these toyota motors around, is there anyway you could compare an S series head with an MZ series head, or the deck on the block?
Id be interested to see how well they match up, a 1MZ-GTE would be pretty badass. Maybe its feasible to shave a cylinder off the head if the bore spacing and waterjackets match up. Ive seen someone weld two v8 heads together for a straight 6 before, so anything is possible.
This post has been edited by Special_Edy: Jan 25, 2013 - 1:06 PM
post Jan 28, 2013 - 9:03 PM
PizzaGuy01
Joined Nov 30, '12
From San Antonio
Any recommendations for a specific mz block for reliability/ease of swap for my daily college/pizza driver? Lexus or Toyota block make much difference?
post Jan 31, 2013 - 4:10 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
QUOTE (PizzaGuy01 @ Jan 28, 2013 - 6:03 PM) *
They're the exact same. A 1MZ from a 94 Camry is the same 1MZ from a 94 ES300... and so on.
**** Photobucket
post Jan 31, 2013 - 6:00 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
to make the swap the easiest, i suggest getting a 1MZ out of a 5 speed car. that way you are not dealing with ECU issues chasing Auto codes
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Jan 31, 2013 - 11:35 PM
95CelicaST
Joined Feb 5, '05
Agreed. 97+ ANYTHING Toyota/Lexus that has a V6 minus SC300.
**** Photobucket
post Feb 4, 2013 - 12:17 AM
Syaoran
Joined Jan 4, '12
From US
Smaay I need a little info to see if it's worth venturing into it. It's in relation to the coilpacks on the 1MZ-FE.
How many pins do the plugs to these have? I want to know if they have inbuilt igniters or if they're just coils. Also, how long do the boots for the plugs measure in inches?
1993 Celica GT Coupe - sold
1994 Celica GT Liftback
post Feb 4, 2013 - 1:10 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
the igniter is an external box just like the 5S. the coils i believe are only 2 wire and they are wasted spark meaning 1 coil feeds 2 cylinders. This is for the non VVT 1MZ
the VVT 1MZ and 3MZ are 4 wire i believe just like a 1ZZ or 2ZZ. they have the igniter built in i think.
you can see here the 2 wire plug on the side and the spark plug wire that runs around to the back 3 plugs.
post Feb 4, 2013 - 4:09 PM
Syaoran
Joined Jan 4, '12
From US
So these are just coils... hmm.
I'm going to run a wasted spark setup for now but I wanted to clean the bay up a little. I was thinking these would look cleaner. I could use these but Id rather use some with inbuilt igniters because it's better, noise-wise (less noise inside the megasquirt with the bip373s) and less heat as well.
Are the 3mz coils the same? I mean wasted spark, or individual COP?
post Mar 10, 2013 - 11:31 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
sorry i didnt see this sooner, the 3MZ actually went to a 4 wire coil on each cylinder so now there are 6 of them.
post Mar 10, 2013 - 11:59 AM
Syaoran
Joined Jan 4, '12
From US
QUOTE (Smaay @ Mar 10, 2013 - 12:31 PM) *
Oh so true COP then. Thanks for the info. Do you happen to have any of those laying around?
post Mar 20, 2013 - 1:59 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
sorry i dont
post Mar 27, 2013 - 11:02 AM
richee3
Joined Jun 29, '08
From Denver
I'd love to hear this thing. smile.gif Has there already been a video posted of the exhaust? I might've missed it.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Mar 27, 2013 - 11:47 PM
smkr3w
Joined Nov 29, '10
From Lake Havasu City, AZ
QUOTE (richee3 @ Mar 27, 2013 - 9:02 AM) *
http://www.youtube.com/watch?v=Rk0XhQXD1o4...eature=youtu.be
post Mar 28, 2013 - 12:42 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
QUOTE (smkr3w @ Mar 28, 2013 - 12:47 AM) *
oh yea i rem. needs to be redone without wind.
post Mar 28, 2013 - 12:54 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
i live in Lancaster, its always windy here. ill try to take a better video.
post May 20, 2013 - 9:58 PM
mr-belowaverage
Joined Feb 4, '07
From Ontario, Canada
QUOTE (Smaay @ Dec 21, 2012 - 5:11 PM) *
you will have to spend a little more if you go the route I did. im using a non VVT 1MZ ECU. so i have no VVT control. still making good power i think. i will make more once i figure out a way to control VVT.
How are you making out with the VVT? I am getting ready to drop a 3MZ into my 94 ST, and am currently sourcing the ECU. I have a ton of options, but they boil down to 1MZ with manual ecu, or 1MZ with VVT ecu, nothing with both. I'd really like to get the VVT working, but don't want to fight all the auto trans codes.
Also, how do you determine if ECU has immobilizer?
if you go with an E153, then just use ST205 engine mounts and my mount on the passenger side. use the axle carrier from the 05 Sienna. it fits perfectly
This is a fantastic tip!
post Jun 24, 2013 - 10:36 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
Just giving an update, the car is running as strong as ever. Im chasing an AC issue. i think i have a leak somewhere.
post Jun 24, 2013 - 12:04 PM
Box
Joined Feb 23, '12
From Warrior, AL
2001 Miata LS 5-speed
Box
Joined Feb 23, '12
From Warrior, AL
This post has been edited by Box: Jun 24, 2013 - 12:04 PM
post Jun 24, 2013 - 6:34 PM
richee3
Joined Jun 29, '08
From Denver
QUOTE (Smaay @ Jun 24, 2013 - 10:36 AM) *
That crap blows... Hopefully it's just an old O ring somewhere. I managed to crack one of my hard lines in one of the times I pulled my motor, then I made the mistake of trying to replace them with the motor in the car. I got it finished, but it would've been a lot easier with an empty engine bay. Then again, if it's something I've done, you've done it ten times and you're a hundred times better at it. smile.gif
1998 Celica GT-
BEAMS Swapped.
6 User(s) are reading this topic (6 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: November 22nd, 2024 - 4:59 AM
