11 Pages V  < 1 2 3 4 > »
> My 1MZ progress thread
post May 21, 2012 - 8:48 AM
rave2n
Joined May 29, '09
From Gainesville, FL
post May 21, 2012 - 8:58 AM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Love thw mount
94 st hatch my daily driver
n
post May 21, 2012 - 9:33 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
Thanks I can duplicate these for 200 bucks. I forget who else wanted on once i built mine. come forward so i can take care of ya
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post May 21, 2012 - 10:20 AM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Ill let you know when i have the extra cash
mine works for now but yours looks muxh cleaner
n
post May 21, 2012 - 5:28 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
I remember when mine was clean...
Lots of good stuff in this thread. When will my bottom end be ready, good sir?
**** Photobucket
post May 21, 2012 - 11:34 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
I got a new problem, since i have a 3MZ bottom end, the power steering pump that came with my 1MZ has no where to bolt up. can anyone help here?
post May 21, 2012 - 11:38 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
3mz pump maybe
n
post May 22, 2012 - 8:26 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
yeah thats what it looks like ill have to do,
post May 22, 2012 - 8:56 AM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Have you tryied the a/c pump or the alternator
you might end ul having that problem with them too
n
post May 22, 2012 - 10:57 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
no those look to be the same, the problem is the 3MZ belt tensioner is slightly different so it would be in the way of the PS pump mount. i need to find the bracket that bolts to the head first. i think that will help me line things up.
This post has been edited by Smaay: May 22, 2012 - 10:57 AM
post May 22, 2012 - 11:53 AM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Good luck
If anyone can make it work its you
Honestly tho
When im moving i dont notice much difference with or without ps
n
post May 25, 2012 - 4:41 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
here is a pic of the bracket i need
post May 26, 2012 - 8:03 AM
the 8k rpm on the celica is on the 1 oclock position, and on the other is on the 5 oclock position.
theoritically if you just swap the faces.
when the tach hits 6k rpm in real time, it will show 8k rpm on your swapped cluster, if you go beyond that then it will show the needle floating in neverland.
unless there is calibration involved, is there any?
This post has been edited by njccmd2002: May 26, 2012 - 8:08 AM
post May 26, 2012 - 9:25 AM
kurt95gt
Joined Aug 23, '11
From kenton ohio
If you dont swap to the v6 tach The tach wont work at all the 4cyl tach cant read the v6 signal
n
post May 26, 2012 - 10:07 AM
richee3
Joined Jun 29, '08
From Denver
You can use a Dakota Digital or MSD tach adapter to make that work without swapping tachs.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post May 26, 2012 - 10:20 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
Kurt is right, you cant just change the faces, you need to change the electronics. I also got the gauge cluster in my purchase with the engine. that is much cheaper than having to buy and wire in an MSD box
post May 26, 2012 - 12:16 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
so you swapped faces and the elecrtronics? im not clear on what you did really and how itll give a correct rpm reading..
if you use the stock gauge and electronics itll read 50% higher... i know from experience... redline on my v6 is past where the gauge stops moving.
i believe there is a resistor you can change to get it at the right calibration.
post May 29, 2012 - 1:55 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
no i just changed the electronic board. they have integrated circuits on them that are designed to receive a 4 cylinder pulse or a V6 pulse. the Camry face wouldn't fit in the celica cluster.
post May 29, 2012 - 3:04 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
did that board include the motor that moves the needle? if so then its still calibrated for the camry gauge face and would still be off, correct?... unless im missing something entirely
post May 29, 2012 - 3:08 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
It works stephen
Mr2 guys doit all the time lol
n
11 User(s) are reading this topic (11 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: November 22nd, 2024 - 1:21 AM
