My 1MZ progress thread |
Dec 27, 2013 - 12:26 PM |
ever sort out the speedo and tach issues?
Dec 27, 2013 - 4:26 PM |
Enthusiast Joined Mar 8, '12 From Hanford/Fresno, Ca Currently Offline Reputation: 20 (100%) |
ever sort out the speedo and tach issues? +1 Also smaay. You think you can enlighten this? I would've asked K-ESD but he's not active for the past 10 months. The Sienna fuel pump is bolt on. But he didn't say which Sienna? Do you happen to know this answer? This engine uses a returnless fuel system, basicly a ordinary fuel pump with the regulator inside the tank. I adapted this system by swaping out my 5SFE pump for a sienna pump (bolt on, plug and play), hacked off a section off the steel return line next to the pump, strapped on the regulator and Tee-d the main line to the return line on top of the fuel pump cap. -------------------- |
Dec 27, 2013 - 11:25 PM |
Im not sure what he did, i cant follow what he said. I dont think there is a difference in sienna pumps. i think what he was describing is converting the fuel system to returnless. Maybe the Sienna assembly is P&P on the celica. I dont know. I made my own fuel system
Apr 26, 2014 - 7:47 PM |
Enthusiast Joined May 29, '09 From Burlington, NC Currently Offline Reputation: 0 (0%) |
Bump. How's the 1MZFE doing? Giving you any trouble? Have you done any other mods? Really interesting thread.
-------------------- wow . teespring.com/savethemanual
Apr 27, 2014 - 7:55 PM |
Bump. How's the 1MZFE doing? Giving you any trouble? Have you done any other mods? Really interesting thread. its a 3MZ with 1MZ electronics, and yes its running awesome. Ever since i changed the harness to run on a 97 Camry ECU, i have no CEL. Im about to do another V6 swap in the GF's car. im going to document every step so stay tuned. -------------------- 2001 Celica GT-S Turbo
Apr 28, 2014 - 12:00 AM |
Schweeeeeeet!
Apr 28, 2014 - 12:09 PM |
Enthusiast Joined Feb 12, '13 From Cleveland Currently Offline Reputation: 5 (100%) |
Bump. How's the 1MZFE doing? Giving you any trouble? Have you done any other mods? Really interesting thread. its a 3MZ with 1MZ electronics, and yes its running awesome. Ever since i changed the harness to run on a 97 Camry ECU, i have no CEL. Im about to do another V6 swap in the GF's car. im going to document every step so stay tuned. I think i should hold off on mine and see the detailed steps you did haha, going to go the route of 3mz with 1mz electronics, i just got the a 97 avalon harness so thats in the bag already |
Apr 28, 2014 - 12:32 PM |
I think i should hold off on mine and see the detailed steps you did haha, going to go the route of 3mz with 1mz electronics, i just got the a 97 avalon harness so thats in the bag already get familiar with the harness. there are a bunch of plugs for the automatic that you dont need. I used a Camry harness and opened it up completely and ran only the wires that are needed. If you send me the Avalon harness and a celica harness I can build it for you -------------------- 2001 Celica GT-S Turbo
Apr 29, 2014 - 6:37 AM |
Your willing to build harnesses now
Hmmm this has me thinking -------------------- 95 gt coupe, v6 swap weekend toy
Apr 29, 2014 - 7:49 AM |
Your willing to build harnesses now Hmmm this has me thinking No Kurt, it's too late for me now. -------------------- 2001 Miata LS 5-speed
Jun 15, 2015 - 5:38 PM |
Enthusiast Joined Oct 3, '10 From Lansing, MI Currently Offline Reputation: 2 (100%) |
Jun 29, 2015 - 10:03 AM |
sorry just saw this. Im using the engine mount on the front of the engine, i just cut off the part that bolts to the camry frame. I also had to get a 3MZ bracket for the PS pump. toyota changed the location of the timing belt tensioner from 1MZ to 3MZ so you need to get either a 3MZ PS pump, or just the bracket if using a 1MZ pump
Sep 27, 2015 - 8:32 PM |
Enthusiast Joined Jun 21, '14 From Ottawa, Ontario, Canada Currently Offline Reputation: 0 (0%) |
This swap can be done right for 2000-2500 easy of ypu just want to do the stock swap an if ypu gpt yhe topls the mounts ate easy to make If I do get this done I bet I can do it for under $1000 CAD. That's my goal. Also when I mated the 1mz TB to my custom intake on the 5s I had to make a bracket with a offset in it so the TB would open fully. I can duplicate these easy. I'll post a pick of the bracket if any one is interested. One more thing. The vvt is that like a vtec . And if so what is different about the vvt-i. A friend of mine had a crx and he had a switch/button hooked up to the vtec solenoid so he could engage it at any time basically. I remember it was crazy fast when he pushed that button at around 4500 rpm. Just an idea. -------------------- |
Sep 27, 2015 - 9:41 PM |
VVT is nothing like VTEC.
VVT means the valve timing is variable. it changes with the conditions of the engine. VTEC is similar to LIFT in the 7th gen celica GT-S. its a different cam profile that is engaged at a certain RPM. -------------------- 2001 Celica GT-S Turbo
Sep 28, 2015 - 12:58 AM |
^i always thought the vvtli was similar to the ivtec?
Sep 28, 2015 - 7:30 AM |
no IVTECH is like VVTi.
Sep 28, 2015 - 3:45 PM |
Regardless if you had a 3MZ with a vvti in it then you could control the cam lift manually with a switch connected to the solenoid. No?
Sep 28, 2015 - 8:22 PM |
No lift in power band except in 7gc
Sep 28, 2015 - 8:42 PM |
Regardless if you had a 3MZ with a vvti in it then you could control the cam lift manually with a switch connected to the solenoid. No? There is no lift on a 3MZ. Only the 2ZZ got VVTL-i, every other engine is just VVT-i. -------------------- "Employ your time in improving yourself by other men's writings, so that you shall gain easily what others labored hard for." -Socrates. Even Socrates told us to use the search button!
Feb 4, 2023 - 12:05 AM |
Dang, celicatech is down, all my pics are gone
Lo-Fi Version | Time is now: November 22nd, 2024 - 1:47 AM |
