> WTB: Manual Transmission Swap
post Feb 29, 2012 - 11:05 AM
JozhGoober
Joined Jan 2, '12
From Rome, NY
Hey all. I got a nice little bonus, so I'm looking for an S54 and all the related clutch hydraulics for my '99 GT. I also need shifter cables, though I already have a 7G shifter. Bonus points if someone has a manual ECU, but if not I don't need an inspection until September, so a check engine isn't a big deal for now.
List of things I'm looking for:
S54 transmission (preferably under 150k miles, my engine has 130k so I'm not TERRIBLY picky, but it shouldn't need a rebuild)
Driver's side transmission mount
Shifter cables
Clutch master cyl, slave cyl, and related lines
Clutch pedal assembly
Brake pedal
Flywheel (lightweight preferred, used okay as long as it's in good shape. I can get it resurfaced if need be)
New or lightly used OEM-spec clutch and pressure plate
Manual ECU (optional)
I'm in central NY, but I don't mind traveling a bit to pick up the transmission if you're in the northeast. I can find excuses to travel to NYC or Pennsylvania on a weekend. Everything else shouldn't be too much to ship.
If you think I've forgotten anything for this, let me know! I probably have. And if anyone wants my auto transmission after this, you can have it!
post Feb 29, 2012 - 11:37 AM
Fate
Joined Nov 30, '04
From Atlantic City
PMed.
post Feb 29, 2012 - 11:39 AM
BoostedRicer
Joined Apr 2, '11
From Gloucester/804
I have a good transmission out of a 1994 ST w/ stage 2 excedy clutch and everything else on the car you would need to do the conversion. I do believe the ST 1.8L motor's have the transmission you are speaking about? I am almost certain. Correct me if I'm wrong? Well my car is being parted out and the trans/clutch/pedals/manual ecu/ everything is still on the car, so if you know that this swap would work for you and your set up, let me know and we can talk about a price!
BoostedRicer
Joined Apr 2, '11
From Gloucester/804
~bump also biggrin.gif~
This post has been edited by BoostedRicer: Feb 29, 2012 - 11:39 AM
post Feb 29, 2012 - 12:03 PM
JozhGoober
Joined Jan 2, '12
From Rome, NY
QUOTE (BoostedRicer @ Feb 29, 2012 - 11:39 AM) *
Sorry, the ST's 7AFE has a C52 transmission. But! I'm not sure if the clutch hydraulic system is the same or not. If it is, I'd be interested in those parts, can anyone chime in on that?
post Feb 29, 2012 - 12:23 PM
BoostedRicer
Joined Apr 2, '11
From Gloucester/804
I don't know? I'm guessing google would know if we could question it right lol..
post Feb 29, 2012 - 12:40 PM
JozhGoober
Joined Jan 2, '12
From Rome, NY
QUOTE (BoostedRicer @ Feb 29, 2012 - 12:23 PM) *
Humm, according to ToyoDIY, the master cylinder is the same but the slave is not. It seems to be kind of hit or miss what is compatible and what isn't.
I appreciate the offer, though! Good luck with your part out.
post Feb 29, 2012 - 3:51 PM
Muggs
Joined Sep 13, '06
From St. paul, MN
I have a set of shifter cables, make an offer if interested..
Lo-Fi Version Time is now: February 13th, 2025 - 7:08 AM
