jdm 7afe engine swap |
Mar 1, 2012 - 12:27 AM |
Enthusiast Joined Feb 29, '12 From mississippi Currently Offline Reputation: 0 (0%) |
i am ordering a jdm 7afe engine but it doesn't have a wiring harness and ecu. could i just use mine and put my distributor on the jdm motor?
thanks for the time and info |
Mar 1, 2012 - 11:39 PM |
Enthusiast Joined Jun 4, '10 From Jax Beach, FL Currently Offline Reputation: 0 (0%) |
What year make and model of your car and what year is the JDM?
Mar 2, 2012 - 1:31 AM |
Enthusiast Joined Dec 9, '05 From Germany Currently Offline Reputation: 0 (0%) |
Mar 3, 2012 - 4:09 AM |
thanks i got a refund from jdm engine zone and got one from ebay from jdm engine corp. that comes with a ecu and wire harness.. just gotta figure out how im gonna fix the problem of the location of the harness is at and how i can make it feet to where i can put the harness threw the fire wall .... the jdm motor's wire harnees is made for a right hand drive car there for the location where the main harness ends up will be the front driver side and i need to run the wires threw the firewall in the back passenger side of the engine bay.
i have my work cut out for me my car is a 1995 toyota celica st the motor is a 7afe from ebay unknown what car it was in its from jdm engine corp. http://www.ebay.com/itm/320858622259?ssPag...984.m1426.l2649 |
Mar 3, 2012 - 7:23 AM |
Dude... since no-one is giving you a straight answer...
There are 2 versions of the 7AFE available all over the world. Being "JDM" doesn't make it any better. Version 1... some versions had TVIS which was a butterfly system in the intake runners designed to increase torque and throttle response. This engine was not available in the US and probably won't be a direct swap... probably because ignition components may be different as well as a variety of other unknowns. 2nd version is what we have... non-TVIS... which can be "JDM". Being JDM doesn't necessarily mean it's a different engine. So long as the head is the non-TVIS head... you can bolt-up your current stuff, assuming you currently have a 7AFE powered celica... and you're done. No headaches. You should be able to find this engine locally... it's quite common. There are also a variety of used engine distributors... so I would look around first before forking over a lot of money to ship for a cheap engine... and do your research (I guess that's what you're doing here)... cause if you end up getting a TVIS 7AFE and then are now talking about wiring and all that jazz... you might as well upgrade. Also: the 7AFE pictured in that ebay auction is the TVIS model... so I would avoid it. This post has been edited by Kwanza26: Mar 3, 2012 - 7:26 AM -------------------- "It's ok to be naked girl... I'm an artist!"
Mar 3, 2012 - 6:09 PM |
Enthusiast Joined Dec 30, '11 From Atlanta via Mobile Currently Offline Reputation: 0 (0%) |
All the wiring is included. I'd say give it a shot. I'd like to know the difference the TVIS makes.
Mar 3, 2012 - 7:20 PM |
Wiring is not fun. I'm in the middle of a similar process. Obd I to obdII. Its not a fun process unless u know exactly where everything is going
Mar 3, 2012 - 7:43 PM |
All the wiring is included. I'd say give it a shot. I'd like to know the difference the TVIS makes. Then why not throw in a 4AGE 20V or a 4AGZE or even a 3SGTE? It's the same process... -------------------- "It's ok to be naked girl... I'm an artist!"
Mar 7, 2012 - 11:30 PM |
i would do a 3SGTE but i dont have the cash to do a awd swap.
but later in the year i might save up for this swap. ill just get a front clip from ebay for 4500 it comes with the awd transmission rear axle and 3SGTE and right hand drive dash i just had 1000 to threw on a motor. mine had 350k miles and was burning oil daily |
Mar 8, 2012 - 10:33 AM |
^ No need for an AWD swap, you can run the 3S-GTE on an S54 transmission, which comes from the USDM GT.
'93 MX-5 LE |
Lo-Fi Version | Time is now: November 22nd, 2024 - 7:44 PM |
