Has any one got a cold air intake on there SX-R |
Mar 4, 2012 - 1:40 AM |
Enthusiast Joined Feb 29, '12 From reload34 Currently Offline Reputation: 0 (0%) |
I've seen some pix , but I have a cruise control box in the way so what other way can I make a cold air intake
Mar 4, 2012 - 3:18 PM |
Enthusiast Joined May 31, '11 From Rochester, NY Currently Offline Reputation: 5 (100%) |
Route it through the factory location under the fuse box. You'll have to cut some plastic to make it work, but it is possible.
-------------------- 1994 Toyota Celica GT-S 5S-FE 190k Miles. Project car 1992 Toyota Celica GT 5S-FE 170k Miles. Daily driver/beater 1999 Toyota Camry LE 5S-FE 216K Miles. RIP You will be missed. *ASE Certified General Manager |
Mar 7, 2012 - 5:21 AM |
Mar 7, 2012 - 9:15 AM |
Uhhh what?
If it comes down to it you can remove the fuse box from the car and set it aside during the install, but if you remove all of the mounting bolts it should have some play in it. -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Mar 8, 2012 - 11:58 AM |
Enthusiast Joined Oct 17, '11 From Kent, WA Currently Offline Reputation: 0 (0%) |
i moved mine to behind my battery. i can post pictures later if you want. its by far the easiest way to do it. all you need is a cut off wheel or hack saw a drill and a self tapping screw.
Lo-Fi Version | Time is now: November 23rd, 2024 - 2:31 AM |
