10 Pages V  « < 3 4 5 6 7 > »
> diegohiga celica progress, 3rd gen 3sgte, jdm mirrors, quick release steeringwheel installed.
post Oct 13, 2012 - 10:48 PM
diegohiga
Joined May 4, '09
From coral springs florida US
QUOTE (CRTRD @ Oct 13, 2012 - 11:45 PM) *
Diegoooooo !!!! If u need a non turbo fuel pump from supra there is like 4 down here in Miami I can find u one unless u need a new one or something
first i need someone here on the forum to confirm this info is right. and yeah i would get a new one. had issues before with fuel pump not working because they get old and it sucks haha
post Oct 28, 2012 - 11:06 PM
diegohiga
Joined May 4, '09
do i need a gt4 trottle cable or gt one works fine? because i realized that the cable goes around the valve cover an seems much longer than the gt or st cable
post Oct 29, 2012 - 8:19 AM
GT is fine.
post Nov 2, 2012 - 7:47 PM
diegohiga
Joined May 4, '09
today i got a couple packages laugh.gif albro
APEXI n1 muffler
megan racing 2 core radiator
QTP exhaust electic cutout 3"'
Walbro fuel pump
try to take a pic measuring the outlet but came out blurry. inlet is 3' and oulet 4.5'
post Nov 3, 2012 - 11:53 AM
Syaoran
Joined Jan 4, '12
From US
I was searching around and found this topic: http://www.6gc.net/forums/index.php?showto...ss-iii+trd+rear
It's come along really well.
1993 Celica GT Coupe - sold
1994 Celica GT Liftback
post Nov 4, 2012 - 3:11 PM
enderswift
Joined Jul 12, '08
post Nov 4, 2012 - 11:48 PM
diegohiga
Joined May 4, '09
QUOTE (Syaoran @ Nov 3, 2012 - 11:53 AM) *
wowww thats old haha i had different ideas back then, that front bumer was pretty ugly now that i see it hahaa
QUOTE (enderswift @ Nov 4, 2012 - 3:11 PM) *
post Nov 5, 2012 - 2:10 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
That'll look real nice.
Whats the "exhaust cutout" ?
My Celica!
post Nov 5, 2012 - 5:34 PM
richee3
Joined Jun 29, '08
From Denver
It's a butterfly valve to bypass the majority of the exhaust for more power when he chooses, when he gets the 3S swapped in. thumbsup.gif
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Nov 5, 2012 - 7:00 PM
Ted95
Joined Mar 8, '09
From Westport, MA
The cutout is a great option for instant power without further adjusting your boost controller. I'm running 14psi with my cutout closed and jumps up to 17psi with the cutout open and sounds great!
This post has been edited by Ted95: Nov 5, 2012 - 8:56 PM
st205 powered ss3 coupe
post Nov 6, 2012 - 2:02 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
QUOTE (richee3 @ Nov 5, 2012 - 6:34 PM) *
Thats what I though.
So, electronically controlled, you can let more exhaust flow for more power?
My Celica!
post Nov 6, 2012 - 3:52 PM
Syaoran
Joined Jan 4, '12
From US
QUOTE (jordisonjr @ Nov 6, 2012 - 3:02 PM) *
Yep, basically you put it before anything ideally (cats, resonators, mufflers) to simulate an open downpipe.
You can also do it with a throttle body. My previous Celica had it done with a 60mm TB on 2.25" exhaust tubing. The difference is it's manual vs electronic. I plan on doing it again to my actual Celica, and it'll be manual again. There's no motor that can go bad that way.
post Nov 7, 2012 - 2:20 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
QUOTE (Syaoran @ Nov 6, 2012 - 3:52 PM) *
This would only be beneficial to a Forced induction motor, correct?
Would that not cause a decrease in back pressure on a n/a, resulting in a loss of power? (if used in the exhaust)
My Celica!
post Nov 9, 2012 - 12:27 AM
Syaoran
Joined Jan 4, '12
From US
QUOTE (jordisonjr @ Nov 7, 2012 - 3:20 PM) *
Depends on the location and application. Think of it as an alternative, not an upgrade. Instead of getting a noisy exhaust, you can bypass your stock muffler with upgraded exhaust tubing up until the cutout, then scale down to stock for quietness.
In a Forced Induction setup you could use it as an exhaust bypass, which would mean better spool, for example.
post Nov 9, 2012 - 10:41 AM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
Yall are silly. The real reason you spend hundreds of $s on exhaust cutouts if for the sound. The car goes from quiet like grandma's grocery getter to open headers racecar pitstop in a few seconds.
And backpressure on any engine is bad, its high velocity flow which is good for a N/A.
post Nov 9, 2012 - 10:49 AM
QUOTE (Special_Edy @ Nov 9, 2012 - 11:41 AM) *
post Nov 9, 2012 - 11:07 AM
Syaoran
Joined Jan 4, '12
From US
That's the only reason why it was on my previous Celica...
post Nov 9, 2012 - 2:06 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
QUOTE (Special_Edy @ Nov 9, 2012 - 10:41 AM) *
Go put 3" exhaust, from header back on your n/a, and let me know how that works out for you. laugh.gif
My Celica!
post Nov 9, 2012 - 3:53 PM
Syaoran
Joined Jan 4, '12
From US
QUOTE (jordisonjr @ Nov 9, 2012 - 3:06 PM) *
Backpressure is bad. NA engines need high velocity exhaust flow. Narrow piping generates more backpressure than wider piping, but it also speeds up the exhaust gas velocity.
So it's not really backpressure what you want, it's exhaust velocity.
Hotter air also flows faster, which is one of the reasons why things are thermal-wrapped and coated. They help keep the heat in which in turn speeds up exhaust gas velocity.
What backpressure means in an engine is that the exhaust gases are being restricted or prevented from exiting the combustion chamber. If backpressure was good, clogged cats wouldn't be bad, as they generate immense amouns of backpressure.
post Nov 9, 2012 - 4:43 PM
smkr3w
Joined Nov 29, '10
From Lake Havasu City, AZ
Stop arguing and click here
..And let Diego have his thread back so he can post some more pics of his amazing car smile.gif
Lo-Fi Version Time is now: November 30th, 2024 - 2:48 AM
