> 5th Gen 3sge, Battery light and overheat light on
post Mar 7, 2012 - 2:54 PM
PolliS_5S-FE
Joined Aug 29, '08
From Auckland, New Zealand
Hi guys, just recently did the headgasket on my mates 5th gen with a 3sge, ran fine, idling a little low but is running good until yesterday while driving the battery light comes on along with what im guessing is the overheating light looks like:
sss
The 's'es are supposed to be squiggly lines.
No engine codes, serpentine belt isnt broken, as far as i can see all the pulleys are turning...
Any ideas??
Also the light that looks like the car with lights on is on.
post Mar 7, 2012 - 8:58 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
alternator working?
post Mar 7, 2012 - 11:46 PM
Rusty
Joined Nov 5, '07
From New Zealand
thats the catalytic converter temp sensor.
if it comes on when you first start the car, it could be a faulty sensor. But if the warning light comes on when driving the cat could be blocked.
heres a pic I found on google. bonus its even a celica.
* the oil light should be oil pressure, not oil level.
post Mar 8, 2012 - 1:15 AM
PolliS_5S-FE
Joined Aug 29, '08
Thankyou rusty, I knew you would comment! tongue.gif you = 3sge.
So it seems strange to me that the rear lights go at the same time as the cat (possibly) sensor. Could this be a short somewhere?
post Mar 11, 2012 - 1:44 AM
delusionz
Joined Feb 11, '08
its your alternator dieing, the other lights come up because they rely on seeing 12v+ which obviously your alternator isnt putting out. replace that alternator before you get stranded somewhere.
(from identical experience)
Mike W
269awhp / 273ft-lbs
post Mar 11, 2012 - 6:04 PM
PolliS_5S-FE
Joined Aug 29, '08
Thankyou.
Lo-Fi Version Time is now: February 21st, 2025 - 2:25 PM
