> Guys, I am about to lose my mind!!
post Mar 12, 2012 - 9:36 PM
6G96GT
Joined Jan 20, '08
From East Coast
I'll just break it down like this:
I start my car and my belt squeals. I let my car run about a couple minutes and then drive about 1 mile to the highway (it squeals the whole time). I get on the highway and eventually within about 2 more minutes, it will stop squealing. About 20 minutes later I slow down for EZ pass and it starts to squeal again. Then I take off after passing through EZ pass and it stops. I make it another 10 miles and finally slow down to a couple lights. It starts to squeal again and will squeal whenever it decides to after I get off the highway.
Sometimes at a light it will stop. Then when the light turns green, I take off and it squeals until I get into 3rd gear. Then it stops and will come and go.
If I park my car for less than 2 hours, it squeals again at start up immediately.
It doesn't matter if I am turning or not...it will sometimes squeal and sometimes not.
My belts seem dry and I am not losing any fluid. WHAT THE HELL?????
post Mar 12, 2012 - 9:43 PM
block
Joined Jul 27, '06
From Soda
Alternator belt.
post Mar 12, 2012 - 9:54 PM
3WayStunna
Joined Jun 25, '06
From Box Elder, South Dakota
QUOTE (block @ Mar 12, 2012 - 9:43 PM) *
TIGHTEN Alternator belt.
Think you meant this right? ^_^
This post has been edited by 3WayStunna: Mar 12, 2012 - 9:55 PM
(\__/)
post Mar 12, 2012 - 10:03 PM
block
Joined Jul 27, '06
From Soda
And that too. Sometimes on cold starts it'll squeal until warmed.
post Mar 14, 2012 - 12:13 AM
Araykhel
Joined Sep 21, '10
From Woodstock, MD
Alternator belt 100% lol. I had the pleasure of getting the squeals this winter only to find that my alternator bracket sheared a bolt near my water pump laugh.gif .
post Mar 14, 2012 - 7:19 AM
b22ri22an
Joined Jun 2, '10
From Davenport, Florida
wow same bolt that broke on mine, cost me a fortune to have fixed
post Mar 14, 2012 - 9:57 AM
schmooot
Joined Sep 29, '09
From Prince George, BC CANADA EH!
just replace the belt, cheap easy fix. Or for an even cheaper temporary fix, rub the butt end of a candle on the belt as it is spinning to see if it stops squeaking. This also helps to determine which belt is actually squealing if there was any doubt
ST205 Crew represent
Challenge Accepted
post Mar 14, 2012 - 4:04 PM
richee3
Joined Jun 29, '08
From Denver
Since its cheap, I would replace the power steering belt while as well. That way you know 100% that you've replaced both belts, know neither will snap while you're driving down the road, and can ensure that the squealing will be gone regardless of which belt it is.
This post has been edited by richee3: Mar 14, 2012 - 4:06 PM
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Mar 18, 2012 - 8:28 AM
6G96GT
Joined Jan 20, '08
From East Coast
Thanks guys, it was in fact the alternator belt.
post Mar 18, 2012 - 8:34 AM
o gosh, well good find, i was going to tell you to stop torturing the pig
Lo-Fi Version Time is now: December 2nd, 2024 - 9:42 AM
